Bending Composites To Radius
Old 06-10-2009, 10:48 PM   #1
ClemS's Avatar
Trade: Framing
Does anyone have any amount of experience bending composites to a radius? I'm bidding a job that's all curves out of trex brazilia. The curves are very slight, about an 18' radius at the sharpest. I feel pretty confident getting the bends - the only trouble area may be butt seams.
This is what I'm thinking of doing.
Glue and pocket screw the boards together and then bend. Any thoughts on the process from people with a little more experience in this greatly appreciated.
clem
ClemS is offline
Old 06-10-2009, 10:59 PM   #2
KemoSabe
loneframer's Avatar
Re: Bending Composites To Radius
clem
I'm not familiar with the properties of Trex, but I bent Correct Deck around an 11' radius, but needed to rip it to 3.5" first. Still broke several boards in the process. I'd suppose a 100% vinyl product with no wood fiber content would give better results. I don't know if the radius will be obvious but these are the steps.
loneframer is offline
Old 06-10-2009, 11:09 PM   #3
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
Take your time.
Keep the boards in the sun.
Consider using a heater to warm them.
Work with help.
Use ratchet straps to hold them in the shape till screwed AND COOL!!
Buy extra boards.
Realize that you most likely underbid it, if you're asking this question.
It will most likely be a learning experience... but you'll know for next time!
~Matt
BreyerConstruct is offline
Old 06-11-2009, 12:04 AM   #4
Teetorbilt's Avatar
My experience with Trex is zero other than seeing the docks around here and noting that 16" centers is not enough support in the SoFL sun. Heat is definitly a factor.
I have an upcoming project that involves forming 4" SH 80 PVC pipe to contours. I plan to build a 20' oven to bring the 18' PVC up to temp for bending. I have done this before for curing thermoset epoxies for spars. It really helps if you have a turkey fryer or lead smelter (same thing here).
Build watertight box, attach heater unit and recirc pump, find the magic temp. You can do this with scraps and gloves and it gives you the most even temp.
Plan 2, Air system. Same box, needs lid, heat control uneven even with booster fan. Can be done with Ol' lady's hair dryer over time.
Albert Einstein
Teetorbilt is offline
Old 06-11-2009, 07:21 PM   #5
ClemS's Avatar
Trade: Framing
I want the job so I'm not going crazy with the numbers even though there's a lot of bending. There's 5800 sf of deck to be done so I think I'll get a system going after a day of putzing around.
Thanks!
Originally Posted by BreyerConstruct View Post
Take your time.
Work with help.
Buy extra boards.
~Matt
ClemS is offline
Old 06-11-2009, 07:24 PM   #6
ClemS's Avatar
Trade: Framing
Because of the volume I'm leaning towards the hot air approach. I can rig 2 or 3 kerosene heater to melt this stuff in bulk as I'm installing. Thanks for the info. I'm bound to be closer that 16oc on most of the deck due to the radius.
ClemS is offline
Old 06-11-2009, 07:26 PM   #7
ClemS's Avatar
Trade: Framing
Originally Posted by loneframer View Post
I'm not familiar with the properties of Trex, but I bent Correct Deck around an 11" radius, but needed to rip it to 3.5" first. Still broke several boards in the process. I'd suppose a 100% vinyl product with no wood fiber content would give better results. I don't know if the radius will be obvious but these are the steps.
yes I can kind of see the curve. I think the new trex is much like the other composites so if I heat the stuff up thoroughly I shouldn't be in much worse of a shape than laying it straight. If I win the bid I'll post pics
ClemS is offline
Old 06-11-2009, 07:51 PM   #8
John Hyatt
John Hyatt's Avatar
Teetor, I have some tract time bending wood ,none with manmade stuff. With wood the whole idea is to mimamize stress on the final outcome so you get less spring back and as little as possible lams coming lose or big cracks down the road.
I see pictures of fancy spancy composite projects with radical radis going on and Im just wondering how they do the first year. It should be the same as coming out of the extruder but even that has to be cooled down slowley. In fact the cool down would seem to be more important than the heat process. J.
John Hyatt is offline
Old 06-12-2009, 02:38 PM   #9
Five Star's Avatar
you can buy temp controll heating blanket pads ive read work great!! IN JLC MAG
5800 sq ft..What did they hit a LOTTERY!!???
or did they knock down the house and decided to live on a deck?
LOL GOOD LUCK Make sure you get payments on a steady basis!!
The Bitterness of Poor Quality Remains longer
Than The Sweetness Of A Low Price Is Forgotten
Five Star is offline
Old 06-12-2009, 10:19 PM   #10
ClemS's Avatar
Trade: Framing
thanks. it's some sort of a municipal compound. the deck and a full half circle with a couple of handicap ramp to go up the levels. right now i'm still waiting to get the job, getting payments will be the next battle
ClemS is offline
Old 06-13-2009, 12:03 AM   #11
SSCOTTCONST's Avatar
Trade: General Contractor/Carpenter
Heatcon makes a heat forming blanket system that heats pvc composite boards to the correct temperature to bend any radius necesarry. But boards shrink while they cool so it is a good idea not to seem anything for at least a few hours.
SSCOTTCONST is offline
Bending AZEK Trim hailey Windows, Siding and Doors 5 12-13-2008 05:19 PM
Bending AZEK Trim and Moulding hailey Finish Carpentry 1 12-11-2008 05:54 PM
Matching a Radius TakePride General Discussion 15 10-29-2008 07:23 AM
Radius Calculations????? ETConstruction Carpentry 3 09-10-2008 06:43 AM
CPVC bending radius Jess Plumbing 17 12-01-2006 11:33 AM
