Attaching A Deck (With Caveats)
Old 09-07-2011, 02:47 PM   #1
tolken4's Avatar
Hoping you all can help with this one. Never ran into this exact issue before. I have framed around bump-outs and bays, but never had to stop halfway into one.
Building an attached deck 10 ft off the ground, 16' long x 12' deep deck. 13.5' length of the Deck will be attached with ledger to house thru brick veneer to band board with 5/8" bolts.
Drawing
However, the last 2.5' of the deck will end at a bump out. Client does not want a column at this point next to the house. How can this be framed so as not to ruin the "livable space" underneath.
The initial plan was to tie in thru the existing house floor joist sistering the deck joist to those and resting them on the foundation wall. This will no doubt be structurally sound, but I can't think of a way to make it ok to run those joist into the house like that without having water problems.
Drawing
Framed around a bump out, bay window, or fireplace, but never one that stops mid bump out?
Anyone have any sage advise, or am I missing an easy solution other than the post
tolken4 is offline
Old 09-07-2011, 02:55 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 666
Re: Attaching A Deck (With Caveats)
Why not just use a separate 2.5' ledger attached to the bumpout?
BTW, with a brick veneer, most areas these days require the use of Simpson DTT2s.
Tinstaafl is offline
Old 09-07-2011, 03:15 PM   #3
tolken4's Avatar
Thanks for the heads up on the Simpson DTT2s... It was my understanding, at least in my area, that attaching into a bump out or bay is always a no go.
Man I would love to be proven wrong on that one though.The plans were approved as is, but I just don't want a call back on water damage.
tolken4 is offline
Old 09-07-2011, 03:32 PM   #4
rock16's Avatar
Trade: Commercial Exteriors & Multi Family Remodel
Rewards Points: 274
This thread may help address your waterproofing concerns.
http://www.contractortalk.com/f50/wa...d-deck-102183/
rock16 is offline
Old 09-07-2011, 06:09 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 666
Wups, that was my dain bramage kicking in. You're right, that most likely wouldn't fly. Sorry, with no post there, I have nothing else to suggest that isn't covered in that thread Rock refers to.
Old 09-07-2011, 06:12 PM   #6
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
i don't think my lumber yard stocks Simpson Caveats,probably special order thing
Tom Struble is offline
ScipioAfricanus (09-07-2011)
Old 09-07-2011, 06:22 PM   #7
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
We attach to a cantilever all the time, we pull the bottom off and reinforce with an engineered detail that has an engineers stamp. Tell the HO that if he wants no post then pony up for the engineer.
RobertCDF is offline
The Following User Says Thank You to RobertCDF For This Useful Post:
CookeCarpentry (09-07-2011)
Old 09-07-2011, 11:16 PM   #8
AutumnWood Inc.'s Avatar
Trade: Deck Builder
Rewards Points: 550
Robert
I have a similar issue coming up with a deck where we need to attach to a cantilevered bay. I remember you posting a picture of a job you did where you beefed up the bay for the deck attachment. Can you share any picture or ideas of what you had to do get this work.
Thanks in advance !
AutumnWood Inc. is offline
Old 09-07-2011, 11:19 PM   #9
RobertCDF's Avatar
Originally Posted by AutumnWood Inc. View Post
Robert
Thanks in advance !
PM your email or just email me and I will send over the details.
Old 09-08-2011, 09:31 AM   #10
tolken4's Avatar
Robert, sent you a PM, I would appreciate that as well if you could.
Thanks for everyones feedback,
Steve
tolken4 is offline
Ipe deck Clemens Decks & Fencing 64 06-21-2017 12:13 AM
Trex Deck damage ?'s Celtic General Discussion 15 11-02-2009 07:45 PM
Winter Deck in Montral mat casters General Discussion 3 10-19-2009 07:19 PM
attaching deck ledger to brick veneer house eric at mrw Decks & Fencing 6 01-24-2008 10:56 PM
Attaching deck ledger to new construction Woodcrafter74 Decks & Fencing 12 01-07-2006 09:41 PM
