Bending Composite Decking
Old 06-28-2008, 06:58 AM   #1
tcleve4911's Avatar
Trade: Remodeling contractor
Rewards Points: 1,008
We're designing a deck platform for an above ground pool.
The customer wants the decking to follow the curve of the pool.
It's an 18' diameter (9' radius).
The platform deck will be 12' along the pool so 18' - 20' decking boards would be bent & contoured in one piece.
Has anyone here bent composite boards that much?
Got some tricks to share?
Thanks. Will post pics.
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 06-28-2008, 08:34 AM   #2
JonM's Avatar
Rewards Points: 1,216
Re: Bending Composite Decking
Never used one...but I saw this advertised... http://hc.heatcon.com/downloads/Heat...00-300_Web.pdf
JonM is offline
Old 06-28-2008, 09:44 AM   #3
LRG WoodCrafting
Leo G's Avatar
Trade: Woodworker Extraordinaire
Rewards Points: 8,245
Just multiply the price by about 5 times to deal with the extra time you will need to bend the material. Then show her the difference in price between straight with angled cuts and true curves. That should change her mind pretty quick on which one she will choose. If she still wants the curved you at least have some extra money to buy the specialized equipment to heat it up.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 06-28-2008, 10:10 AM   #4
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
Rewards Points: 1,000
Ditto what Leo said.
~Matt
BreyerConstruct is offline
Old 06-28-2008, 06:53 PM   #5
BuiltByMAC's Avatar
Trade: Deck guy
Rewards Points: 2,270
The only real success I've had w/ bending on that tight of a radius was to rip the deck boards into thirds, bend and screw the rips together from the side. I haven't purchased one of those $1000 heating blankets though. The ripped edges weren't very noticeable at all once they were screwed back together.
Edit to add: I wouldn't give her two prices and try to talk her out of curves. If that's what she wants, maybe she wants it enough to pay for it. Give her the price for curved and judge her reaction at that point. Maybe it will be out of her price range, maybe not...
Mac
Bending composite decking-curved_caprail-01.jpg   Bending composite decking-pict1534-01.jpg
BuiltByMAC is offline
Old 07-02-2008, 05:17 PM   #6
Paul Nee's Avatar
Trade: Home Improvement contractor
Rewards Points: 25
I've asked some dealers in the past and they told me to use sonotubes. You have to create a tunnel whatever the lenght of your board. Then use a kerosene turbine style heater. They said it softens them after about 1/2 hour.
Paul Nee is offline
Old 07-03-2008, 12:20 AM   #7
BuiltByMAC's Avatar
Trade: Deck guy
That's the stock answer - unfortunately, it doesn't work. The end next to the heater get burned, the other end is stone cold, board still snaps when you bend it. I don't think any composite manufacturer has actually tried that method, they just think it'll work so that's what they suggest!
You can get a more even heat just laying the board on asphalt or concrete on a hot day. For gentle curves (+/- 20' radius) that method works. It's the tight curves that everybody wants and those are the toughest to create...
Mac
Old 07-03-2008, 05:19 PM   #8
Mac's correct, skip the sono tube, use a culvert, rotate the board every 15 minutes... it might take up to 2 hours to get it cooked to the center.
~Matt
Procell-Azek decking by far best composite TurnkeyConst Decks & Fencing 28 10-20-2008 09:22 PM
Composite decking gercon Plumbing 13 05-30-2008 08:05 PM
Composite decking gercon Decks & Fencing 8 05-25-2008 06:46 PM
Composite Decking 'Bright' MartyCD Decks & Fencing 13 02-01-2008 08:24 AM
Powerwashing composite decking??? dougchips Pressure Washing 3 02-12-2007 11:58 AM
