Deck Sealing Recomendation
Old 07-13-2009, 10:08 PM   #1
TRISTAN's Avatar
Trade: REMODELER
Does anyone have any info or experiance using a deck finish called "one time". The manufactor claims it has a 7 year life expectancy on cedar decking. Thanks
TRISTAN is offline
Old 07-13-2009, 10:12 PM   #2
katoman's Avatar
Trade: carpenter
Re: Deck Sealing Recomendation
Never heard of it. Check out Para Raincoat, it contains wax, the best sealer for wood. And you can recoat without sanding/scraping anything!!!
katoman is offline
Old 07-15-2009, 09:50 AM   #3
deckman22's Avatar
Trade: Deck Builder
I've heard about it, but have not seen it in use. No one sells it around here & it is very expensive to order & have shipped.
I seem to remember some folks on another forum saying it worked well. However I doubt anything would last 7 years with only one coat here.
Deckman
www.alscustomdecks.com
deckman22 is offline
Old 07-15-2009, 10:05 AM   #4
Professional Builder
sirlopez's Avatar
Trade: Deck and Dock Construction
I'm not familiar with the product, but if they are quoting 7 years, it must be pretty good stuff. I agree with Deckman that we won't be able to see a 7 year lifespan here in FL, but still, if it got us 3 years, that would be better than anything else we've used to date. Tristan, let us know if you use "one time" and your thoughts on the application.
**For the finest in composite outdoor furniture, check out Deccessories.**
http://www.deccessories.com
sirlopez is offline
Old 07-15-2009, 09:41 PM   #5
John Hyatt
John Hyatt's Avatar
Man we have been thru the one time guys over and over at several sites.
They will not give up its always the same,someone gets on and asks about it, not a rep of course,and on and on it goes.
If you read the fine print, you have to wonder just what exactley do that stuff do. And what is the warenty good for, and what will it protect against, and how did they come up with One Time, and what is the 7 years all about, and.......well you get the idea. The more you dig the more you come up with the same as cleaning out the sepict tank. J.
John Hyatt is offline
Old 07-15-2009, 10:05 PM   #6
DeanV's Avatar
Trade: Painter
From what I have read, wax is a bad idea and usually as sign of a cheaper sealer.
DeanV is offline
Old 07-15-2009, 10:13 PM   #7
katoman's Avatar
Trade: carpenter
Wax is what is used to seal hardwood lumber coming from South America and other places. It is considered the best way to seal lumber, achieving about 90% seal ability. Para of course also contains linseed oil and other additives for uv protection etc.
I did a log building with it about 9 yrs ago, walls. The ownership has changed hands about three times, and no one has maintained it. I drive past this building every day and it still looks pretty good. Faded, but no failure in the product - no peeling or anything, as it soaks in, not a surface stain.
katoman is offline
Old 07-15-2009, 10:23 PM   #8
deckman22's Avatar
Trade: Deck Builder
We've all heard some of the wild claims these folks make. Funny, the sales girl over @ one of the local ipe suppliers was trying to pitch some new sealer to me. It's called Wood Protect. They claim it has UV inhibitors in a clear sealer, waterbased, non toxic, zero VOC. The thing that really struck me was she said it will reduce the surface temp. of the wood 7-10%.
I gotta see this stuff, asked for some sample cans so I could try it out on some scraps. I want to see how this new sealer will hold up in a summer of 100 degree days.
I googled it up & found their site, www.kinlochusa.com , click on products then on wood protect. All those claims she mentioned were right there on their site, except the part about reducing the temps 7-10%. Says it's nanotechnology.
I'll report the results of my test pieces @ the end of summer, that's about halloween around here.
Deckman
Last edited by deckman22; 07-15-2009 at 10:26 PM. Reason: correct the website link
Old 07-16-2009, 05:16 PM   #9
naturalwood's Avatar
Trade: decking
I've seen the One Time, one of the companies doing thermally modified wood is using it as a factory coat. Have some concerns as what I saw it did not appear to be a pentrating finish. If not then it may peel off after time. I have a sample of the Kinross, pretty expensive but if it works... It is absolutely clear. I did a foot long piece in the garage but when I went to put it outside, could not determine which side I had applied it. Very Very clear.
naturalwood is offline
Old 07-21-2009, 11:54 AM   #10
TRISTAN's Avatar
Trade: REMODELER
Sorry for the delay getting back, my comp. Went down. I wound up using the one time product, but it has it's drawbacks. First -all of the old finish has to be removed, so that the new stuff can penetrate. This meant an initial cleaning with tsp and bleach. This was followed by a chemical stripping of the old remaining cabot stain that was still left. This was followed with a acid neutralizer to return the cedar to its natural color. All of this scrubbing left the decking with a fuzzy coating in spots that required some sanding. So much for the prep. The sealing requires 48 hours of dry time prior to application followed by 48 hours of sunshine to cure the product. Needless to say that's hard to come by here in new england. I applied the product yesterday, 2 hours to coat 350 sq. Ft. With a pad applicator followed with brush out to cover plank edges-two man job . Sunshine lasted till end of day, then rain overnight followed by hard rain today. I tarped over the deck at days end to protect the as yet uncured product. Hoping for some sun tomorrow. I'll post further info as it developes.
