Trade: Deck Builder
Deck Building Logistics
Ok, so I'm still pretty new to the deck building business & just trying to learn some ways to be more efficiency & not kill myself on some tasks. These questions may seem pretty basic, so bear with me.
How do you pour your footings if a concrete truck can't get to them? Do you mix them yourself with a small mixer? Do you huff wheel barrows full back & forth? I looked into renting a concrete pump, but can't seem to find anywhere that rents them. I've called half a dozen places & ones that even googled for "concrete pump rental". No dice! Next, lumber. Do you buy all your lumber the same lengths or do you spec some 10', 12' & 16' for the project depending on what they will be used for? Footings. Say you have some 20" & some 12" footings on the same deck. Do you bore all of those with the same auger, say a 24", & then just backfill or do you use different sized augers? Sorry for the basic questions. Like I said, still new & try to learn from some of the best. Just don't beat me up too much! Thanks, Dan |
Re: Deck Building Logistics
Wheel barrow
length specific all 12's, but I have never needed a 20" |
every situation is diff, usually its hard to justify the price of a pump for some deck footing, we wheel or mix ourself, depending on terrain,lumber order per job specific, 10s 12s 14s 16s whatever you need, auger size, one size, then hand work, dont of coarse dig deeper, then fill in, terra firma
#4 | |
Re: Deck Building LogisticsQuote:
I can only conclude that you aren't trying very hard. I just flipped open the Yellow Pages (the real ones) and there are six listings under "Concrete Pumping Serv". At least three of them are on the eastside. If you don't have them, you really need to get the AT&T Indy phone books. As to lumber... you can't stretch a 12 if you need a 16, and why ever would you pay for 16 if you only need 10 feet of it? Personally, I like to leave the dirt around footings the way the glaciers packed it if it's at all possible. Once again, why dig 24"Ø if you only need 12"Ø? Going the other way, I will sometimes "bell" the bottom of a 12"Ø to make a 16.
Trade: home builder carpenter Central Alabama
Here its not worth calling a truck AND a pump for a yard of mud. They charge more per yard for less than 5 yards and a pump will cost $150 just to come not counting pumping time. We have a small electric mixer we mix quickcrete with (not in the hole). You could rent one. Theres no such thing as a frost line here so we dont have to drill deep footings we just dig them 1'x1'x6" or 2'x2'x1' buy hand. You should probably just use the 12" drill. Order what you need for lumber. Get extra boards not extra length. You can take back uncut boards.
#6 | |||
Trade: Construction
If you're not finding a pumping service in the phone book, call your local sand and gravel company. They oughta know of some pump companies in town - they work with them daily. Quote:
Mac |
#7 | |
Trade: Deck Builder
As far as the lumber length, I guess I should have been more specific. Obviously if you only need all 12' joists you wouldn't order all 16'. I guess I was just wondering for ease of ordering & bundling from the yard. Easier to bundle & order if you say (20) 16' instead of (12) 16' (5) 12' & (3) 10'. I figure the excess can be used for blocking etc. |
#8 | ||
factor. How long will it take to haul, mix, etc. How difficult is it to access the site.... We have only had a very few where pumping was the answer, but those would have been monumental problems without the pumper! (At your age, you also have to consider that whatever the time to hand mix... it's all going into your pocket.) Quote:
but I usually figure in extra joist to allow for the fact that they will send some material that is to crappy to use for structure but will still make decent blocking. I don't much worry about how the yard will load and band it... cause they never worry about loading it upside down for me! ![]() (No matter how I write my list, or what I say when I order it, they will make sure that the first piece I need is on the bottom and the decking is on top. )
#9 | |
Trade: Construction
Yeah, I sometimes order one or two lengths of pt lumber, regardless of actual layout. The ends can be used as blocking or shorty angles and getting all the same length increases (but doesn't guarantee) your chances of getting lumber that is the same height (pt lumber can vary by as much as 1/2" in height out here - planing the tops or shimming the bottoms takes up time, if I can avoid that, I do!) If you get all your lumber from the same rack, your chances are better. Mac Edit to add: Here we go again, Neo! Although you've got the quick fingers this morning! Enjoy the day, hopefully you've got good weather too - |
#10 | |
Professional Instigator
there are bags of footer mix/quickset concrete you dump in the footers add water and they set up around the post. Some times i use my bobcat if it can get through to the area fill the bobcat bucket with the cement and ride it around back. Call the concrete plant and ask them about a pump truck will know who pumps concrete in your area. I try to by correct lumber size, anything after a 12' here is expensive. we usually do 12" holes for 4x4 and 24 for 6x6 no one really uses 4x4 anyway though |
#11 | |
![]() Partner is baby sitting the tile guy on the job, so I get to spend a day working on re-organizing and cleaning up the garage/workshop/warehouse/dump without starting up a heater!
load and band it... cause they never worry about loading it upside down for me! ![]() (No matter how I write my list, or what I say when I order it, they will make sure that the first piece I need is on the bottom and the decking is on top. )[/QUOTE]aint that the truth ![]() I picked up some lumber for a small 10x14 deck today. I just got it on my truck and i was amazed when the jard help asked if i wanted the 5/4 boards loaded first. To bad i had to tell him i wanted the 14' 2x8s on first so the decking could hold them down in the 6' bed. |
| fined for building a 6x14 deck $1000 per day, what do I do? | dabs27 | Decks & Fencing | 15 | 03-01-2008 01:02 PM |
| Deck Building Labor Wages? | Jizmaglobin | Decks & Fencing | 12 | 11-16-2007 06:47 PM |
| Deck Building Question | brewsterb | Decks & Fencing | 2 | 06-21-2007 01:29 AM |
| Deck building as a career? | fishscaper | Decks & Fencing | 13 | 03-20-2007 10:08 PM |
| building a screened porch atop a deck | 72chevy4x4 | Decks & Fencing | 1 | 02-21-2007 10:29 PM |
