Deck Ledger At Mid Wall
Hey got an issue....
Need to build a deck several feet below threshold of second story. Obviously no rim joist. Can i block the studs and thru bolt? any and all suggestions welcome! |
Re: Deck Ledger At Mid Wall
Lag into the studs. No need for blocking. Just make sure your centered and secure. Use 3/8"-1/2" lags. If this deck has a too large a tributary load you may need to bring other footings closer to the house.
Trade: Masonry consultant
Most codes will not allow lags into studs. Some will not allow any lags, but want through bolts. Because your ledger would be pressure treated, you will have to use corrosion resistant bolts.
Have you considered a free-standing deck to eliminate all the moisture and detail problems such as the rcommended double flashing and sealing.
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. |
#4 | ||
Trade: Squirrel Handler
Re: Deck Ledger At Mid WallQuote:
Best idea as recommended by concretemasonry, is a free standing deck, with an attachment to the house to meet code and avoid cross bracing. Here is an alternative to lag screws that might actually work for a ledger to load bearing stud wall situation, they are called LedgerLok, and they do have an ESR report. I've been wanting to try them but haven't yet. From their website: Quote:
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
Workin' Hard & Havin' Fun
Trade: Deck Designer/Builder
Mickey,
We just switched over to the LedgerLok's about a month ago. Try them! They'll send you a few free ones to get started if you're on the fence. They're quicker than predrilling & lagging, however we used an impact on our 1/2" lags, so that was never an issue. What sold me was the price- they're cheaper than lags. Oh, and stronger too. We proved that by putting a ledger on a house w/ 1/2 lags, then went & installed the LL's, which pulled the 2x closer to the house! Just food for thought... ~Matt |
Thanks All- No way for free standing. I am in berkeley on top of a fault. Looks like arhitect or
engineer> |
#7 | |
Do it Right, Do it Once
Trade: Deck & Concrete
FM Sent me over the paperwork showing the code compliance for 2006 IBC IRRC.
So far we only have one Twp giving us grief, I sent them the paperwork & they haven't returned my request for answer. I'll probably fight that battle next week. If I have to use 1/2 lags I will, but I hate being inefficient & dropping the quality to the customer just for a poorly informed inspector! ~Matt |
Trade: Custom deck builder
If you go the route of attaching a ledger to the studs I recomend using a 2x12 ledger. Even if you dont need one that large it will get your ledgerloks further apart and have less chance of splitting the stud. I would also recomend the ledger loks over 3/8 lags.
They are 2x6 walls and i do not want to lag to studs.
I think i will block the studs with 4x12 flush to the outside of stud. sds some angles from stud to block and then thru bolt ledger to the blocks. What do ya think? Thanks |
#11 | |
#12 | |
Here's the ESR report for the LedgerLoks to show to inspectors: http://www.fastenmaster.com/Files/Fa...R/ESR-1078.pdf
| Used the new Correct Deck CX-personal review | IHI | Decks & Fencing | 22 | 07-27-2008 09:52 PM |
| Backyard office, retaining, and privacy wall | Team Scream | Masonry | 8 | 08-02-2007 11:27 PM |
| Deck ledger on brick? | jiggyjack | Decks & Fencing | 13 | 03-30-2007 09:46 PM |
| Low (12" or so) brick garden wall questions | bindersbee | Masonry | 8 | 04-27-2006 08:31 PM |
| Attaching deck ledger to new construction | Woodcrafter74 | Decks & Fencing | 12 | 01-07-2006 09:41 PM |
