Deck Over Empty Swimming Pool
Old 03-16-2009, 06:26 PM   #1
Evans Brothers Inc.
evansbrothers's Avatar
I have a customer that has had major problems (city code violations, maintenance and upkeep costs, tenant complaints, etc) with an indoor basement swimming pool located in a 15 unit apartment building.
He wants us to build some kind of a simple wood platform or deck over the pool opening so he can use the new floor for tenant storage units. He does not want to use the empty pool area beneath the deck for anything so installing access to that area isn't necessary.
The pool will be emptied of course, and all pumps, pipes & electrical connections disconnected. Its relatively small in size (I will have the exact dimensions tomorrow). Does anyone see where there could be problems with this? Thanks for any input.
evansbrothers is offline
Old 03-16-2009, 07:07 PM   #2
genecarp's Avatar
Re: Deck Over Empty Swimming Pool
odd, but doable
genecarp is offline
Old 03-16-2009, 07:13 PM   #3
TimelessQuality's Avatar
Trade: GC/Remodeling
No problema senior
Better watch out, I think decks over empty pools in commercial properties is RBS' specialty
-Steve
"The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein
TimelessQuality is online now
Old 03-16-2009, 07:18 PM   #4
BuiltByMAC's Avatar
Trade: Construction
You'll probably need to drill holes through the existing pool floor to get your footings on bearing soil, that, or use beams that have been engineered to span the pool w/ no intermediate supports. With that option, you'll need to make sure the concrete next to the pool can handle the point loads of the beam ends.
Plan for a lot of weight if it's going to be used as storage...
Mac
BuiltByMAC is offline
Old 03-16-2009, 07:20 PM   #5
mickeyco's Avatar
Trade: Squirrel Handler
Find a demolition job and toss the debris in the pool before you build the platform.
I seem to remember some codes about "decommissioning" pools, don't know what, there are several pool guys here, hopefully they see the post or maybe you can contact them.
mickeyco is offline
Old 03-16-2009, 07:49 PM   #6
Originally Posted by mickeyco View Post
Find a demolition job and toss the debris in the pool before you build the platform..
mickey....you make me cry
-Steve
Old 03-16-2009, 08:30 PM   #7
always building
parkers5150's Avatar
Trade: general constructiion
the problems will arise when the DEA shows up to remove all the new landscaping
under the deck
parkers5150 is offline
Old 03-16-2009, 08:35 PM   #8
Warren's Avatar
Trade: framing/remodeling
We did a remodel once where a lady didn't want her pool which was under the garage. They had it filled in with gravel and then poured concrete over it. Only problem I see with just building the deck over an empty pool is that water will probably find its way in there which could be a mold concern maybe?
Warren is offline
Old 03-16-2009, 09:16 PM   #9
Patrick's Avatar
Thats why you gotta build a super secret access hatch
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 03-16-2009, 11:57 PM   #10
General Contractor
greg24k's Avatar
Don't forget to install the light at the far end of the pool before you close the lid
greg24k is offline
Old 03-17-2009, 09:10 PM   #11
Anti-wingnut's Avatar
1) Are there fire sprinklers in the area? If so, the area under the deck will have to be sprinklered
2) Is wood construction allowed in this building? Or is the building of another construction type
3) What will be the floor loading?
Anti-wingnut is offline
Old 03-17-2009, 09:23 PM   #12
Alternately, saw cut out the bottom for drainage. Fill it with CDF or gravel, and pour a slab onto of it
Pool Deck Fence TimelessQuality Decks & Fencing 7 01-31-2009 12:30 PM
Swimming pool Construction Company Silver Construction 1 06-30-2008 05:00 AM
