Deck Beam Sizing And Post Spacing?
Old 05-09-2006, 01:56 AM   #1
diyerforever's Avatar
Trade: electrician
I am sparky by trade asking a little help about the deck I would like to build. Let me explain the deck first. The overall deck will be 29'6" x 12' and 8'H at the highest point. The 29'6 is due to yard restriction. But anyway if you start at one end there will be 3'6" then a 12'4" driveway then 13'8" to the end. I can place the posts for the beam anywhere except in the driveway.(obviously) I was planning on attaching the deck to the house and having a beam size of 3- 2x12 combined with 3-6x6posts 14' on center and 2x10 joist. I am asking is this code (and safe). The drive slopes down so beam height is not a problem.
I thought about turning the beams to run away from the house and span the driveway with the joist but that is a lot of posts. If this is the only way that it can be done than thats what I'll do.
I heard of placing a flat piece of 1/4 or 3/8 steel between the beam and bolting it all together to take out the bounce and strengthen the beam.
I was hoping someone on this site has run across this before or has any advice on the situation. I am open to any and all suggestions.
Thanks in advance,
sparky by trade diyer forever
diyerforever is offline
Old 05-09-2006, 02:36 PM   #2
RobertCDF's Avatar
Trade: Custom deck builder
Re: Deck Beam Sizing And Post Spacing?
I have spanned large driveways before with a 14" glulam beam. You MIGHT be able to use 3 2x12's depending upon the loading requirements of your local building department. IF NOT you could most likly use (2) 11 7/8" microlam for your beams. (I have used these to span 18' with a 40 PSF LL and 15 PSF DL) Check with your local building department for permits and to double check your plans.
RobertCDF is online now
Old 05-09-2006, 06:50 PM   #3
bob the builder's Avatar
Trade: Home Improvement
Thanks in advance,
Where I live if you want post spacing every 14' you would need 4/2x12's not 2. Then 2x10's 16" o.c. for s. pine # 2.
You could run your beam into the house if you have a way to attach it you would still only need 3 posts total. The benefit I guess would be no seams on deck boards that are 12' long...
Yes you could use a fletch beam/steel sandwich but it's not needed.
Bob
bob the builder is offline
Old 05-09-2006, 09:56 PM   #4
onhitch's Avatar
Trade: deck contractor
Bob
yes , run your beams pependicular to the house and you are golden!
onhitch is offline
Old 05-10-2006, 10:46 PM   #5
Trade: electrician
What about 14" beams? Wonder how long it would take to get those? Are they readily available? How much are they?(roughly) Would I need to rap them with anything?
Thanks for the replies,
diyerforever
Old 05-10-2006, 10:58 PM   #6
RobertCDF's Avatar
When I used the 14" glulam I think it ran me $8.XX a linear foot I would have to look that up to be sure. But it is 3" wide so you only need one instead of 2. I did cover it with flashing to keep water from sitting on it. But there are pressure treated glulams out there. I saw an ad for them in Professional Deck Builder magazine.
