Cutting Stucco
I need to cut out some stucco for a 2x8 ledger board. I can cut the long runs easily enough with my circular saw and diamond blade, and the two vertical cuts at each end, but then, what would be a good tool to finish up the cuts at the 4 corners?
Time for the Multi Master??
http://woodsshop.com/ |
Remodeler Extraordinare
Re: Cutting Stucco
I use a Dewalt 4" angle grinder with a diamond blade for things like that.
If you dont want to overcut and go past your line, try a rotozip with a tile cutting bit. First score the stucco with the grinder the take several passes with rotozip.
A.W. Davis Construction Co. http://www.awdavisconstruction.com/ Your friendly remodeling contractor Last edited by A.W.Davis; 09-03-2007 at 10:28 AM. |
Re: Cutting Stucco
Yep, it's for a second story deck in the San Diego area. I've got a page started on my website for it here http://woodsshop.com/PROJECTS/Mill/MillDeck.htm
Those 4" grinders do a pretty good job, but I'd like to get into the square corners and cut a little deeper before I start chiseling out the last part, hopefully without causing any cracks.
#4 | |
Re: Cutting StuccoQuote:
You wont have to worry about overcutting too much on the top of the ledger because the deck boards will cover that, I am sure you knew that. I personally wouldnt remove the stucco for a ledger board, unless I was adding some L-flashing to sit over the deck boards, or ledger board. I am sure the deck pros will chime in soon.....I do kitchens but I have built a few decks in my time.
A.W. Davis Construction Co. http://www.awdavisconstruction.com/ Your friendly remodeling contractor |
Re: Cutting Stucco
Just looked at the plans posted on your website. That looks like it will be a fun project to do!
Ohhh and your side elevations say you are to install a 2x10 ledger not 2x8
Re: Cutting Stucco
whoops! That Side View is an older version, showing that 2x10 as the ledger. My set of drawings for the Permit show a 2x8 ledger.
General Contractor
Re: Cutting Stucco
I would cut a straight line above where the ledger would sit and insert a flashing a after the ledger is installed.
Re: Cutting Stucco
How do you handle the weep screed continuity when you cut out the stucco like that?
Re: Cutting Stucco |
Trade: Custom deck builder
Re: Cutting Stucco
We use spacers now on stucco. It is normally imposible to get the flashing behind far enough up to be effective.
Re: Cutting Stucco
Robert, how do you seal around the lags/bolts at the stucco?
here in San Diego, rain, and water damage issues aren't really an issue like they are in other parts of the world where it rains once and awhile! I've usually always just lagged right to the stucco, with some good caulking behind the ledger at each of the penetrations. I just recently heard about putting some self adhesive membrane behind the ledger, that sounds like a very good idea. Once and awhile I've cut an angled kerf into the stucco for a piece of copper, glued in with caulk. this time, see that little balcony over that mudroom? We'll have to remove the balcony and lower the new little roof down to underneath the new ledger, so we'll have a section of stucco cut out already, so we'll just continue the cut across the wall for the rest of the new ledger. Actually, I've never removed the stucco for a ledger like this before MD, I'm hoping to cut just deep enough to not cut the paper, and then do flashing like this. If I do cut the paper, I don't think it'll be an issue with the way the flashing will work. I might use some tape though if I do cut the paper. I'm just hoping I can stuff the top flashing up under the stucco enough.
http://woodsshop.com/ Last edited by Joe Wood; 09-03-2007 at 12:50 PM. |
Super B
Re: Cutting Stucco
#13 | |
Trade: Squirrel Handler
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
Re: Cutting Stucco
The spacers are 5/4 x 6 PT cut to 9" (if 2x10 7" if 2x8) Then we cut an angle on it usually 30* to make it into a ^. Nail them on at 16" O.C. (or whatever your bolt pattern is) And caulk the living piss out of it on the top and sides. Then install your ledger on top and use 6" lags, or timberlocks (I like to use 3 timeberlocks) The space allows water and such to run behind the ledger.
#15 | |
Super B
Re: Cutting Stucco
That sounds pretty good Robert. This time we'll use LedgerLok, 2 every 16".
Re: Cutting Stucco
The reason I use the timberlocks in these cases is because the ledger locks dont come in 6" and you really need that extra 1" because of the 1" block. That is why I add 1 extra (BTW you may need an engineer stamp to approve this plan, we had to get one)
#18 |
Re: Cutting Stucco
The weep screed is typically installed at the base of the stucco, not midlevel so you wont have to worry about it, however I have seen stucco expansion joints installed on multi level units that interfere with the ledger when installing z-flashing
#19 | |
I would think as long as the cable spacing isnt more than 4" than it meets the minimum code requirements and is fine.
#20 |
Re: Cutting Stucco
Nope, already pulled the Permit last Fri. :-)
I was wondering if they'd allow the Cable Railing, but they did. The Plan Checker almost made me get engineering though for the cable and its connections.
| 1 coat vs. 3 coat stucco finishing | janrickey | General Discussion | 12 | 07-17-2011 11:22 AM |
| Tight Space Stucco Question - Undershot between roof sections | CGofMP | Construction | 3 | 03-24-2009 09:10 AM |
| Some questions about painting outside stucco?? | Zeebo | Painting & Finish Work | 10 | 09-20-2006 08:09 AM |
| Determining Manhours for rolling vs. cutting - your suggestions would be helpful | Zeebo | Painting & Finish Work | 9 | 06-02-2006 06:12 PM |
| Rubber membrane behind ledger on stucco? | Woodcrafter74 | Decks & Fencing | 6 | 01-31-2006 08:27 PM |
