Dry-Snap Deck Drainage
Old 11-25-2008, 09:56 AM   #1
decks-patios-remodeling
deckndave's Avatar
Trade: Deck, patios & remodeling
Rewards Points: 75
Does anyone have any thoughts regarding this product? I will be installing about 600 SF and was wondering how easy it is to work with.
I've attached a few pics of this job. I must say the dry snap system looks fab!
Dry-Snap deck drainage-jw601.jpg   Dry-Snap deck drainage-jw597.jpg   Dry-Snap deck drainage-jw608.jpg
deckndave is offline
Old 11-25-2008, 12:02 PM   #2
hailey's Avatar
Trade: vinyl decks and fence
Rewards Points: 150
Re: Dry-Snap Deck Drainage
Haven't used that system...we use American Dry Deck.The installation seems like it may be easier.What's the cost like on it?
hailey is offline
Old 11-25-2008, 01:39 PM   #3
bighammer's Avatar
Trade: Lead Nail Bender....
Rewards Points: 95
We have installed some of the "Dry Space" by Timbertech, and it works really easy, it is a good system and we had no trouble with it - we charged customer 20% more than what we get for laying floor (working over our heads...not so fun)
bighammer is offline
Old 11-25-2008, 06:37 PM   #4
deckndave's Avatar
Rewards Points: 75
Cost was about $5.50 sf
Here's a few more pics for your viewing pleasure
Old 11-25-2008, 08:05 PM   #5
Bone Saw's Avatar
Trade: decks
Rewards Points: 2,076
looks good, easy install, leaks like a sob
Bone Saw is offline
Old 11-25-2008, 09:01 PM   #6
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
Bone Mon,we are on the same page. J.
John Hyatt is offline
Old 11-30-2008, 12:10 PM   #7
deckndave's Avatar
Rewards Points: 75
Hmmmm. Not good.... not good at all. Bone saw, were the leaks easily repaired.
Old 12-01-2008, 09:13 AM   #8
hailey's Avatar
Rewards Points: 150
Ahhhhh...thus my suprise with the 5.50/sqft....American Dry Deck prices out at double that , looks great,fairly easy install , no leaks. I guess the old addage rings true here.
hailey is offline
Old 02-18-2009, 10:15 PM   #9
deckndave's Avatar
Rewards Points: 75
Bone, when should I start expecting these leaks? It's been almost 3 months and no leaks yet. How long afer installation did you learn of the leaks?
Old 02-18-2009, 10:45 PM   #10
OW! My thumb's Avatar
Trade: Finished /Remod/Decks/ done it all /whatever pays
Rewards Points: 306
I can see the problem if you dont snap the panels in just right , and sometimes you really got to make sure. The very last one to install is a bitch.
Anyway, I did one last year and its still doing its thing.
OW! My thumb is offline
Old 02-18-2009, 11:00 PM   #11
dlcj's Avatar
Trade: home builder carpenter Central Alabama
Did one last summer with 26g galv corragated metal. Used different length screws and standoffs for the pitch to the gutter. Whole thing cost under $3sqft. Labor and all. Did the 720 sqft by myself in 2 days. Looks great and the owner loves it.
dlcj is offline
Old 06-07-2009, 10:19 PM   #12
deckndave's Avatar
Rewards Points: 75
bump
Old 06-08-2009, 08:11 AM   #13
BuiltByMAC's Avatar
Trade: Deck guy
Rewards Points: 2,270
Nice looking system, any tips or tricks regarding the process?
You do the deck as well?
Mac
BuiltByMAC is offline
Old 06-08-2009, 08:49 AM   #14
deckndave's Avatar
Rewards Points: 75
Yes, I built the deck also. This job started out as just a repair and stain job. As I get into the job I find a tremendous amount of rotten framing. It had a dry below system installed 2 years ago and keep in mind the deck was 25-30 years old. I actually found earthworms in the wood 8' above ground. Still scratching my head on why any contractor would try putting a new drainage system on a 30 year old rotten deck. We tried to salvage the old system and reuse but wound up going with the dry snap system. It's holding up so far but from some of the earlier posts I'm not sure how long.
Old 06-15-2009, 07:16 PM   #15
Fine Deckbuilder
Clemens's Avatar
Trade: Deck business
Rewards Points: 250
We did had a few leaks on a couple jobs. Those where existing decks and using the existing framing. With new decks there are no problems. We found that the 1/4" spacers does give enough slope but with existing (old) framing if some of the joist are a little higher it would lift up the panel in that area also and the slope is not enough and creates a puddle (and leak) In addition with an added 12" flashing at the ledger we move the first spacer 6" away from the ledger. Installation manual calls for 2 1/2"
By having 6" we have the option to lift the panels slighty higher with a trim piece. Instead of the 24" requirements for spacers we use 16" to create a slighty higher slope. After using this method we never had a leak anymore.
Hope this helps,
Clemens
Clemens is offline
Old 06-16-2009, 04:36 AM   #16
Bone Saw's Avatar
Trade: decks
hi clemens, good to see you here, how those augers treating you.
Bone Saw is offline
Old 06-16-2009, 06:26 AM   #17
Fine Deckbuilder
Clemens's Avatar
Rewards Points: 250
Hello Chris,
I'm doing fine and the augers are still working (after a few repairs during the last two years) Still working by yourself?
Hope all is well and talk to you soon
Clemens is offline
Old 01-21-2010, 07:08 PM   #18
Chava's Avatar
Trade: Landscape Contractor, Patios,walks,walls,gazebos
I'm interested in becoming an installer of some type of underdeck waterproofing systems. I like the look of the Snap Dry system but am still undecided. I spoke with the rep for the region and he indicated that an average project would cost about $4.50 for the materials and I would be able to charge about $8.50/sq. ft. This seems really low, although I don't fully have a grasp of the installation time for a smaller project. Could someone give me a range of what my pricing should be? Also, how many square feet can you install in a day? Thanks for your help.
Chava is offline
Old 01-21-2010, 07:22 PM   #19
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
Took 2 guys 2 days to rap upper & lower decks with PVC board and install Dry Space, Deck size 18' x 16'
festerized is offline
24x24 Deck amanandhisvan Decks & Fencing 63 09-24-2008 10:59 PM
Looking for deck and fence builder - Chicago west suburb Green_2 Help Wanted or Looking For Work 0 09-07-2008 05:34 AM
Used the new Correct Deck CX-personal review IHI Decks & Fencing 22 07-27-2008 08:52 PM
Second story deck drainage system floorsforsure Decks & Fencing 0 05-28-2008 09:21 PM
Deck drainage system Onsite1 Decks & Fencing 2 02-23-2008 11:00 AM
