Concrete For Post Holes: How Many Holes Before It's Cheaper To Have It Delivered?
I've always mixed concrete on site in a wheelbarrow (don't work with it much), but just sold two neighbors on 330 feet of new fence (@46 holes, w/gates & arbors).
I'm thinking that it will be cheaper (labor wise) to have my guys running the crete from the truck to the holes rather than mixing 46 80 lb bags. But at about what point does it cross over (i.e. it's cheaper to just mix the bags on site?)
Scott (the ex-grunt-tanker-jarhead guy) |
Re: Concrete For Post Holes: How Many Holes Before It's Cheaper To Have It Delivered?
Bags of concrete, X hours = cost "A"
Yards of concrete X hours = cost "B". Here, we have to buy 3 yards, even if we need only a yard of concrete....truck minimum.
Trade: Custom deck builder
We can order less than 3 yds we just pay a short charge (usually about $90). Personally I would use a line pump truck. This would cost me approx $800-$900 for what your talking about. It may be worth it to you... It may not. It all depends upon how long it would take to mix by hand and how much your paying your guys.
#4 | |
Re: Concrete For Post Holes: How Many Holes Before It's Cheaper To Have It Delivered?Quote:
I'm getting a truck for this job - but also have a small deck job (9 holes) where I'll mix onsite. Just wondering where the cross-over is...
Scott (the ex-grunt-tanker-jarhead guy) Last edited by Panzer5; 07-08-2009 at 09:23 AM. Reason: better response |
#5 | |
Lack Of All Trades
Trade: Professional handyman services
To me, I would not have the concrete trucked in-- unless all holes are dug first. I prefer to dig holes 1 by 1, then set posts and level, then drop bag of concrete in the hole, then add water to the hole. I take time to follow the mason lines and stake the gate posts for complete levelness. With it being trucked, there must be complete coordination of your helpers so as to not rush and have the posts set too fast without being level and set at exactly 8' apart. The post are the most important part of the job. If they're not right, the finished project won't look right. Good luck. |
#6 | |
Lack Of All Trades
i just use the fast set bags of 'crete--you pour the dry mix in the holes, set the posts, then add water with water hose. |
Trade: Construction
You only use one bag of concrete per post? That's some shallow or narrow holes...
How many guys do you have? This kinda changes the equation a bit. Take into consideration whether or not your concrete truck charges by the minute for sitting there - Have you looked into renting an elec. mixer? You don't have to worry about truck time or min. del. charge or the time it takes your guys to hand mix. Mac |
#8 | |
Lack Of All Trades
Trade: Carpentry Contractor
Building fences, I'm not quick enough, getting the fence posts lined up, and plumb, to use a constantly fed load of concrete from a truck.
I also premix all of my concrete prior to putting it in the hole, using a electric mixer or wheelbarrow. That's probably why I don't build many fences these days. |
Trade: Construction
you lost me - manufacturer of what...fences?
An 8" dia. hole gives you about 2" of concrete on the sides of a 4x4 post, less if you're using 4x6s...not nearly enough support for me. And you toss it in dry and water it down? We build differently is all I can say. Mac |
Trade: home improvements and renovations
Get a mixer, portland and some navijack. Lowest cost and go as slow or fast as you want.
#12 | |
Lack Of All Trades
![]() sot. were layin' a fence---not a deck
#13 | |
Lack Of All Trades
![]() you life will go much easier now.... |
Smart phone? Scan me!
Trade: Painting/Framing/Drywall
/\ en englesh por favor!
Lack Of All Trades
No- hab- leh- es- spanyo? Me neither.
That's just the pic on the big box website.
Trade: Residential
I may open up a whole new can of worms with this one, but fences I have installed, I have used #2 crushed limestone for a post base and to surround the posts. I learned that one from a company that only builds fences. It is supposed to avoid any chance of problems with frost heave. Yes, I know dig post holes down below the frost line, but the thinking is this: Who's post holes are always perfect cylinders? Admittedly, mine often have a little bit of a cone shape, especially at the top, leaving the chance of heave. Stone would certainly eliminate the rush of setting posts / placing concrete or hand mixing bags. See this pics on this link to see what I'm getting at. I have seen this concept addressed on line on several different websites in the past, but this was the only one I could find today. (Alapaca's...what???) BTW, 1st time poster, short time reader from southeast michigan also. Don't beat me up too bad!
Trade: Residential
Ooops...the link...
it wouldn't let me put the link in due to being too new...it's gatewayalapacas.com for those who really want to know... |
#18 | |
Lack Of All Trades
This is an important step. Thanks fo that! Last edited by Darwin; 07-08-2009 at 03:13 PM. |
#19 | |
I builds'em
Trade: Renovations & Decks
Ryan |
#20 |
I builds'em
That's not a step. He's using it instead of concrete.
Ryan |
| concrete slab on paved drive? | durham | Concrete & Paving | 7 | 09-13-2008 11:28 PM |
| Advice - concrete Pool Deck coping | ejleonard | Masonry | 4 | 06-17-2008 05:18 PM |
| Concrete countertop acid stain problem | AHS | Concrete & Paving | 12 | 05-09-2008 02:14 PM |
