Trade: Table Resurfacing
Deck Advice
I am going to do a job on a deck that is 10 years old. Some mildew and chipping paint. The deck is about 250 sq. ft. Should I sand the deck with a belt sander and than paint and water seal or should I use a power washer? What would be the best way to attack this deck beast. I am completely open for all opinions and am grateful for all suggestions.
Trade: GC/Remodeling
Re: Deck Advice
Just do what a table resurfacer does...just a little lower
-Steve "The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein |
John Hyatt
Re: Deck Advice
10 years old,chiping paint,mildew probley pt decking. Give it a quick bleach wash and paint it again. J.
Trade: Interior Trim/Decks
Re: Deck Advice
Without seeing the deck i cant say what is best for the job. The advice i can give is that a pressure washer will be the quickest way to go but make sure you set the pressure so that it wont blow out chunks of wood. As far as using a beltsander, well unless you are skilled with a beltsander you can do some serious damage, maybe a palm or orbital sander would be the way to go . good luck.
#5 | |
House Painters Reading PA
Re: Deck AdviceQuote:
I used to always be in custom homes where they would spend several thousand dollars on exotic wood front entry doors and have them painted. What a waste. Clean/scrape off high spots where peeling/scuff sand with a very fine grit paper or screen to feather in spots, but do so lightly and repaint. I do not know what to tell you without a look. This post will seem vague and not too deep.
House Painting and Roof Cleaning by Sutton provides House Painting Services in Berks county PA for all Interior and Exterior Projects 484-334-3999 |
| Deck advice /tips | polaris | Decks & Fencing | 5 | 10-03-2008 08:19 PM |
| Advice - concrete Pool Deck coping | ejleonard | Masonry | 4 | 06-17-2008 05:18 PM |
| deck framing advice | builditright | Decks & Fencing | 20 | 05-08-2008 08:00 PM |
| Deck cover flashing/product advice?? | trav007 | Roofing | 0 | 04-20-2008 07:28 PM |
| advice needed on deck posts in pond | smitty58 | Decks & Fencing | 7 | 09-29-2007 07:54 PM |
