Cable Rails
Old 11-01-2009, 10:37 PM   #1
deckman22's Avatar
Trade: Deck Builder
Cable Rails
Who do you all use for cable rails? Suppliers that is.
I seem to remember someone posting links but, I couldn't find that thread.
TIA
Deckman
www.alscustomdecks.com
deckman22 is offline
Old 11-01-2009, 10:49 PM   #2
BuiltByMAC's Avatar
Trade: Construction
Re: Cable Rails
Atlantis Rails and Feeney would be where I'd start looking. Feeney is local to me and I've seen ads in the Deck Builder mag for Atlantis... (with the caveat that I haven't had a client yet go for the cable rail option).
Mac
BuiltByMAC is offline
The Following User Says Thank You to BuiltByMAC For This Useful Post:
deckman22 (11-02-2009)
Old 11-01-2009, 11:43 PM   #3
redwood's Avatar
Trade: Carpentry Contractor
Re: Cable Rails
I use Feeney Cable wire.
http://www.cablerail.com/index_2.shtml
They are very helpful and do give contractor discounts. I have even given them layouts and they have planned all the wire runs.
I can't comment on whether they are the cheapest though. I don't know.
Allow a couple of weeks for delivery, as they make runs to order.
Mark
Los Gatos, CA
www.creative-redwood-designs.com
redwood is online now
The Following User Says Thank You to redwood For This Useful Post:
Old 11-02-2009, 08:53 AM   #4
deckman22's Avatar
Trade: Deck Builder
Re: Cable Rails
Thanks Mark & Mac.
I've had customers ask about cable rails before, but like you Mac, have never had one bite. A GC that I built a TT deck for had a cable rail put on it after I was done. He used SS post which looked pretty good. He had his men put in on so it can't be too hard to do as his men were about as sharp as marbles.
All that said I hope my customer likes the deckorators & I won't have to fool with the cables.
Deckman
Old 11-02-2009, 05:32 PM   #5
John Hyatt
John Hyatt's Avatar
Re: Cable Rails
I am biding a TimberTech job where the Wallet wants cable rail. I just cant see it seems like there is enough movement in the wire to rout out the holes in the post wrap. Still thinking. J.
John Hyatt is offline
Old 11-02-2009, 05:38 PM   #6
TimelessQuality's Avatar
Trade: GC/Remodeling
Re: Cable Rails
ferrule??
Wish I could play with that cool stuff... Not sure it would be code here
-Steve
"The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein
TimelessQuality is offline
Old 11-02-2009, 05:43 PM   #7
Chris G's Avatar
Trade: Porch and Deck Builder
Re: Cable Rails
http://www.stainless-steel-direct.co..._cable_kit.asp
"Neek...Neek...yoo-a-moronna Neek. Getta-da-fookin-a-jacka-ham!"
http://www.vicporch.ca
Chris G is offline
Old 11-02-2009, 09:29 PM   #8
John Hyatt
John Hyatt's Avatar
Re: Cable Rails
I have looked at sites like that,seen how they go together, how they look.
Looks like shetttola to me. All the silly wires going in strange directions down the stair way and around the posts. Stupid. Mabey on a com job but I am backing out biding it on that project hard times or no. JonMon
Old 11-02-2009, 10:28 PM   #9
redwood's Avatar
Re: Cable Rails
Jonmon, don't give up the ship. Cable railing is actually a easy install. Possibly quicker then any other railing, if you set it up right.
I think that you can get SS sleeves to put in the holes, if you are worried about the wire expanding the hole.
Mark
Los Gatos, CA
Old 11-03-2009, 06:37 AM   #10
Fine Deckbuilder
Clemens's Avatar
Trade: Deck business
Re: Cable Rails
Cable rail is very easy to install but it can get tricky for stairs. We use Feeney also with a few Atlantis systems here and there. They do sell sleeves. I would recommend it if you have a softer wood or angles.
We normally use ten rows spaced 3 1/4". Check with your county if it is allowed. We have only two counties in my area that approves the horizontal cable system.
Clemens
www.finedecks.com
Clemens is offline
Old 11-03-2009, 01:46 PM   #11
John Hyatt
John Hyatt's Avatar
Re: Cable Rails
Thanks Guys, I really should do what the Wallet wants.Will defentley look closer. J.
Old 11-03-2009, 07:39 PM   #12
Fine Deckbuilder
Clemens's Avatar
Re: Cable Rails
John, E-mail me your layout and I can help you with that.
