Code For Glass Panel Railing
Old 07-05-2012, 01:55 PM   #21
GC/carpenter
Californiadecks's Avatar
Rewards Points: 8,308
Re: Code For Glass Panel Railing
Originally Posted by TLHWindows
I know I read in my last glass magazine that a lot of codes are going to start turning to laminated glass instead. The reason is for safety since laminated doesn't "break". Don't know if you might want to consider that in your next job or not.
This just might be the answer, is laminated glass hard to get and is it cost effective compared to regular tempered? Thanks
Californiadecks is online now
Old 07-05-2012, 03:29 PM   #22
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,112
This is an interesting problem in dealing with the local building departments, plan checkers and engineered products from venders, Trex specifically.
The problem we are having with this is that the plan checker is insisting that the infill (glass) needs to be supported on all four sides, he says that this is prescriptive but I can't find reference to this in the CRC or the CBC 2009.
His insistence on the prescriptive is a little odd as he also says that since we have an engineered and tested product that that would be acceptable.
A Trex representative will be going with us to the BD on Monday to help straighten the issue out which I think is terrific on their part. We will all gain a bit more invaluable information on dealing with these things for the future.
Andy.
ScipioAfricanus is offline
The Following 2 Users Say Thank You to ScipioAfricanus For This Useful Post:
Californiadecks (07-05-2012), hdavis (07-05-2012)
Old 07-05-2012, 05:06 PM   #23
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
go here and click on the link:
http://www.crlaurence.com/apps/conte...ies/index.html
than go to the pictures in this section:
STANDOFFS, GLASS CLAMPS,
SPIDERS AND FITTINGS
and you'll see what i was reffering to
killerdecks is offline
The Following User Says Thank You to killerdecks For This Useful Post:
Old 07-09-2012, 03:54 PM   #24
TLHWindows's Avatar
Trade: Windows Doors Siding
Rewards Points: 732
More than tempered glass, depending on were you get it from. Shouldn't be hard to get.
Either from your local shop, or if you are sneaky enough, from a distributor, which is where I get it from.
Cool, lets put some fabric over a window and let a hurricane throw some stuff at it. I'm sure it will protect you and your windows.
http://www.gulfbreeze-windows.com
TLHWindows is offline
Old 07-09-2012, 09:12 PM   #25
Eater of sins.
with the help of the Trex rep. Californiadecks got it passed this morning, no worries.
The plan checker could see now that the testing and Trex in-house engineering clearly showed that there is a 3-4" gap on the sides of the infill and it all met code.
Plan checkers are interesting people, he does have the authority to have said no and required that the infill be done as he had wanted before but I think he realized that the city's liability would not be compromised by allowing the engineering to stand.
Andy.
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
griz (07-09-2012)
Old 07-09-2012, 09:21 PM   #26
Dirtywhiteboy's Avatar
Rewards Points: 8,044
Nice update.
Dirtywhiteboy is offline
Old 07-09-2012, 09:27 PM   #27
GC/carpenter
Andy.
Thanks again Andy, I got to say, you did a great job on those plans too.
Old 07-09-2012, 09:38 PM   #28
Fire up the BBQ
griz's Avatar
Rewards Points: 1,672
Nice work Andy...
Now you guys will just have to convince the inspector...
griz is online now
ScipioAfricanus (07-09-2012)
Old 07-18-2012, 09:35 AM   #29
rdr8887's Avatar
Rewards Points: 250
Just call the manufacturer of the railings. Get the city something in writing from the manufacturer staring the installation is fine. Provide that to your inspector and see what happens. Most times they are just wanting to cover their self legally. Providing that letter puts everything on the manufacturer.
Make sure the letter is signed and includes engineering calculations. If they don't accept it, ask them to provide a copy of the code you are violating. If it doesn't work after all, do what they want and get the owner to reimburse you. I'd call this a legitimate change order. There would have been no way to know the hoops that this inspector is making you go through.
I can do anything your bank account will allow....
rdr8887 is offline
Old 07-18-2012, 09:38 AM   #30
rdr8887's Avatar
Rewards Points: 250
You beat me to the punch. Good job.
rdr8887 is offline
Old 07-27-2012, 08:40 PM   #31
GC/carpenter
Pictures of glass panel rail
Still have skirting to put on but otherwise all rapped up
Old 07-27-2012, 09:10 PM   #32
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 476
Beautiful work.
So what kind of post, beam hardware do you have to use in So Cal.?
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
Old 07-27-2012, 10:06 PM   #33
deckman22's Avatar
Trade: Deck Builder
Rewards Points: 5,884
Nice work on those glass rails.
Question on the decking. Why is the decking run on such a slight angle? Makes the decking look skewed at picture frame over by those two doors.
Deckman
www.alscustomdecks.com
deckman22 is online now
Old 07-27-2012, 10:22 PM   #34
GC/carpenter
Originally Posted by redwood
Beautiful work.
To be honest that was the first time I used a notched post and beam. Ive always used solid beams. I was cool to try something different
Old 07-27-2012, 10:32 PM   #35
GC/carpenter
It's hard to see but the corner of the house is not a ninety degree angle so I ninety degree to one side. And made the landing square to the garage door. If I made the landing run parallel with the decking it would of been out over the concrete steps, would of been a mess. My designer and I both decided this was the best application.
The tree had a lot to do with that shape also.
Old 07-27-2012, 11:41 PM   #36
GC/carpenter
Beautiful work.
I think I remember you mentioned in another post how you prefer solid beam and post caps over notched. I totally agree with you on that. This was the first time I ever tried to get the city to pass this type of beam. It seems to be more popular in other states. They were mostly concerned with railing glass not stopped on all four sides.
Old 07-28-2012, 12:08 PM   #37
GC/carpenter
After further thought you brought something very important to my attention. I hate to redo my work, however, I will go back on Monday and skew the lower decking planks to run parallel with the upper decking. I don't need to change the framing just the direction of the planks on the landing only. My thought was before, to run the planks on the landing with line of travel, but after you brought it to my attention you're right, it doesn't look right. Thanks for the constructive criticism. The HO didn't even notice but now that I see it, that is all that matters and I will fix.
Combination Panel Install thom Electrical 8 07-04-2011 12:40 PM
New service panel from ex.panel galixy250 Electrical 1 12-20-2010 09:29 PM
wainscoting on stairs- panel spacing keith mathewson Finish Carpentry 0 06-23-2010 09:07 PM
State Adopts MANDATORY Green Building Code BKFranks General Discussion 14 01-14-2010 01:51 PM
sub panel or not? mikeybobo Electrical 16 11-30-2008 06:49 AM
