Does Anyone Nail PT Decking?
Old 10-01-2008, 12:30 PM   #1
72chevy4x4's Avatar
for a cheapo deck-does anyone nail (ringshank exterior nails)? I've always screwed PT decking, but sometimes when doing something where the HO doesn't have the funds, seems to me labor/time can be shaved to lower the project cost.
72chevy4x4 is offline
Old 10-01-2008, 12:46 PM   #2
Re: Does Anyone Nail PT Decking?
Screws are the time savers.
When we nailed, it was 16d galvanized
casing nails, counter sunk.
Three across on 5/4 X 6.
(Say labor intensive three times fast!)
Headed nails will always wind up
proud when the deck dries out.
Then they continue to "breathe"
out each time the decking shrinks
and swells.
neolitic is offline
Old 10-01-2008, 12:54 PM   #3
mickeyco's Avatar
Trade: Squirrel Handler
Not when you're using a nail gun, we use nails on front porches (historic homes) and on "cheap" new homes.
mickeyco is offline
Old 10-01-2008, 12:59 PM   #4
My point is, they aren't
barefoot-friendly over time
for a deck.
Never used headed nails for
that reason.
It's a principle damn it!
neolitic is offline
Old 10-01-2008, 02:25 PM   #5
Sean
SLSTech's Avatar
Mickey is right - nail guns = fast with less labor & material cost
Neolitic - has nailed it dead on though, those suckers are going to come up. It doesn't matter if the decking is glued down & you use ring shank nails
Glue & screw is the only way to go
I am kinda of curious if those combination screws that you install via an air nailer would work. I saw them in a McFeely's catalog, but I haven't tried them out. Anyone else try them?
SLSTech is online now
Old 10-01-2008, 05:26 PM   #6
topsail's trimcat
woodworkbykirk's Avatar
we hand nail em all (by hand.......), where im working now, if it were my choice, screws, sure its alot more expensive for them but they hold
i've worked with the system which fastens from below,kinda looks like a green corner bead, kinda annoying especially since we biscuit jointed all are ends and used pl. it was on a couple cedar decks but the homeowner wanted it and didnt care about$$ just how it looked
woodworkbykirk is online now
Old 10-01-2008, 06:07 PM   #7
PA woodbutcher's Avatar
I nailed 1 off last year. Guy calls and says I got 3 grand, give me the biggest deck you can for the front of a trailer. Stick gun and a board bender didn't take long to nail it off.
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline
Old 10-01-2008, 06:26 PM   #8
Professional Instigator
rbsremodeling's Avatar
I nail them off sometimes to with ring shank nails
rbsremodeling is offline
Old 10-01-2008, 06:38 PM   #9
ContractorTalk Flunkie
dayspring's Avatar
My personal preference is screws, However it is more expensive to install, both labor and material. I like to pre-drill my screw holes at the ends to keep the splitting down, depending on the moisture content of the wood, I have even pre-drilled them all. I always screw the railings and pickets
But, in the real world, not many of my clients want to pay the additional cost for screws and labor. But nail prices have went way up around here, $112.00 for a box of 16d ringshanks for my Paslode
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline
Old 10-01-2008, 06:41 PM   #10
John Hyatt
John Hyatt's Avatar
John agrees with the Mickey, in fact I use 2 1/2'' senco glav trim nails to fasten 5/4 pt decking along with construstion adhesive. Works for me no call backs so far. Its a econ choice but Hell I know guys that put down ipe that way. J.
John Hyatt is online now
Old 10-01-2008, 07:37 PM   #11
boman47k's Avatar
and swells.
Funny this should come up. I thought I have been noticing some nails in my deck starting to work up a little. Some of the 5/4 was aged, some was new. Seems to be mostly the new where I notice the nailheads being a little proud.
boman47k is offline
Old 10-01-2008, 07:55 PM   #12
Deck Designer/Builder
DecksEtc's Avatar
I only use screws. The only way to do it properly in my books. Nails will not hold as well and, as already discussed, will work themselves out of the wood.
