Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Decks & Fencing
Old 05-06-2009, 11:07 PM   #1
Trade: Remodel
Dry Joist deck system
A question for anybody that cares to give their input.
I've got a homeowner that wants to use a system called Dry Joist. It is another product designed to keep areas below a deck dry. Sort of unique in that the system is actually part of the deck structure and doubles as a ceiling below the deck. Seems straight forward enough. I would personally have trimmed out the framing members under the deck with cedar etc.. for a more finished look. See link and go to gallery for pics.
Well I guess I cant post a web site because I'm still a newbie. So the company is Wahoo decks and the product is Dry Joist
Thanks for any info y'all might have.
ProHab is offline   Reply With Quote
Old 05-07-2009, 07:15 AM   #2
John Hyatt
John Hyatt's Avatar
Trade: out door areas, decks,spa room additions,fire pits,custom design
I got a big sample pack/info a few days ago. Intersting idea,and a Lot more $ than a torchdown/stringers. J.
John Hyatt is offline   Reply With Quote
Old 05-07-2009, 08:53 AM   #3
Composite Decking Mfr
MartyCD's Avatar
Trade: Manufacturer of Composite Decking, LEED AP
There are two basic types of systems, those that are below the joists and double as a ceiling, and those that hang on top of the joists and you provide the ceiling. For the on top of the joists type, you have more flexibility to add can lights and fans; can do any ceiling that fits the decor; and you might get some benefit from the joists being protected from the weather. Rain Escape is a top-of-joist system I have used with good results.
Marty
MartyCD is offline   Reply With Quote
Old 05-07-2009, 12:23 PM   #4
Trade: Remodel
Marty,
This system actually sits on top of the deck joists. The bottom of the system is actually visible from below the deck. The part that actually sits on the joists is finished aluminum that acts as the ceiling as well as support for the decking above. The product is structural so you don't need nearly as many joists. Since I can't put a url to link to, because I don't have 15 posts, just search WahooDecks and the product is DryJoist. They have a diagram on the site. Looks to be a pretty neat system though I'm sure it is pricey.
Old 05-07-2009, 08:25 PM   #5
Trade: Deck Builder
Personally I think any of those "on top of joist" systems are a crap shoot. Sooner or later they're going to leak then you have to deal with taking off the decking to fix it, no thanks. Either conventional frame it then the torch down roof/deck above or if the deck is all ready built then use metal roofing under the deck. I'd bet good $ either of those will outlast any "on top of joist" system.
Deckman
www.alscustomdecks.com
deckman22 is offline   Reply With Quote
Old 05-07-2009, 09:27 PM   #6
Trade: Remodel
I appreciate all of your imput. At the risk of being abused unmercilessly, what is the actual method to doing a torch down deck application?
Old 05-08-2009, 08:05 AM   #7
Trade: Remodel
I found a thread on my torch down question. Anybody else got anything on this DryJoist system? Thanks
Deck Advice VirginiaAvsFan Decks & Fencing 4 03-26-2009 05:45 PM
Sizing built up deck beams Unforgiven Decks & Fencing 17 09-08-2008 09:03 PM
Correect Deck ?'s Robert and others IHI Decks & Fencing 9 05-21-2008 09:45 PM
deck framing enough support? builditright Decks & Fencing 8 05-04-2008 07:50 AM
Dry lower deck stuff frostyfrost Decks & Fencing 12 05-19-2007 06:59 AM
