Design For Deck?(crappy Picture Drawing Included).
Old 10-20-2007, 03:08 PM   #1
Mischman's Avatar
Trade: Hobby
I'm building a deck. For the support i was going to bolt one side to the house and then come over 2 feet and put a beam and then come 1 feet over from the other side and stick a beam. The beam would be 12 feet long(like the deck). Can i bolt a 2X12 to each side of a 4X4 post? Is that strong enough to have 2 of those running the length of the deck. I can stick a 4X4 every 3 feet so there will be 4 of them bolted to the 2X12's. I want to sandwich the 4X4's.
There is a solid concrete slab under part of where the deck will be. I was planning on using those square/triangular concrete posts holders.
Is this a good design for a deck. If the beams are strong enough, what size joists do i need? I will use joists hangers and 3" deck screw with the joists being 16" on center.
Crappy drawing, not to scale. The red things are beams and the black box is where the steps will go(will add extra support posts there).
Mischman is offline
Old 10-20-2007, 04:02 PM   #2
Catoctin Timber's Avatar
Trade: Carpentry/ Framing
Re: Design For Deck?(crappy Picture Drawing Included).
Where do you live? Most counties will no longer let you "sandwich" the post with a separated beam. They want two 2x whatevers nailed together and bearing ON the post. If your ledger attachment to the house is a good solid attatchment then the beam close to the house is unnecessary. Around here you could get away with a double 2 x 10 beam and 2 x 6 joists. But they also want you to use 6 x 6 post. SO.. two six by six posts with a double 2 x 12 beam would span your 12', then 8' 2x 6 joists.
Catoctin Timber is offline
Old 10-20-2007, 04:04 PM   #3
RobertCDF's Avatar
Trade: Custom deck builder
You should hire a profesional deck builder.
If you want I can design it but it costs money.
RobertCDF is offline
Old 10-20-2007, 04:15 PM   #4
Mischman's Avatar
Trade: Hobby
Private piece of land, around here i can do it myself, no problem with legalities. I already have the rough design, just need to know if the way im building it is strong enough.
Mischman is offline
Old 10-20-2007, 04:21 PM   #5
Mischman's Avatar
Trade: Hobby
What if i was to nail a
2X12 = 2X8 = piece of 1/2 ply wood = 2 X 8 = 2 X12
Then sit that over the 4X4 posts, bolt, screw, bracket where needed
Mischman is offline
Old 10-20-2007, 04:38 PM   #6
Remodeler
MinConst's Avatar
When building a deck using a ledger you need to have pilings dug below frost line. Setting your posts on top of a slab is not a good idea. If you change your design to NOT use a ledger and make it free standing it is OK. You don't mention where this is or what you plan on using (IE: "Plywood"??) so you must not really know what your doing. No offense intended just safety for you and whoever else stands on the deck.
Paul
Minichillo's Construction
Website
I will never leave you hanging!
MinConst is offline
Old 10-20-2007, 04:47 PM   #7
Mischman's Avatar
Trade: Hobby
I guess i will consult a pro around here.
Mischman is offline
Old 10-20-2007, 05:06 PM   #8
neolitic is offline
Old 10-20-2007, 05:13 PM   #9
RobertCDF's Avatar
I love it when people think that just because they dont have building codes to follow they can build things like idiots. Then they wonder why it falls over and kills someone.
I have seen this many times before "I dont need to follow code" Well that just dumb.... Guess what I never build to code, I think the code is lacking so I always build above code.
Old 10-20-2007, 05:45 PM   #10
concretemasonry's Avatar
Trade: Masonry consultant
Every house is resold at some time.
Even if it survives a DIY design and no code inspections, the ability and value will be less in the future.
If the area is ever under a code, you could have bigger problems because it could not be modified unless the entire deck is up to code. Codes are designed to protect the future owners also.
We just had a local deck go down with 15 people on it. Try to get your insurance company to back you up with a non-standard deck.
Dick
concretemasonry is offline
Old 10-20-2007, 05:50 PM   #11
Mischman's Avatar
Trade: Hobby
Doubt it would kill someone, if its unstable, ill invite you over for the first BBQ
Mischman is offline
Old 10-20-2007, 07:27 PM   #12
Why not do it right?
Fix-it's Avatar
Trade: General repairs
Lightbulb
There are many DIY sites on the web, Just do a search on how to build a deck and they will walk you thru step by step.
Good Luck
Fix-it is offline
Old 10-20-2007, 07:41 PM   #13
Charitable animal
Bone Saw's Avatar
Trade: decks
Doubt it would kill someone, if its unstable.
let us know how it goes
btw I'm thinking about getting into hip and knee replacements, already have the tools plus I've done gutters and siding for years, its not rocket science
Bone Saw is offline
Old 10-20-2007, 08:20 PM   #14
Deck Designer/Builder
DecksEtc's Avatar
Would you like to make a bet on that?
DecksEtc is offline
Old 10-20-2007, 08:54 PM   #15
It's all about the Avatar
woodmagman's Avatar
Trade: I have no face!
I am curious to why you are putting a beam 2 feet from a bolted on ledger. If I have not mis-read your design, that beam would be redundant and even create stress on the leger during weather changes.. not a good thing.
woodmagman is offline
Old 10-20-2007, 10:16 PM   #16
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
ProWallGuy is offline
Tile Design Software for floor and wall kaiofthesun Technology 6 07-11-2007 07:56 PM
Looking for some Residential Design work KentWhitten Help Wanted or Looking For Work 0 04-23-2007 10:45 PM
Marvin Venting Picture Window/ Useless? dougchips Windows, Siding and Doors 3 10-29-2006 10:59 PM
Picture post??? Kim1181 Flooring 2 03-09-2004 04:10 PM
