Certainteed Railing
Old 05-08-2007, 04:43 PM   #1
jeclarke's Avatar
Trade: deck builder
Certainteed Railing
I'm about to install a Certainteed Evernew Railing system on a procell deck. On 1 section, the railing I need is 10' minus a few inches. They sell a 10' railing section. Is this 10' section going to be stable (no sagging) or should I put a post in the middle and have 2 shorter railing sections?
jeclarke is offline
Old 05-08-2007, 06:24 PM   #2
Carpenter/fencing
nywoodwizard's Avatar
Re: Certainteed Railing
I install certainteed railings quite a bit,only once have i installed a 10' pc ,and it was between two brick collums,it was pretty strong,and no sagging,the aluminum inserts are still pretty ridged. your post installation is very important,are you using there metal post supports? wood post ? It must be well blocked and bolted in either installation and it should be fine.its obvious it will be a little stronger with a line post,but the 10' should be fine for normal use.
Learning without thought is labor lost; thought without learning is perilous.
nywoodwizard is offline
Old 05-08-2007, 09:39 PM   #3
jeclarke's Avatar
Trade: deck builder
nywoodwizard,
thanks for the reply. I am using the metal pipe posts bolted to the PT structure. You are right that adding a line post in the middle will make it stronger.
I may add a post in the middle just for the extra strength. Have to think about it a little more.
jeclarke is offline
Old 05-08-2007, 10:19 PM   #4
Carpenter/fencing
Originally Posted by jeclarke View Post
nywoodwizard,
you're welcome ,and goodluck
Old 05-08-2007, 11:07 PM   #5
The Deck Guy
Greg Di's Avatar
Instead of adding a post, why don't you install two "cripples" 1/3 of the way in beneath the bottom rail and the top of the deck. These are either included in the kit, are available as an extra, or you just cut down a spare baluster. The cripples prevent long sections from flexing down if someone puts weight on the rail.
Greg Di is offline
Old 05-09-2007, 06:20 PM   #6
Carpenter/fencing
Its not the sag that could be a problem its,its 5 people leaning against it and not securing the post properly,that could be a problem.
stairway railing job AGC Finish Carpentry 2 08-08-2007 12:36 PM
Metal Railing Paint sgrprince Painting & Finish Work 1 06-29-2007 01:43 PM
Cedar railing vulcan Decks & Fencing 2 09-22-2006 10:48 PM
metal railing finish failed problem? a68cudas Painting & Finish Work 9 06-06-2006 03:37 AM
Certainteed Shingles?? Junk?? schoolcraft Roofing 27 05-28-2006 02:05 AM
