Deck Screws Vs Joist Nails
Old 11-16-2008, 05:31 PM   #41
redwood's Avatar
Trade: Carpentry Contractor
Re: Deck Screws Vs Joist Nails
Repeat "The Designer/Engineer of Record can specify a substitute screw"...
So, has anyone done this?[/quote]
The key word in your statement is "can". But, in my 30+ years of building, I have never had a engineer substitute a screw for a nail in shear situations.
If it helps you to beleive me, I actually have a degree in structural engineering. But No, I am not a engineer.
Mark
Los Gatos, CA
www.creative-redwood-designs.com
redwood is offline
Old 11-16-2008, 05:33 PM   #42
subybohn's Avatar
Trade: AmeriCorp State Alumni
Screws in hangers are not practical in basic deck design at this time for the pros - due to costing more and slowing the pros down...
But if screws have not been tested, why not? This way will will know if they could be a viable alternative…or to put this debate to bed once and for all.
Most importantly, I want to make sure 10d x 1-1/2" Joist nails are not being used unless noted by the manufacture, for they are not designed specifically for "ALL" hanger use.
That is the basis for this discussion for I’m floored when I hear people make this assumption...especially when this comment it is coming from an inspector….or the salesman selling the hangers.
subybohn is offline
Old 11-16-2008, 06:59 PM   #43
BuiltByMAC's Avatar
Trade: Construction
I'm going to have to assume at this point that Suby is not a native English speaker. The reasons he/she just gave for "pros" not using screws in hangers are not the reasons we've been giving. Suby doesn't understand what we're saying. This is like talking to a brick wall...I think I mistook incomprehension for tenacity.
Mac
BuiltByMAC is offline
Old 11-16-2008, 07:36 PM   #44
PA woodbutcher's Avatar
Are you "confused"?
Always
All I'm saying take 2 8' 2x4s tack them together with a couple of nails and use them to jack something up...try the same thing with screws and see which gives first. I know I've sheared screws off doing this, turned around and used 16s and had no problem. After re-reading and checking the rest of the posts, I think MAC may be on to something.....I mean how hard headed can someone be?
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline
Old 11-16-2008, 08:01 PM   #45
Deck Designer/Builder
DecksEtc's Avatar
Originally Posted by BuiltByMAC View Post
Sorry, too early in the morning to try and sort through the technical facts you're proposing...though I am laughing my ass off at DecksEtc response to your cabinet comparison!!
Mac
Glad I could bring a smile to your morning coffee Mac!
Subybohn,
What kind of "time savings" do you think there is between screws & nails for joist hangers?
Before I had a palm nailer (they weren't readily available in Canada until this year ), I guarantee you that I could screw a joist hanger in place faster than by nailing it. I don't use nails for the time savings, I use them because they are the right thing to use and they are all that passes building codes.
What is it that you're not understanding???
DecksEtc is offline
Old 11-16-2008, 10:58 PM   #46
Kgmz's Avatar
I know this is a can of worms -- and I have read the postings from Nails vs. screws...
But I have a problem.... Simpson Strong-Ties LUS28Z face mounted joist hangers...
According to their web-site, this hanger can really carry a good load, as long as it's installed properly.
I've noticed that if the Hanger has an "S" in its name, it's a hanger in double shear and their web-site specifically says I cannot use 10d x 1-1/2" Joist nails.
It does not say that. It says that these hangers are engineered for full load when hung from 3x or better material, meaning a 3x8 or 4x8. And if you use this hangers on a 2x8 then you have to use the 10d x 1.5" nails on the face and take a load reduction. And you cannot use any other nail than a 1.5" nail when it is nailed straight into the face of a 2x.
AND if I use a 10d x 1-1/2 joist nail in the header, I have to multiply the load by .65 (or I have to reduce the load it can carry by 35%).
Same as above, you have no other choice but to use a 1.5" nail since it is nailed straight into the face of a 2x and take the load reduction.
To maximize the load these hangers can carry, I have to install an equivalent fastener to a 10d common.
This is only for the double shear nails, since you can't use a 10d common nailed into the face of a 2x.
I am only using the hangers along the house and with the header lagged into the rim board; I have the needed 3" for the 10d length....for both the header 10d nail and the joist 10d nail.
However -- their specs says the equivalent to a 10d common is 0.148 x 3"
I am using treated wood -- and the hangers are not stainless steal -- so I cannot use stainless steal fasteners.
I can find 10d hot-dipped galvanized in a Box Nail, but not a 10d hot-dipped common nail.
If I use a box nail, I have to go to a 20d to achieve the 0.148...but their 4" long...and will stick out an inch....
