Building A Deck Flush To The Ground
Old 06-14-2007, 07:57 PM   #1
Kingflynn's Avatar
I've never built a deck so close to the ground that it didn't need footings and support posts. Now if one was to build a deck so that the decking is just a step above grade (7"), how would you do it? would you still need concrete footings, or could you dig railroad tie sleepers over crushed stone for your support?
Kingflynn is offline
Old 06-14-2007, 08:46 PM   #2
Forry's Avatar
Trade: General Contractor, Remodeler
Re: Building A Deck Flush To The Ground
Concrete "grade beams" w/ pt 2x4 sleepers, then joists.
Forry is offline
Old 06-15-2007, 01:27 AM   #3
BuiltByMAC's Avatar
Trade: Construction
12"x12"x8" concrete deck blocks w metal strap - tops of concrete just above grade (in a hole with 4" packed gravel beneath them)
Heavy duty landscape fabric under entire deck with holes cut out for top of concrete blocks
4x4 beams, 2x4 joists, no span greater than 4', blocking over beams
2x decking will round you out at just over 8" above grade, 5/4 composite would be slightly lower...
This was a little ground level Timber Tech deck I put together that way.
Mac
Building a deck flush to the ground-70701-02.jpg   Building a deck flush to the ground-70702-04.jpg
BuiltByMAC is offline
Old 06-15-2007, 04:30 AM   #4
Deck Cleaner
PressurePros's Avatar
Trade: Deck Cleaning, Staining, Restoration
Something to think about from my perspective. Design as much ventilation as you can into the structure. These types of decks so close to grade do not last long (especially cedar). Finishes do not hold up and they are always mold covered. A compsoite might be best. ::cringe::
Ken Fenner
Pressure Washing PA
Roof Cleaning Services PA
PressurePros is offline
Old 06-15-2007, 10:08 AM   #5
gregj's Avatar
Good location for a brick or flagstone patio instead of a deck.
gregj is offline
Old 06-15-2007, 01:34 PM   #6
Kingflynn's Avatar
All good responses. Thanks. Looks nice Mac. I like the corner. Looks like a nice spot for a water feature.
Old 06-15-2007, 07:38 PM   #7
Chris G's Avatar
Trade: Porch and Deck Builder
Is frost heave not an issue with low level decks?
Chris G is offline
Need help with a shocking outside waterspout Badoish Electrical 23 12-27-2008 04:18 PM
ground level deck Tom M Decks & Fencing 3 07-02-2007 09:38 PM
Deck Building Question brewsterb Decks & Fencing 2 06-21-2007 01:29 AM
Deck building as a career? fishscaper Decks & Fencing 13 03-20-2007 10:08 PM
building a screened porch atop a deck 72chevy4x4 Decks & Fencing 1 02-21-2007 10:29 PM