I guess I;ve been lucky in that I've never had a customer insist on nails to save a few hundred bucks. For me, the cost difference between nails and screws is pretty insignificant. Also, using impact drivers doesn't really add that much more in labour costs. I just don't want my company name on a deck that has the deck boards nailed down.
JMHO...
DecksEtc is offline
Old 10-01-2008, 08:04 PM   #13
we seal all of our decks. We use the rink shank in our pasloades and they hold pretty well
1 box of pasloades or senco ring shank 58 bucks.
Labor Hours saved about 4-6
Don't think it is worth it
Old 10-01-2008, 08:21 PM   #14
dkillianjr's Avatar
I too prefer screws over nails, but I have done a lot of PT decks shooting down the flooring and I have to say I have not had one problem to this day, and some of them are pretty old. When I shoot the nails I make sure the pressure is up and the nails drive pretty far into the board, so when it drys the nails are still below the surface. And I have only used 3" ringshank galv. I have seen decks I did 6 years ago and the nails are still below the surface.
On a side note I never use nails in the PT rails, only screws. The nails loosen up over time and the rail becomes loose.
dkillianjr is online now
Old 10-01-2008, 08:31 PM   #15
kjung's Avatar
Trade: custom deck builder and the "gee, that looks dangerous....Kevin, get up there" guy
We have an unwritten rule that we will never use screws for top-out. Even if we lose a few bucks in the process, it saves the headache of having to go back later for repairs.
www.luxurydecksoftx.com
-Kevin
kjung is offline
Old 10-01-2008, 09:13 PM   #16
dayspring's Avatar
JMHO...
You are one I respect, a lot. But when it comes to working or not working, I'm gonna nail that sucker. Bottom Line. Not that I want to, but I have to make a certain dollar. I haven't had any call backs on anything I've nailed yet... yet. But I would certainly had rather it been screwed.
T.C.
Old 10-01-2008, 10:52 PM   #17
jarhead0531's Avatar
Trade: Electrician and Remodeler
I have to agree, if HO insists on nailing after I explain all the downsides I will nail away. Kinda nice to be able to use my coil gun at time anyway...
jarhead0531 is offline
Old 10-02-2008, 01:03 AM   #18
deckman22's Avatar
Trade: Deck Builder
For you guys that think screwing down decking is so much slower that nailing down with a gun you need to look into a standup screwgun, they are almost as fast as a nailgun.
Of course we all know screwing decking is better than nailing. However a 3" galv. ringshank nail shot out of nailgun that countersinks the nail it will hold. I've done tear offs where the 2x6 would break before the nails would pull out of the joist.
If you have a customer that is so tight that the minimal cost difference between screwing & nailing is going to decide whether you get the job or not then nail that sucker down.
Deckman
www.alscustomdecks.com
deckman22 is online now
Old 10-02-2008, 06:00 AM   #19
I have a quick drive stand up also. Used it once and wasn't crazy about how set the screws....too inconsistant with the 2 1/2" screws in the PT and the screws are galv. Screws work out to be about 2 cents a screw more than the greycoats that I've been using. It does work great for sheet rock though.
Old 10-02-2008, 01:03 PM   #20
Stone Mountain's Avatar
Trade: Outdoor contracting: fences and decks
On my own 10 year old deck, we have one level screwed down and one nailed down. Never had any problems. throughout the 80's there was no such thing as deck screws, so all we used were nails. Recently replaced a 24 year old deck I built originally, and the nails were all just fine.
Residential Deck Specialist: Vist our Website
www.fenceanddeck.ca
Stone Mountain is offline
Aurora decking BillD Decks & Fencing 5 10-03-2008 10:39 PM
Best Nail Punch Journeyman T Finish Carpentry 4 06-07-2008 11:12 PM
How much decking... ruskent Pool Construction & Enclosures 2 03-08-2007 08:38 AM
Powerwashing composite decking??? dougchips Pressure Washing 3 02-12-2007 12:58 PM
vinyl decking with hot tub nriddock Decks & Fencing 2 06-16-2006 02:10 PM
