Deck Too Low For Notched Post And Beam Support?
Old 11-01-2009, 12:13 PM   #1
DaveNJ's Avatar
Trade: Landscape design
For a low-profile (but not ground level) deck, what's the shortest I can go with a notched 6x6 post? With an overall grade to deck surface height of 22", using a typical post and beam construction eats up my post height quickly when I factor in pier rising 2" above grade, a 1" post standoff, doubled 2x10 beam, 2x8 joist and 5/4 decking.
As such, I'm left with a measly 2.75" of post surface to support the beam. Seems like so little wood between fresh cuts is a recipe for disaster. Barely makes 6" clearance between beam and soil, too.
I suppose I could go without the cantilevered beam and go with a flush header (where beams and joists are flush at the top. Never did one of those, but it would seem the post centers would really need to be precise (no fudge factor).
Another thought I had was doing a beam to pier design, where the beams are strapped to the concrete pier tops (no post), but using larger lumber for the beams to get the height. No easy way to adjust for level, though if the piers aren't perfect.
Appreciate any advice. Thanks.
DaveNJ is offline
Old 11-01-2009, 12:24 PM   #2
framer
steves's Avatar
Trade: framing
Re: Deck Too Low For Notched Post And Beam Support?
If you use the same set up you drew but use a 2x12 beam ,you still have 3/4" for shimming/leveling
And use a 4x4 post base
steves is offline
Old 11-01-2009, 12:28 PM   #3
Trailer park boy
shanekw1's Avatar
I would pour the piers 3.75" higher, and set the beam in saddles on the piers.
shanekw1 is offline
Old 11-01-2009, 12:29 PM   #4
jhark123's Avatar
My lumber yard has brackets that can be adjusted for height 0-6" (think HDG threaded rod and an adjustable nut to give clearance). That being said I wouldn't worry about the short post, I would just soak the entire piece in a bucket of end treat solution for as long as possible.
jhark123 is offline
Old 11-01-2009, 12:32 PM   #5
Illusion of Perfection
CookeCarpentry's Avatar
x2 with Shane's advice.
And you can get the piers pretty darn close to perfect taking your time with measurements and either a laser level or string line.
CookeCarpentry is offline
Old 11-01-2009, 12:34 PM   #6
Money Changer
bert0168's Avatar
Trade: Residential Remodeling
That would be my suggestion.
Oh and also, maybe an introduction as to who you are, where you are, etc.
bert0168 is offline
Old 11-01-2009, 12:39 PM   #7
Trailer park boy
shanekw1's Avatar
This would be good advice.
I poured all these in place before I stuck the beam in there.
shanekw1 is offline
Old 11-01-2009, 01:07 PM   #8
genecarp's Avatar
ME thinks a HO was just told how to deal with his deckGMOD,,,FOC
genecarp is offline
Old 11-01-2009, 01:16 PM   #9
doh!
Old 11-01-2009, 01:27 PM   #10
Trailer park boy
shanekw1's Avatar
I blame all the candy for breakfast.
shanekw1 is offline
Old 11-01-2009, 02:39 PM   #11
Tom Struble's Avatar
Trade: siding
he has done this alreadyhttp://www.contractortalk.com/f44/hello-n-j-67011/
Tom Struble is offline
Old 11-01-2009, 05:04 PM   #12
stp57's Avatar
Trade: carpenter/ handyman
I would make those mini posts from composite glued together for thickness. It would certainly hold up better than wood.
Steve
stp57 is offline
Old 11-01-2009, 07:33 PM   #13
DaveNJ's Avatar
I had thought of that, but with no cantilever, I didn't want to end up with this (apologies to original poster -- see below). Can't cover that with cladding or lattice -- maybe a shrub.
DaveNJ is offline
Old 11-01-2009, 08:38 PM   #14
Trade: siding
hey i know that deck
Old 11-01-2009, 08:47 PM   #15
PA woodbutcher's Avatar
Originally Posted by tomstruble View Post
2 different Daves....DaveNJ adn Dave67
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline
Old 11-01-2009, 08:55 PM   #16
Trade: siding
ah ty pa my bad
Old 11-01-2009, 09:01 PM   #17
I like Green things
WarnerConstInc.'s Avatar
Me too!!
I still don't know the reason for that but, it does look a little funny.
Originally Posted by Leo G View Post
Thanks for that tidbit of information Darcy.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana
Warner Remodeling Facebook
WarnerConstInc. is offline
Old 11-01-2009, 09:04 PM   #18
Trade: siding
i did the siding on the house
thats my debris strewn about in the background
Old 11-01-2009, 09:14 PM   #19
carpentershane's Avatar
Trade: general carpenter
http://www.strongtie.com/products/co...4T.asp#gallery
Someone already alluded to this I think, but this might be a decent solution to your conundrum.
carpentershane is offline
Old 11-01-2009, 09:18 PM   #20
Trade: siding
conundrumvery good Shane thats gotta be worth 25 points
sheetrock vs. plaster in bathroom post and beam ceiling Bunc General Discussion 2 03-16-2009 09:34 AM
Another Post and Beam Custom from Lindal wallmaxx Framing 0 12-05-2008 03:26 AM
Deck Design Timberland Decks & Fencing 5 02-23-2007 09:50 AM
Beam Support Issue HandyAl General Discussion 5 06-15-2006 11:11 AM
deck beam sizing and post spacing? diyerforever Decks & Fencing 5 05-10-2006 10:58 PM