TRISTAN is offline
Old 07-21-2009, 07:53 PM   #11
John Hyatt
John Hyatt's Avatar
WTF is this stuff good for. Like what do it do??? J.
Old 07-22-2009, 10:17 PM   #12
FarView's Avatar
Trade: Home Improvement
I used it on 2 different pressure treated decks I built around 2yrs ago. I just saw one of them last May, and it still looks like I just sealed it (and it gets a LOT of NY sun exposure).
I typically have sprayed deck sealants in the past, but this stuff is pretty THICK, and it would have required thinning in order to spray it. For the railing/stair parts, I tried a lambs wool staining "mit", but had much better luck using a car wash mit instead. Using one of those awesome "Paint pals" in one hand, I dipped the mit and gently caressed every inch of the deck components with the mit. This took some time, but really wasn't all that bad once you get going. I believe I used a thick nap roller for the decking, which sped things up.
Anyway, yes- it does seem expensive...but if it lasts 7yrs as the manufacturer claims, it's worth it, IMO. And it goes REAL far. I used under 2 gal for each deck, and they were each 12 x 16, at least 6ft high with staircases (closed risers).
I was pretty impressed with the quality of the stuff, but "time will tell" just how good it really is, I guess.
(BTW, I am in no way affiliated with Bond Distributing)
FarView is offline
Old 07-22-2009, 10:44 PM   #13
John Hyatt
John Hyatt's Avatar
One more time....What does it do. What is the warenty good for and against what. No real advantage reading the info on line it says nothing as well. J.
Old 07-22-2009, 10:52 PM   #14
FarView's Avatar
From their site:
One TIME® wood protector is a proprietary acrylate resin blend that contains no water, wax or solvents. The resins are cured by natural sunlight and become part of the cellular structure of the wood. One TIME® contains 100 percent solids, where conventional treatments usually contain only 5-20 percent solids. Conventional treatments typically contain water and/or solvents that can cause the wood's cellular structure to swell, then shrink as it dries, causing cracking. Water and solvents also dissipate quickly into the air. And because most wood treatments build up on the surface and eventually wash away, it becomes necessary to reseal the wood every one-to-two years.
Because One TIME® penetrates and is cured into the wood, it provides protection for seven years. As a result, Bond Distributing offers a 7-year warranty on One TIME®, compared to the one-to-two year warranties offered with conventional treatments.
FarView is offline
Old 07-23-2009, 10:41 PM   #15
TRISTAN's Avatar
Trade: REMODELER
After a full day of hard rain, we pulled the tarp off the deck, and found some water spotting. After the sun beat onthe deck for most of the day, just about all of ths spots were gone. This stuff does not dry as conventional sealers do. It really needs sunshine to cure. I wouldn't recomend for a north facing deck, it'd take forever to cure. The customer is holding off two more days to allow full cure before moving table and chairs back on.
TRISTAN is offline
Old 07-23-2009, 10:51 PM   #16
FarView's Avatar
It shouldn't take more than 48hrs to cure, even if it never sees direct sunlight. As long as it is "outdoors" where there are still UV rays, it will cure...it's just that direct sunlight will cure it faster. It does not need "direct sunlight" to cure, however...
I wonder if a UV curing "lamp" would speed up the process for the shady areas??
Anyway- it's always best to try and use this when there is NO rain in the forecast for a couple days!
FarView is offline
Old 07-24-2009, 08:09 AM   #17
John Hyatt
John Hyatt's Avatar
But what does it protect against, in other words how do you know if it fails. Ive already read that. All I can gain is it gets into the wood.
My projects require uv,water,and mold/mildew protection TWP has all of that and its pretty easy to figure out when its time for a recoat.
So why is it one time or 7 years and what does it do. J.
Old 07-24-2009, 09:55 AM   #18
FarView's Avatar
Water and UV radiation.
in other words how do you know if it fails. .
If you see the water does not bead up and/or the wood is checking, etc- that would mean it failed. Otherwise, it's still protecting.
About-
FAQS-
Their toll free number in case you still have any questions (they were very helpful, knowledgeable and friendly on the phone when I called with my questions/concerns):
866 663 8463
Again- I am not affiliated with Bond, nor do I have any financial reason to "promote" their product. I simply have used it on 2 decks, and was quite impressed. YMMV.
FarView is offline
Old 07-25-2009, 01:31 PM   #19
Pro Deck Guy
Ahren's Avatar
Trade: Jim's free government helper
They call it "One Time", because that's how many times you'll use it in your career. With the pain in the ass of applying it, with the pain in the ass cure time, along with the pain in the ass cost, not to mention it's seriously doubtful that the stuff will last 7 years, you'll try it "one time" and vow "never again".
Ahren is offline
The Following User Says Thank You to Ahren For This Useful Post:
sbcontracting (06-29-2011)
Old 07-25-2009, 03:42 PM   #20
John Hyatt
John Hyatt's Avatar
John could not agree more with the Ahren. J.
Whats The most expensive deck you've built deck king Decks & Fencing 96 07-10-2010 09:02 PM
24x24 Deck amanandhisvan Decks & Fencing 63 09-24-2008 11:59 PM
Looking for deck and fence builder - Chicago west suburb Green_2 Help Wanted or Looking For Work 0 09-07-2008 06:34 AM
Deck Sealing youngblood88 Painting & Finish Work 5 10-30-2007 02:47 PM
