Deck Screws Vs Joist Nails
Old 11-19-2008, 10:02 PM   #81
basswood's Avatar
Trade: trim carpenter
Re: Deck Screws Vs Joist Nails
The 16" Makita Saw is quite the tool. It certainly commands respect.
Timber framers have all the coolest tools.
Sometime soon, I am visiting a timber frame a friend put up here recently. Looking forward to seeing it.
Later,
Bass
basswood is offline
Old 11-19-2008, 10:29 PM   #82
reveivl's Avatar
Trade: Renovations
Wanna take some pictures? I'll swap ya!
reveivl is offline
Old 11-21-2008, 08:41 AM   #83
basswood's Avatar
Originally Posted by Alwaysconfusd11 View Post
Wearing gloves while operating power tools is a big no no
Single digit temps this morning... wind chill -6*F.
Dressing up like an Eskimo.
basswood is offline
Old 11-21-2008, 08:10 PM   #84
subybohn's Avatar
Trade: AmeriCorp State Alumni
You guys do some defiantly quality craftsmanship. My hat is off to those who still do things the "old timer’s ways" - with or without today's tools - They must have known what they were doing, for their true craftsmanship has stood the test of time...
I'd like to see you start a discussion sharing these old ways -- just as you did in this discussion....that was impressive to read.
But sometimes you don't have the space under the joists/header board for a ledger board -- and a double header to nail the joists off of (using 10dx3" into the headers isn't always feasible in smaller applications.
What it neat, is all the options -- there isn't just one way of doing solutions.
And the more options, the more possibilities.
BUT not everyone is equip or has the skill it takes to design and build large decks or special builds. And not everyone can afford you talents.
Volunteers do the best they can....when the skilled craft are to busy trying to get their own work done...and volunteers usually only tackle the "simple" small deck designs.
So - this is for those truly seeking information and not trying to change a person's mastered trade.
File Type: pdf USP Opt Nails for Face Mount Hangers.pdf (92.6 KB, 114 views)
subybohn is offline
Old 11-21-2008, 08:17 PM   #85
jarhead0531's Avatar
Trade: Electrician and Remodeler
Christ almighty you just wouldn't give up until you found something that said it was okay to use screws. Then use screws already, just don't do it on any deck I'll ever be on, and quit asking what the right fastner to use is, then don't listen.
jarhead0531 is offline
Old 11-21-2008, 09:17 PM   #86
Deck Designer/Builder
DecksEtc's Avatar
EXACTLY!
subybohn, go ahead and use whatever fastener you want for crying out loud. Use interior flooring screws for all I/we care. You live far enough away from me that there is virtually no chance in hell I'll ever step foot on one of your designs/builds. As you can see, or maybe you can't, we've given you many, many reasons why we don't use screws for joist hangers. Afterall, what do a bunch of dumb contractors, most of which have probably been building longer than you've been alive, know anyway.
Just do us all a favour and stop posting your "proof" because it's going to fall on deaf ears. You're not going to convince any reputable deck contractor that screws are "better" than the proper nails for joist hangers.
Give it a rest already, would you?
P.S. How many decks have you built where a permit was pulled?
DecksEtc is offline
Old 06-07-2009, 11:12 AM   #87
melkahn3669's Avatar
Trade: fasteners
Originally Posted by subybohn View Post
I know this is a can of worms -- and I have read the postings from Nails vs. screws...
But I have a problem.... Simpson Strong-Ties LUS28Z face mounted joist hangers...
According to their web-site, this hanger can really carry a good load, as long as it's installed properly.
I've noticed that if the Hanger has an "S" in its name, it's a hanger in double shear and their web-site specifically says I cannot use 10d x 1-1/2" Joist nails.
AND if I use a 10d x 1-1/2 joist nail in the header, I have to multiply the load by .65 (or I have to reduce the load it can carry by 35%).
To maximize the load these hangers can carry, I have to install an equivalent fastener to a 10d common.
I am only using the hangers along the house and with the header lagged into the rim board; I have the needed 3" for the 10d length....for both the header 10d nail and the joist 10d nail.
However -- their specs says the equivalent to a 10d common is 0.148 x 3"
I am using treated wood -- and the hangers are not stainless steal -- so I cannot use stainless steal fasteners.
I can find 10d hot-dipped galvanized in a Box Nail, but not a 10d hot-dipped common nail.
If I use a box nail, I have to go to a 20d to achieve the 0.148...but their 4" long...and will stick out an inch....
I've seen the "deck Nails" that are really just spiral 10d - which in their 2003 catalog said I could use without a reduction -- but have been removed from their 2006 Replacement Nail table....butd I can't find the specs for 10d Deck nails nor have I found them on store shelves...
The Nail vs. screws discussion stated if screws are not over driven "in a nutshell, when comparing nails to screws, screws will prevail in every instance."
HOWEVER, the City of Des Moines (Iowa) is not allowing me to substitute 3" Deck Screws (which are not drywall screws) for the 10d common -- and are requiring me to use the 10d x 1-1/2" joist nails -- because "that was what they were designed for" --- and I can't get them to see the joist nails cannot be used with the hangers I have...
HELP -- What am I going to do?
Simpson makes all of the appropriate nails for this. They make a 10D common just ask your supplier to order the 3" nail and you will be all set.
Model number is 10D5HDG
melkahn3669 is offline
Old 06-07-2009, 09:54 PM   #88
KemoSabe
loneframer's Avatar
Originally Posted by redwood View Post
First off, I beleive the 10d refers to the length, not the diameter. A 10d is 3" long. You cannot have a 1 1/2" long 10d in any nail.
