Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Decks & Fencing
Old 10-02-2009, 10:20 AM   #1
decking on 24" joists
currently there is 2x6 boards on 24" spaced joists. I'm guessing 5/4 composite wouldn't work b/c of the span-can anyone confirm? if not, does anyone make a composite rated at 24" joist spacing?
72chevy4x4 is offline   Reply With Quote
Old 10-02-2009, 10:25 AM   #2
Trade: GC, Remodeling
Yeah, I don't think that will work with 5/4. You could go with Correct Deck or Cross Timbers, that might work. Maybe the TimberTech T&G would work, seemed pretty stiff last time I used it.
AJAX is offline   Reply With Quote
Old 10-02-2009, 10:44 AM   #3
genecarp's Avatar
Dont know for sure, check with the manufactureres websites, any composite that can be run at a 45 with 16" centers might handle the 24". Another thought would be to sell them on droping in new joists inbetween, that would make a nice solid deck. G
genecarp is online now   Reply With Quote
Old 10-02-2009, 10:47 AM   #4
Maybe "Correct Dock."
Check their website, or PM Marty.
neolitic is online now   Reply With Quote
Old 10-02-2009, 11:29 AM   #5
redwood's Avatar
Trade: Carpentry Contractor
It's not a composite, but 5/4 ipe will span 24" O.C.
Mark
Los Gatos, CA
www.creative-redwood-designs.com
redwood is offline   Reply With Quote
Old 10-02-2009, 11:33 AM   #6
Probably cheaper, certainly
faster and less PITA than dropping
to 12"oc.
Old 10-02-2009, 12:03 PM   #7
pro
Trade: ...
tt floorizon, moisture shield engineered, ceartainly ipe,
Custom Decks & Carpentry LLC.
play
more play
raped ape
Originally Posted by nilscraft View Post
I'm doing a bid for a homeowners ass
Bone Saw is online now   Reply With Quote
Old 10-02-2009, 12:34 PM   #8
Fine Deckbuilder
Trade: Deck business
Ecoboard makes a composite that can span up to 8' if you want, depending on the thickness (up to 8" thick!!!). You can also order it reinforced. I have samples and it is used alot for commercial docks.
www.ecoboard.org
Clemens is offline   Reply With Quote
Old 10-02-2009, 12:50 PM   #9
Sean
SLSTech's Avatar
The higher end GAF product will (sorry I can't recall the name) & Correct Dock are the only two I can recall at the moment
SLSTech is offline   Reply With Quote
Old 10-02-2009, 03:05 PM   #10
Trade: Home Renovations
GeoDeck boards rated 24" & 30" OC
GeoDeck has an S4S and T&G board that are ICC rated 24" on center. And their 2x8 commercial board is rated for 30" on center.
KevinKelly is offline   Reply With Quote
Old 10-02-2009, 03:08 PM   #11
http://www.contractortalk.com/f50/geo-deck-61285/
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline   Reply With Quote
Old 10-02-2009, 05:07 PM   #12
RobertCDF's Avatar
Trade: Custom deck builder
Correct Deck CX will span 24" O.C. and we have installed (per homeowners request) at 45 degree angle @ 16" O.C. and it was fine. So its about the same as 24" o.c.
Crosstimbers is rated to span 24" O.C. but it sags in heat on 16" O.C. so that would be a dumb choice.
RobertCDF is offline   Reply With Quote
Old 10-02-2009, 06:00 PM   #13
John Hyatt
John Hyatt's Avatar
Trade: out door areas, decks,spa room additions,fire pits,custom design
geo deck... I cant belive it J.
John Hyatt is online now   Reply With Quote
Old 10-02-2009, 06:09 PM   #14
loneframer's Avatar
Trade: residential framing/general carpentry
I used Timbertech T&G about 12 years ago on a front porch deck. It was rated to span 2' centers if memory serves me. I believe it is the Floorizon line.
" It's a Jersey thing, you wouldn't understand"
loneframer is offline   Reply With Quote
Old 10-03-2009, 07:27 AM   #15
LOTS of great info-thanks for the leads on product lines.
I Joists roofing/blocking? ApgarNJ Framing 22 01-02-2009 11:13 PM
I joists for roofing, questions ApgarNJ Framing 18 11-11-2008 09:38 PM
Replacing joists in rowhouse Philly Dude Framing 3 10-16-2008 05:24 PM
Dealing with Floor Joists dcapone Low Voltage 0 08-18-2008 01:45 AM
Framing Roof Joists for Addition when top Plate is not Level personalt Framing 3 07-20-2007 05:52 AM
