#21 |
Super B
Re: Cutting Stucco
#22 |
Re: Cutting Stucco
use a 4" angle grinder to cut the stucco. You will see the blade will cut through the lath & stucco 7/8" but not through the paper. If you do end up ripping the paper use polyurethane caulk to "tape" the cut ends together. All this talk about weep screeds and leaks is wrong. Weep screeds are at the base of the stucco! Pre drill your ledger board up and counter sink for the lag bolts then polyurethane the piss on the bolt's threds before you drive them in breaking the moisture paper. Good luck on your project.
#23 |
Re: Cutting Stucco
BTW the use of the drip ledges over and under the ledger board is a Plus it will keep the ledger board from rotting. You may be able to slide the top of the drip ledge behind the stucco w/o cutting it but it all depends if there are lath staples in the way. otherwise I wouldn't worry to much about cutting more stucco than necessary because it's just to keep the water from sitting on top of the ledger board.
#24 |
Super B
Re: Cutting Stucco
#25 | |
Trade: Construction
Re: Cutting StuccoQuote:
Mac |
#26 |
Re: Cutting Stucco
James, I just googled proteckfashing and came up with nada, got a link for that product?
http://woodsshop.com/ |
#27 |
Trade: Construction
Re: Cutting Stucco |
#28 |
Re: Cutting Stucco
Got it, thanks Mac. He needs to put a side view of it up on his site. I've had that type flashing made up at a local sheet metal shop before.
| 1 coat vs. 3 coat stucco finishing | janrickey | General Discussion | 12 | 07-17-2011 11:22 AM |
| Tight Space Stucco Question - Undershot between roof sections | CGofMP | Construction | 3 | 03-24-2009 09:10 AM |
| Some questions about painting outside stucco?? | Zeebo | Painting & Finish Work | 10 | 09-20-2006 08:09 AM |
| Determining Manhours for rolling vs. cutting - your suggestions would be helpful | Zeebo | Painting & Finish Work | 9 | 06-02-2006 06:12 PM |
| Rubber membrane behind ledger on stucco? | Woodcrafter74 | Decks & Fencing | 6 | 01-31-2006 08:27 PM |
