Armstrong Carpentry
Trade: Carpenter / Cabinet Maker
Deck Ledger Question
I am rebuilding a deck, the joist hangers for the old deck were attatched directly to the house rim joist is (no ledger / no sheathing), this was done by a builder in the 70's...
Fortunatly I dont see any rot, The house siding is 5/8 T1-11. I have never seen this type of deck / house attatchment, Should I sheath over the rim joist before I attatch a ledger (10 inch strip of plywood)? or should i run ice and water over the rim, flash and attatch my ledger directly to the rim joist (without sheathing)? I hope that makes sense to someone else... Thanks in advance Mike |
Trade: Carpentry Contractor
Re: Deck Ledger Question
I've seen it done that way, except that the sheathing still covers the rim joist.
You need to get flashing up under the sheathing and building paper above the new ledger, with a kickout to wrap over the ledger. Flashing behind the bottom of the ledger, kicking out over the siding. Then water shield over this bottom flashing and under the upper flashing. Hope that makes sense. |
I would tear it all down and redo it the right way. this way you know what you are dealing with. but your 10" piece of sheating on then attach your ledger into the joyce of the house. make sure you are going into the joyce and not the rim joyce.
One day at a Time. |
If the rim joist is flush with the back
of the siding, no sheathing. If the old sheathing would have continued down past the joist, then I'd fill in the sheathing.
#5 | |
Trade: Carpentry / Fencing / Decks
Re: Deck Ledger QuestionQuote:
Who in the world is Joyce and are you sure she doesnt mind the penetration?
www.ParkerFenceandDeck.com |
| The Following 3 Users Say Thank You to curapa For This Useful Post: |
#6 | |
I'm still trying to figure out why no one makes a distinction between a rim joist and a boxing board. Leaves me confused....
decks-patios-remodeling
Trade: Deck, patios & remodeling
Re: Deck Ledger Question |
I dont see any problem with leaving out the sheathing. Hell I think its better really. There were no signs of problems after years of service. You could ice shield and rehang on the rim again probably with out an additional ledger. Even if you add a another ledger without the sheathing you create a larger offset of water from the house. Just make sure new flashing is behing the siding.
| The Following User Says Thank You to Tom M For This Useful Post: | knucklehead (04-22-2009) |
#9 | |
The Deck Guy
What's a "joyce"? I'm new to this.
| The Following User Says Thank You to Greg Di For This Useful Post: | knucklehead (04-22-2009) |
Did Jon Mon get a new User name?
Why would you put a 10" strip of sheathing back up? If it is flashed properly, the ledger and weather proofing is just as good, with or without the sheathing. That strip of sheathing has just become a spacer or gap filler. All of the correct flashing procedures will be required regardless. |
| New Clear Cedar Deck Finish Question | TRISTAN | Painting & Finish Work | 6 | 10-25-2011 10:33 PM |
| Whats The most expensive deck you've built | deck king | Decks & Fencing | 96 | 07-10-2010 09:02 PM |
| Deck over Living space question | NK8892 | Decks & Fencing | 18 | 07-08-2009 06:20 AM |
| Correect Deck ?'s Robert and others | IHI | Decks & Fencing | 9 | 05-21-2008 10:45 PM |
| Another newbie deck pricing question | fullhouse | Decks & Fencing | 1 | 05-05-2006 08:10 PM |