I've seen the "deck Nails" that are really just spiral 10d - which in their 2003 catalog said I could use without a reduction -- but have been removed from their 2006 Replacement Nail table....butd I can't find the specs for 10d Deck nails nor have I found them on store shelves...
The Nail vs. screws discussion stated if screws are not over driven "in a nutshell, when comparing nails to screws, screws will prevail in every instance."
HOWEVER, the City of Des Moines (Iowa) is not allowing me to substitute 3" Deck Screws (which are not drywall screws) for the 10d common -- and are requiring me to use the 10d x 1-1/2" joist nails -- because "that was what they were designed for" --- and I can't get them to see the joist nails cannot be used with the hangers I have...
HELP -- What am I going to do?
Now learn to read the book and understand what it is saying, all pages.
You are already forced to take the load reduction of .65 because of the 2x material you are hanging it from. So if you use the 10d box nail (.131) you have to take a reduction of .83, which is well above the .65 reduction of the 2x material. So use 10d x1.5" nails for the face and the 10d box nails for the double shear nailing, easy.
Also when Simpson refers to a 8d,10d, etc. hanger nail. They are referring to its diameter, not its length. Whether it is a 10d x 1.5" or 10d x 2.5" hanger nail.
Kgmz is online now
Old 11-16-2008, 11:27 PM   #47
Kgmz's Avatar
Who do you think designs and tests for Simpson, Engineers.
Don't you think they have probably tested some of these things with screws.
And they do also have some products that use screws, just look in the book.
Also since you do have internet access, download their latest catalogs and technical bulletins.
And last if you have any questions please call Simpson at 800-999-5099
Kgmz is online now
Old 11-17-2008, 12:14 AM   #48
reveivl's Avatar
Trade: Renovations
Off topic I know, but man we've had palm nailers out here for years and years.
Who was it said that screws are always better? They each have their uses, learn to use the right one in the right place. Lotta people here are talking a lot of sense.
reveivl is offline
Old 11-17-2008, 11:45 AM   #49
subybohn's Avatar
Simpson Ties themselves stated "deck screws" have not been tested.
So if screws are faster to install than nails -- why isn't anyone asking for deck screws to be tested?
And yes, there is a difference between a deck screw and a 16d common nail... I am trying to compare a 3" deck Screw to a 3" 10d spiral.
Information I have gathered is from inspectors, sales people who sell the hangers (who said SS cannot be used with LUS28Z and Z is for Zinc), pro's including postings from web-sites - they all have something to say.... But I'm not finding consistency.
When inspectors told us, we have to fill "every hole" in the hangers with the 1-1/2" joist nails (including the joist AND the header) -- for that is what the "joist nails" were "designed for" -- my mouth dropped, and we had to comply or fail inspection.
I'd rather install screws....which I read from THIS web-sight during a Screws vs Nail discussion back in 2005.
I am just trying to find consistency....or lab results comparing Nails to Screws...
It's nice to hear screws are no longer time consuming to install....for it helps to show screws could be a viable alternative in hangers and should be tested.
And by the way -- you don't have to take an allowable load reduction, if you are using 3" and nailing through a deck header board into the rim board....
And if you use a box (casting) nail, you'll need a 20d box for the same diameter a 10d common has (0.148). 10d box only has a diameter of 0.135 which is less then the neck (area I call without threads in shear plane) of a 3" deck screw.
Again, I'm just looking for consistency....
subybohn is offline
Old 11-17-2008, 12:28 PM   #50
Kgmz's Avatar
Oh yes you do. You better read that book better.
From the Simpson Wood Construction Connectors Book C-2008.
Built-up lumber
(multiple members) must be fastened together to act as
one unit to resist the applied load
(excluding the connector fasteners).
This must be determined by the Designer/Engineer of Record.
So unless a engineer designs this and you have a stamped approved copy onsite, you have to take the reduction.
Also most engineers never design something at the max load of a hanger.
Kgmz is online now
Old 11-17-2008, 12:43 PM   #51
Kgmz's Avatar
I just did a search for you and found 10d common galvanized nails all over the place.
Do a web search for a "10hgc"
Do any of your local suppliers carry Grip-Rite nails, they make them and my local suppliers and lumberyards carry them.
Kgmz is online now
Old 11-17-2008, 01:35 PM   #52
redwood's Avatar
This topic is getting old. Just use the damn screws.
Mark
Los Gatos, CA
redwood is offline
Old 11-17-2008, 07:52 PM   #53
RobertCDF's Avatar
Trade: Custom deck builder
Yeah do whatever you want and shut the heck up. Codes and engineers dont have a clue what they are talking about. You are the smartest man around much smarter than us dumb deck builders who have no field experience at all.
RobertCDF is online now
Old 11-17-2008, 09:33 PM   #54
basswood's Avatar
Trade: trim carpenter
A few thoughts:
The dude is pushing a rope.
