Dek-Drain Water Diversion System
Old 04-04-2008, 03:02 PM   #1
deckman22's Avatar
Trade: Deck Builder
Anyone have any experience with this product? A builder a do work for wants me to use this stuff & I'm leary to say the least. He did not say anything about using it before I started the job, then it just shows up on a Fed-Ex truck. I hate being a guinee pig on new products. T&G cedar going on under the joist. Here's their website......... www.dekdrain.com
Tia for any comments.
Deckman
www.alscustomdecks.com
deckman22 is offline
Old 04-04-2008, 04:15 PM   #2
Composite Decking Mfr
MartyCD's Avatar
Trade: Manufacturer of Composite Decking, LEED AP
Re: Dek-Drain Water Diversion System
Al,
I haven't worked with that one personally but it is very similar to the Rain Escape one that we push. It's all fairly simple and straightforward, my only caveat is to be careful walking on the joists while installing the decking - the plastic can be slippery. Rain Escape includes a funnel for the troughs to discharge into but this system doesn't need any caulk or tape across the top of the joists.
Marty
MartyCD is offline
Old 04-04-2008, 06:15 PM   #3
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
I've looked at it, but haven't installed it yet.
I like that it's integrated into the next version of Deck Tools, and I like the "no caulk" bit, but I don't like the fact that I've got to install something under it to finish things off.
Just my thoughts...
~Matt
BreyerConstruct is offline
Old 04-04-2008, 11:18 PM   #4
buckeyeso2's Avatar
Trade: carpentry
i used it just recently for two decks and it worked fine. It is kind of a pain if the house has brick on it, but if it has siding it would go on fairly quickly.(difficult to flash the dek-drain properly against the brick) The thing that impressed me the most was the helpfullness of the company. We were using it on a million dollar house and I was very tentative about "practicing" on a house of this caliber. If you have any questions, just call the company. I talked to the inventor of the product several times and he was extremely helpful.
These two decks have held up to a lot of precipitation in the last couple of months, and no leaks yet!!!
good luck.
buckeyeso2 is offline
Old 04-08-2008, 02:37 AM   #5
deckman22's Avatar
Trade: Deck Builder
Well I'm glad to hear positive feedback. I told the guy that I'm not going to be responseable if the stuff leaks a couple of years down the road, but I would do my best with it & test it before installing decking. Using Timbertech with their new hidden fasteners so I figure I'd better throw some boards down before installing then run the hose over it & see how well the stuff works. Cedar lap & gap siding that needed exisiting flashing replaced anyway so I'll pull bottom row off to install new flashing.
Marty, I had the same thought especially since it's about 20' above grade. No falls in the 35 years I've doing this stuff so no sense starting now.
Deckman
Old 04-08-2008, 02:08 PM   #6
MartyCD's Avatar
That's good Al. Be safe.
The hose test is a good idea, especially test anywhere you have taped around posts, or had to do anything fancy because of bridging, etc. Don't want to ruin that nice T&G cedar ceiling!
A thought, if it's of interest to this builder, is that you can get a LEED point for collecting the rainwater from these systems for garden usage.
Marty
MartyCD is offline
Old 04-08-2008, 02:30 PM   #7
constrkings's Avatar
Trade: Home Improvement Contractor
Going to install it for the first time next week -- let me know if you run across any issues I should be aware of. The HO wants it simply because he can install whatever ceiling he wants below it. It is going on a mahogany and cedar deck so he wants the ceiling to look great also and most of the underdecking systems out there won't look as good with this deck so . . .
constrkings is offline
Old 04-08-2008, 09:49 PM   #8
deckman22's Avatar
Trade: Deck Builder
Looks like we'll be doing it at about the same time. You might even get to it before me as I still have 800 sq. ft. of framing to go along with some big azz 6x6's going from grade to 1st level deck, 2nd level deck, then to the beam holding house roof & a zillian footings dug/rebar grids/concrete poured. At least the builder is springing for a pump truck.
Deckman
Old 04-08-2008, 10:06 PM   #9
This is going on a deck that I built last year and now they decided they want this so I am going to be using the underside not the topside but I will keep you informed.
Old 04-10-2008, 12:14 PM   #10
novicepro's Avatar
Trade: general contracting
do they make something like that but in aluminum or metal?
novicepro is offline
Old 04-10-2008, 12:41 PM   #11
BuiltByMAC's Avatar
Trade: Construction
Deckman, you gonna start a thread here w/ pics of this big ass project? I'd love to see 'em!
Mac
BuiltByMAC is offline
Old 04-10-2008, 07:10 PM   #12
I like Green things
WarnerConstInc.'s Avatar
used dry-deck from timber tech. I was pretty good except that when it showed up I had half the deck framed 12 o.c. and it was for 16" o.c. that sucked
WarnerConstInc. is offline
Old 04-12-2008, 02:03 AM   #13
deckman22's Avatar
Trade: Deck Builder
Mac
I hope to get to that soon. I set up a photobucket account so I can an online album of newer stuff. It'll make it easier for my web guy to do some updating for me since all the pics on my site are 10 years old. Only problem is I'm an old fart that is challenged with all the new technoligy. I have to have my 32 year old daughter show me how to do it.
While I may be proud of some of these bigger/fancier/new product projects I do nowadays I long for those 10x20 cedar decks I use to get so many of. My wallet longs for them too cause I know I make more $ on the simple plain jane decks.
Deckman
Old 06-30-2010, 11:02 AM   #14
dangrs158's Avatar
Trade: Builder
Isn't Dek Drain just rubber roofing cut into tapered strips?
dangrs158 is offline
Old 06-30-2010, 10:13 PM   #15
DecksEtc's Avatar
You don't need to ask the same question 3 times...
DecksEtc is offline
Old 06-30-2010, 11:04 PM   #16
dangrs158's Avatar
Trade: Builder
I asked the question once myself and then found a couple of threads already on the subject. Some threads can be quite dead so I thought I would ask on the existing threads.
I didn't think it would be that BIG of a deal.
Old 07-01-2010, 07:30 AM   #17
DecksEtc's Avatar
I was just offering a friendly suggestion.
It annoys people when someone asks the exact same question in different threads. Makes you look like a non-pro too.
But go ahead and keep up the attitude while you're at it...
DecksEtc is offline
Old 07-01-2010, 07:46 AM   #18
deckman22's Avatar
Trade: Deck Builder
It did not look like roofing rubber to me, however I'm not a roofer so I don't know, not torch down stuff for sure.
I no longer work for that GC so I don't know if it leaks or not. I did not like using an untested product on a high end project & got in trouble with the GC for letting my opinions known. Also they want you to pull up a few deck boards every year hose down your trenches to clear debris to keep warranty in place. I know darn well most HOer's will not do that.
I would not use it again. There's better ways to get the same result.
Deckman
Old 07-01-2010, 01:07 PM   #19
dangrs158's Avatar
Trade: Builder
Removing boards doesn't work with the TimberTech hidden fasteners. Thanks for the info. I'll have to check that out. My homeowner wanted to keep dry but I don't want to deal with warrantee issues.
Old 07-01-2010, 08:38 PM   #20
RobertCDF's Avatar
Trade: Custom deck builder
Start digging into all their testing data and you will find out its 45 mil EPDM rubber... attainable at most roofing supply houses for less than $1 sq ft... And they want what??? $5 sq ft?
RobertCDF is offline
Water heater smell. silvertree Plumbing 6 03-29-2008 11:12 PM
Is it safe to drink water from Hot water Heater? robertc65 Plumbing 14 02-04-2007 12:11 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
