Deck With Stairs At 45 Degrees At Corner
Old 04-14-2008, 07:10 PM   #1
Dad'll do it's Avatar
Trade: Home improvement contractor in CT. License # HIC.0614385
Building a 16 X 15 foot deck, custoner wants steps to cut off the corner of deck at 45* stating 8' from house and 9'from right hand side. How do I lay out the piers to feed the joist across? If the piers are parallel to the house and Ledger, and the joist are perpendicular the house I end up with 5 feet of joist overhang right in the middle at the top of the steps. I especially don't like that since I'll be using 5/4 for the decking. If I run the piers at a 45* angle to the house and parallel to the steps I end up with a huge overhang from the house to the steps and in the opposite corner. I think my only option is to run the piers parallel to the house and put in a short 7 foot pier at a 45* angle at the start of the steps. Any other suggestion or does that seem like the way to go?
Dad'll do it
Dad'll do it is offline
Old 04-14-2008, 09:04 PM   #2
Remodeling Professionals
buildenterprise's Avatar
Re: Deck With Stairs At 45 Degrees At Corner
I am so confused right now. A drawing or pic would help this work-weary brain a little...
buildenterprise is offline
Old 04-14-2008, 09:53 PM   #3
Chris G's Avatar
Trade: Porch and Deck Builder
Thanks for braking the ice. I too have no idea what he is talking about.
"Neek...Neek...yoo-a-moronna Neek. Getta-da-fookin-a-jacka-ham!"
http://www.vicporch.ca
Chris G is offline
Old 04-14-2008, 10:08 PM   #4
BuiltByMAC's Avatar
Trade: Construction
Check out diagram below - just make sure footings where angled beam ends terminate are large enough to hold two sets of posts - one for the parallel beam and one for the angled beam.
This keeps joist cantilever to less than 2' and gives plenty of stability for staircase.
I won't make any comments on the size (width) of the staircase in relation to the rest of the deck, although I will say you will probably need a handrail running down the center line of the stairs because they are so wide.
Mac
BuiltByMAC is offline
Old 04-14-2008, 11:12 PM   #5
Royal-T's Avatar
Have you ever built a deck? If you can read a square and find a 45 degree angle this project should not be a problem. Everything for the stairs will come off of your bandboard. Justa make sure that you have the footers needed for the stairs.
Royal-T is offline
Old 04-14-2008, 11:21 PM   #6
Stone Mountain's Avatar
Trade: Outdoor contracting: fences and decks
Forgive me for being cynical. This guy is already in busiiness, has a licence, and can't figure out a simple thing like how to place footings on a simple deck?
don't they have to pass a test or something to get a licence?
Residential Deck Specialist: Vist our Website
www.fenceanddeck.ca
Stone Mountain is offline
Old 04-15-2008, 01:18 AM   #7
redwood's Avatar
Trade: Carpentry Contractor
Mac, pat yourself on the back. You solved the mystery of the ages.
By the way, that beam at 45 deg., might require a pier in the middle, especially if you are hanging steps off of the fascia.
Mark
Los Gatos, CA
www.creative-redwood-designs.com
redwood is online now
Old 04-15-2008, 01:56 AM   #8
BuiltByMAC's Avatar
Trade: Construction
I don't wanna jump on EVERY noob that walks through the door. I'm not a xenophobe, I just can't stand the "How much do I charge" and the "What's the going rate" crap - this guy had a legitimate "How do I do this" question. Bummer that it was his FIRST post but maybe he'll stick around and become a positive addition to the site.
(By the way, welcome to the site DDI. Sorry, just can't call ya Dad)
I sure as hell don't know everything, I'm not expecting anyone else to either. I learn lots of stuff from this site...
As to posting up in the middle of the angled beam span, I figure if my diagram gets him on the right track, he can work up the spans/beam sizes for his application. I don't know the deck height, number of beams, joist sizes, anything....
Mac
Old 04-15-2008, 01:58 AM   #9
BuiltByMAC's Avatar
Trade: Construction
you gotta be kiddin' me - when was the last time a contractor license test had ANYTHING to do with being able to build something?
Mac
Old 04-15-2008, 10:00 AM   #10
Mac
Around here the test is
can you sign a check!
neolitic is offline
Old 04-15-2008, 10:02 AM   #11
Mac, Thanks for the response. Your drawing was consistant with my solution. I appreciate your willingness to take the time to respond
Dad'll do it
Old 04-22-2008, 08:58 PM   #12
blindhammer's Avatar
Trade: carpenter
ease up on this guy. his first post and you guys are all jumping his ****.
what's wrong with some helpful advice instead?
blindhammer is offline
Old 04-22-2008, 09:49 PM   #13
cmansmith's Avatar
Trade: Framer, Carpenter
Thats a group of framers for ya...
cmansmith is offline
24x24 Deck amanandhisvan Decks & Fencing 63 09-24-2008 11:59 PM
Waterproofing a deck - looking for ideas Laketahoedan Carpentry 12 04-03-2008 06:54 PM
Building Flaired/Fanned Stairs next to Square Stairs RKDO Decks & Fencing 5 11-30-2007 03:32 PM
Ipe Deck rjordan392 Decks & Fencing 19 10-10-2007 10:58 PM