Clemens
Clemens is offline
Old 11-03-2009, 07:42 PM   #13
deckman22's Avatar
Trade: Deck Builder
Re: Cable Rails
That's where I'm at John, I don't want to loose a gravy job over cable rails. Mays well learn how to do it.
One of those links posted has what looks like a pretty simple system, screwing turnbuckles in the post.
Deckman
Old 11-03-2009, 08:13 PM   #14
deckman22's Avatar
Trade: Deck Builder
Re: Cable Rails
Clemens
www.finedecks.com
I see from looking at your site you've done a good bit of cable rails, very nice looking rails.
Do you always or just perfer to double post the corners? Besides the look I'm guessing another reason, ease of streching cable maybe.
I've seen the cable rails around so I'm guessing it's allowed here, something I should check on even tho this job is out in the country & no juridiction there. Travis county permits are a joke, all they do is check to see if the deck is in the flood plane, if not here's your permit for 50 bucks, no inspections of any sort.
A couple of more questions, why the tighter spacing, the 3 1/4"? Do you think you need a sleeve if using ipe 4x4's w/holes?
Deckman
Old 11-03-2009, 09:45 PM   #15
redwood's Avatar
Re: Cable Rails
I'm not Clemens, but I always double post my corners, regardless of the railing type.
I don't think that you would need sleeves with ipe. But you should ask Greg Di about drilling ipe posts. I always use redwood or cedar posts, with a cap to match the decking.
The 3 1/4" spacing is to prevent that 4 " sphere from getting between the wires. They are not rods, there is some play in there.
Mark
Los Gatos, CA
Old 11-04-2009, 05:32 PM   #16
John Hyatt
John Hyatt's Avatar
Re: Cable Rails
I pluged the price in over the phone they were sucking air so hard there next breath came hard. I figured in using composite post wraps shimed inside and the metal sleaves with washers 3'' oc cable rail on 36'' high, earthwood TT with the clips.
You would have thought I sugested wanting to eat there first born,total ungule delam on the price. They both got on speaker to tell me what I rip off I was trying to be. Guatta Love It JonMon
Old 11-04-2009, 06:43 PM   #17
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
Re: Cable Rails
I'm going to retract my thoughts, before I even share them.
Too public of a forum.
Glad you didn't waste the fuel visiting with them.
~Matt
BreyerConstruct is offline
Old 11-19-2009, 08:58 PM   #18
Steve Unkie's Avatar
Trade: REMODELING CONTRACTOR
Re: Cable Rails
Hi fellas,
We use these guys.
http://www.stainlesscablesolutions.com/
Max is great and they ship within a few days of ordering.
Here's a few pics.
http://unkieconstruction.com/pictures/show.php?id=25
http://unkieconstruction.com/pictures/show.php?id=137
Steve Unkie.
Steve Unkie is offline
Old 11-19-2009, 09:14 PM   #19
#1 stunner
Static Design's Avatar
Trade: Design/Build
Send a message via AIM to Static Design
Re: Cable Rails
I love the cable railing the stuff is really easy to install plus it looks amazing. The only thing I hate is how expensive the connectors are, the cable isn't the bad part it's all your connection pieces. I will look for some camera phone pics here in a minute of the last railing and cable system I completed, I will take better ones tomorrow so you can actually see the connections: I used sleeves for all my angle pieces where stairs or a change of elevation was an issue.
Will do autocad/ 3d work for food.
SD on facebook... click here
Static Design is offline
Old 11-23-2009, 02:22 PM   #20
chief pencil holder
Scribbles's Avatar
Trade: Custom Cabinet Maker, Handrail
Re: Cable Rails
Call Indital, they have a cable/post system called INOX, it is available in steel/galvanized/ and stainless. They will be able to help you out. Whatever you do don’t try to go cheap and use aircraft cable, the oil will leach out the middle and look like crap in less than a year, ask me how I know
Originally Posted by Leo G View Post
Ahhhhh, just buy it.
http://sacramentomillworks.com
Scribbles is offline
The Following User Says Thank You to Scribbles For This Useful Post:
Indital (10-31-2011)
High Speed Cable & P.O.T. Separation? redzthredz Low Voltage 11 12-01-2009 05:09 PM
Running DATA Cable, New Construction spoolin Low Voltage 31 10-16-2009 11:34 AM
Cable Rail Systems Greg Di Decks & Fencing 8 08-31-2009 10:05 AM
floor heat cable metal lathe floor mix carterarce Ceramic & Stone Tile 9 02-01-2009 11:51 AM
Satellite / Cable-TV exterior cable routing bob_cntrctr General Discussion 10 11-25-2008 02:31 PM
