Dryspace And Mid-span Blocking?
Old 09-17-2008, 09:26 PM   #1
The Deck Guy
Greg Di's Avatar
How the heck do you run the joist caps when there is midspan blocking installed? Looks to be impossible to keep the cap continuous without doing some serious surgery on all the blocks.
Anyone know?
I am 80% done with a job and now the HO tells me they "don't want to see any wood" under the deck. This means we are installing Fypon column wraps, Azeking the girder, etc....
PITA!
Before I give them a price for all this, I want to know what the deal with Dryspace is because I've only heard negatives about it from two different dealers and read about the leak issues online.
Also, has anyone ever installed 120V lighting (recessed in a dryspace system). If so, how???
Greg Di is offline
Old 09-17-2008, 10:10 PM   #2
John Hyatt
John Hyatt's Avatar
Re: Dryspace And Mid-span Blocking?
If your talking bout the TimberTech product it is a pita all together. The gutter system is marganial at best, it cant go around blocking with out a lot of spacers,no holes can be installed in it or thru it. J.
John Hyatt is offline
Old 09-17-2008, 10:18 PM   #3
BuiltByMAC's Avatar
Trade: Construction
If you've got the headroom, you could install tapered 2x to each joist and mount the DS joist caps to those. That way, they'd be below the blocking.
Haven't had any callbacks for leaks myself on the DS roofs I've installed...
Don't know if you'll be able to successfully cut holes and mount lights in a DS system, seems like a recipe for failure. If you get the job and come up with a solution, please either drop a line here or PM me. I'd be interested in possible solutions for this.
Mac
BuiltByMAC is offline
Old 09-17-2008, 10:26 PM   #4
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
We've done 1/2 high blocking and joist jacket notching and custom fab'n.
It's a bit of work. I like Mac's idea of addt. 2x's...
~Matt
BreyerConstruct is offline
Old 09-17-2008, 11:32 PM   #5
The Deck Guy
Greg Di's Avatar
Thanks guys...I just priced out this little change order and it's nearly $7,000.
I'm not sure they'll go for it. If they do, at least I charged for the aggravation.
I appreciate having you guys here to bounce things off of. It's a huge asset to me. THANKS!
Greg Di is offline
