Trade: roofer
Boat Dock
Is there any thing better than PT lumber for the joist and post?
its on a fresh water lake and will be using Trex decking to match house |
Trade: Granite & Marble Sales & Installation
Re: Boat Dock
I built mine with stainless steel posts. Of course, everything I do is a bit 'overkill'
but when the lake rose to dangerous levels, seemsMs. Overkill's pier was inundated with all the neighbor's boats. Also, it had wheels and sat on rails so removing it was a peach! Oh...fresh water lake, as well. |
Re: Boat Dock
PVC posts with rebar and concrete are popular here. Jet them down as far as possible or prudent before filling. You will need hydraulic cement until you are above the waterline, some folks may differ on this.
PT is still your best bet on crossmembers and any stringers. The deck surface can be whatever the customer wants to afford. Be sure to have this selection prior to doing the substructure. Some of the plastic stuff says 16"OC but should be on 12's here.
ConradLumberCo
Trade: Supplier
Re: Boat Dock
Trimax Structural Plastic Lumber. Check it out.
#5 | |
Trade: Home Improvement
Re: Boat Dock
Does it need to be removed in winter???
#6 | |
Trade: roofer
Re: Boat DockQuote:
Insert title
Trade: Doors-Windows-Decks
Re: Boat Dock
just built a 60' long by 3' wide (collect boats). I used pt for framing and timbertech for decking. If you are going to use floats check out e-bay, I found a vendor that sells for about 1/2 of the price of the boat stores......just check for shipping damage before you sign for them.
| Dock posts in water.... | TheFishGuy | Decks & Fencing | 12 | 07-20-2007 09:00 AM |
| Setting dock posts | TheFishGuy | Carpentry | 3 | 07-08-2007 11:21 AM |
| Boat paint. | gideond | Painting & Finish Work | 3 | 06-10-2007 12:09 PM |
| anyone with a boat or ski in central/south nj coast | Bone Saw | Help Wanted or Looking For Work | 4 | 03-08-2007 09:31 PM |
| fact or fiction dock wiring | hurricaneflyer | Electrical | 17 | 11-16-2006 10:38 PM |