In theory that is true, but the Teco nails we get have a number stamped on their heads,8,10,12 which refers to the relationship of the diameter of the nails.
loneframer is online now
Old 06-08-2009, 11:55 AM   #89
stuperintendent's Avatar
Trade: commercial construction
it sounds like to me that you have a bunch of 3" screws youre trying to use up but if you follow the simpson book you shouldnt have any inspection problems just use the proper fastener, its all in black and white. if they wont accept it submit hanger/fastener to the architect for the structural engineer for review or he can approve a different fastener. as stated in other posts depending on where youre located besides live and dead loads being imposed on the structure you also have to consider the wind load uplift. In my area so. fla. its a 150 mph wind zone which adds another dimension to the mix. Lab tests have shown that the fastener will fail before the hanger, thats why theres so much emphasis on the shear strength of the fasteners. so in the design of a deck or any other structure you have to consider the live load of people that the proposed structure will accomodate, as well as furniture, equipment, etc. ie. dead loads equating into a pounds per square foot (psf ) number the structural engineer uses to design the structure.hope that helps.
stuperintendent is offline
Old 06-09-2009, 11:12 AM   #90
I builds'em
Winchester's Avatar
Trade: Renovations & Decks
Screws are made from hardened steel -- which is stronger than nails -- capable of more shear...
Proof -- take a wire cutter -- cut a 10d nail with it (shear). Now try cutting a 3" deck screw -- depending on how good the wire cutters are, you may ruin the cutters before you get through the screw.
"Bending" is not shear....
Drive a 3" screw in half way and smack it from the side with a hammer. Usually they snap. Do the same with a nail. Do this and then answer which one do you think is gonna resist shear force better?
Winchester is offline
Old 06-09-2009, 07:02 PM   #91
Chris G's Avatar
Trade: Porch and Deck Builder
Exactamundo!
"Neek...Neek...yoo-a-moronna Neek. Getta-da-fookin-a-jacka-ham!"
http://www.vicporch.ca
Chris G is offline
Old 06-20-2009, 10:29 PM   #92
whooley's Avatar
Trade: General construction and roofing
If you are worried about the hanger nails pulling out then you didn't build anything right from the start. Also a screws strength is compromised by it's installation. Too tight and you have issues, too loose and you have other issues. The density of the wood and length of the screw can effect the screws strength. The heat from installation can change the temper of the screw. A nail does not have many of these issues to contend with.
I'm with the guy that said a structure should be built in a manner that eliminates fasteners from supporting the structure.
whooley is offline
Old 06-21-2009, 09:22 AM   #93
So, you don't believe in
joist hangers?
neolitic is offline
Old 06-21-2009, 11:04 AM   #94
Capra aegagrus
Tinstaafl's Avatar
joist hangers?
Yes Virginia, they do exist.
But I've seen way too many of them (outdoors) rusted through to put a lot of faith in them long-term. Maybe if everything was SS, but that would be more expensive than most are willing to pay.
OTOH, truly eliminating all fasteners from doing any support at all would probably cost just as much.
Tinstaafl is online now
Old 06-21-2009, 11:43 AM   #95
Just sounded like the guy
wasn't taking in to account
that the hangers depend on
the fasteners too.
Maybe I misunderstood.
neolitic is offline
Old 06-21-2009, 11:52 AM   #96
Capra aegagrus
Tinstaafl's Avatar
Maybe I misundrstood.
I think so, but understandable. That last line does kind of jump out at you.
Old 06-21-2009, 09:11 PM   #97
jhark123's Avatar
Wow. five pages and no resolution due to the OP's stupidity. Since you are obviously a professional contractor (), this is what you need:
http://www.amazon.com/Paslode-F250S-...632556&sr=1-17
plus this:
http://www.amazon.com/Eagle-112X148H...5632556&sr=1-9
equals a system 1000 times faster than screws
jhark123 is offline
Old 06-21-2009, 11:18 PM   #98
BuiltByMAC's Avatar
Trade: Construction
1 1/2" nails are fine for nailing the hanger to the ledger but you'll also need the 2 1/2" gun nails for the angled toenails through the joist end.
Mac
BuiltByMAC is offline
Old 10-22-2009, 11:38 PM   #99
cnydave's Avatar
Trade: lead carpenter / trim
I am in the process of R&R 300+ 2 story balconies at two apartment complexes.
All are 12 x 4ish, original decks used cantilevers so you can imagine the rot, anyway...back to the screw vs nail joist hanger issue; many of these decks were "repaired" , some had joist hangers installed with deck screws.
On demo, the hangers with deck screws offered much less resistance than nailed hangers.
We use screws in most situations, but never in shear situations...I use sds lags screws on our dtt2z ties, but this is lateral.
I've bent nails into some pretty cool shapes trying to remove them, screws, just use the head of the estwing.
cnydave is offline
Old 10-23-2009, 01:43 AM   #100
I builds'em
Winchester's Avatar
The 1.5" nails I use have a 10 stamped on the head as well.
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 04:46 AM
Cleaning Stained deck Joist clean solution? plazaman Painting & Finish Work 6 06-07-2008 08:54 AM
Deck Screws Tralene Decks & Fencing 13 10-20-2006 12:51 PM
Floor joist out to deck? irving Carpentry 18 04-15-2006 10:15 PM