People who prefer screws for hangers probably lack skills driving nails by hand.
If you hate hand driving joist hanger nails, get a palm nailer or positive placement gun.
Designing decks (and other structures) that rely less on hardware and fasteners makes them more fault tolerant (especially given the issues of ACQ and galvanic corrosion).
Put beams below joists (rather than flush beams with hangers), when possible. Think to yourself if the hardware or fasteners fails will the structure hold together.
Set beams in notches in the posts and let-in braces (get back to using some real joinery).
I like hardware, but it is often used as strapping, holding bad designs together.
Jigs, a few tools, and some skill and traditional joinery can be just as fast as cobbling a bunch of HDG stuff together.
I am doing a below grade retaining wall and stairs right now, the half lap notches take me 6 minutes, and require no expensive hardware or fasteners.
Food for thought...
Deck Screws vs Joist Nails-6x-notches-retreated.jpg   Deck Screws vs Joist Nails-6x-interlocking-corner.jpg
basswood is offline
Old 11-17-2008, 11:33 PM   #55
Originally Posted by basswood View Post
A few thoughts:
Food for thought...
Nice to see someone else who believes
in cuprinol.
I have been as much as called apostate.
Told that treatment penetrates all the way
through the wood, etc.
neolitic is offline
Old 11-18-2008, 12:34 AM   #56
BuiltByMAC's Avatar
Trade: Construction
Whereas I agree with you in theory, this particular application (joist hangers at a ledger connection) doesn't have a lot of other options. You could install a beam at the house and set the joists on it but then you'd have posts next to the house.
I like using real joinery as much as the next craftsman, but sometimes, ya still gotta pull out the hardware! (Psst, suby - Then you use nails to install them).
Running straps around the back of the ledger is the closest thing I've found to making that connection bomb-proof.
Mac
Old 11-18-2008, 06:55 AM   #57
s. donato's Avatar
mac i like that strap around the back method. but i imagine it only works if the ledger to house connection is good too ;-)
s. donato is offline
Old 11-18-2008, 07:56 AM   #58
stp57's Avatar
Trade: carpenter/ handyman
Just a note on deck screws:
Home Depot has repented of one instance of choosing cheap over quality. Earlier this year they replaced their Square Drive (from Phillips) with a T25 torx head screw from China. Obviously, I wasn't the only dissatisfied customer...they just dumped the entire line & went back to the Phillips screw! Take that you European, metric loving people. Money still talks.
Another note: The Phillips company had made an agreement with Home Depot many years ago that Lowes would not get the Square Drive system, but instead the standard Phillips head (which strips out easily, BTW). HD's Chinese run cost them dearly. Lowes is now selling the Square Drive as Phillips ll Plus for $23 a five pound box v.s HD's $28 a box! Big difference!
stp57 is offline
Old 11-18-2008, 08:24 AM   #59
basswood's Avatar
Mac
Good points. I'm not anti-hardware and the ledger connection is a practical place for it... just figured that since the nail vs. screws debate was going nowhere, I would suggest a third option of eliminating some hardware and fasteners (screws or nails). Just a random thread hijack (though I'm not sure you can hijack something that is not going anywhere).
Sometimes simpler is better. Not always practical, but I like freestanding deck designs (ledger connections are often a weak point both structurally and for water leaks). I'm sure your ledger connections are both strong and water tight, and my deck is bolted onto a ledger at my house.
On hardware, I've had windows and doors show up one size too large and had to remove trimmers under a header and substitute header hangers. Now I hear that to minimize thermal bridging of framing and save some trees, some designs are calling for all headers to be hangered.
Now that seems like hardware run amuck to me, but some deck designs also rely way more on metal than they should. I am just encouraging simple solid design. Design like the metal could fail...cause it might someday.
I so think the ACQ/hanger corrosion thing is a timebomb.
Not really a luddite or into conspiracy theories. Could get interesting.
Have a great day.
Bass
basswood is offline
Old 11-18-2008, 09:47 AM   #60
BuiltByMAC's Avatar
Trade: Construction
Hijack away, this thing has definitely run it's useful course!!
Regarding the ACQ corrosion, one thing I do is spray the backs and insides of the hangers w/ PlastiDip, a rubberized coating (used for coating tool handles). Puts another layer between the ACQ lumber and hanger, and is w a a y faster than using flashing tape...
Mac
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 04:46 AM
Cleaning Stained deck Joist clean solution? plazaman Painting & Finish Work 6 06-07-2008 08:54 AM
Deck Screws Tralene Decks & Fencing 13 10-20-2006 12:51 PM
Floor joist out to deck? irving Carpentry 18 04-15-2006 10:15 PM
