Attaching Balusters To Top Of Treads?
Old 04-04-2009, 12:00 PM   #1
Chris G's Avatar
Trade: Porch and Deck Builder
A customer asked me if I could attached balusters to the top of the stair treads, (like an interior stair). I just mumbled some sort of vague answer to her, which I think bought me some time
Anyhow, has anyone done this. aside from making it hard to clear off debris and creating a point for water to perhaps settle and rot the baluster, are there any other drawbacks?
"Neek...Neek...yoo-a-moronna Neek. Getta-da-fookin-a-jacka-ham!"
http://www.vicporch.ca
Chris G is offline
Old 04-04-2009, 12:52 PM   #2
bmcquin's Avatar
Trade: deck builder
Re: Attaching Balusters To Top Of Treads?
Chris,
If and that is a big "if" I were to do this I would use Deckorators as they have the connectors that screw to the 2x4's on a handrail and they would work fine for fastening to the treads. You would have to buy several different lengths in the balustrade to make it would work.
Also, the debris on the stairs would not be blocked as much by a 3/4" dia. tube as by a 2x2 and no rot problems.
bmcquin is offline
Old 04-04-2009, 01:33 PM   #3
deck king's Avatar
Trade: deck builder
I would not attach the balusters to the tread. On interior stairs you have 2 fixed points the stairs go in between and no exposure to the environment. On exterior stairs, you have one fixed point and one floating point ( being the ground expands with moisture and freezing).
The impact of a 100lbs person going up or down the stairs is about 400 lbs with each step. ( I don't remember the exact # ) That is alot of impact on each step which ( in my experience ) the balusters don't handle well, and will be a bad example of your workmanship.
deck king is offline
Old 04-04-2009, 06:08 PM   #4
Chris G's Avatar
Thanks guys, that makes complete sense now that you pointed out all the movement issues. I often say to my clients, about all sorts of things, that there is a very good reason why they haven't seen something before. And now I know what that reason is.
Chris G is offline
Old 04-04-2009, 06:34 PM   #5
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
I did it on a home I lived in about 15 years ago, a 100 year old 4 square. The above posters are correct but my railing still stands. I had stone pads under the bottom step. I did this because the yard was sand and very stable. I redid the entire front porch with materials I already had in my shop.
silvertree is offline
Old 04-06-2009, 01:31 AM   #6
KennMacMoragh's Avatar
Trade: Repair/Remodel
Send a message via MSN to KennMacMoragh
Originally Posted by bmcquin View Post
Chris,
And probably wouldn't give you the 200 lb rating that code requires for hand rails.
Just noticed you're in Canada, I don't know what the hand rail codes are there. But I'd imagine Canadian codes wouldn't allow that either.
KennMacMoragh is offline
Old 04-06-2009, 01:34 AM   #7
Why does she want it on top of the treads? I would tell her no, but you can protrude the balusters into the stringers then cut and notch your treads around each baluster, that way it would look like they were sitting on top of the treads. I'm sure you can think of creative ways to get the effect she wants.
Old 04-06-2009, 12:58 PM   #8
Golden Rule's Avatar
Trade: New Construction and Remodelling
If you want to go overboard. You can get zinc coated electrical conduit and find a local powder coating outfit to give you 3/4 balusters in absolutely any color you want. Of course if its a small job this is cost prohibitive. Then boar holes into to the top of your treads and lock your baluster's in. This will give you the 200 LB or whatever your area requires for force. I have done this on one deck...Unfortunately the the homeowners wanted a custom color of white.....and were not satisfied w/ the white that Deckorators has. The nice thing is you can make them to any length you want up to 10'. I'd post a pic but i need 15 posts lol and this is only #4.
Golden Rule is offline
Old 04-06-2009, 01:22 PM   #9
Do you have the pictures on photobucket or something like that? Then you can link them. That's kind of what I meant by protruding them into the stringers, cut holes in the treads and stick them through. I'd make them go to the bottom of the stringers though.
Old 04-06-2009, 01:35 PM   #10
Here is a pic...Its not real obvious that I bored holes into the top and bottom of the railing, but it is what did.
Old 04-06-2009, 02:18 PM   #11
Motorboatin' son of a ...
BKFranks's Avatar
Use LJ Smith dowel fast screws. Part #LJ-3076
http://www.ljsmith.com
If I were you I would explain that, yes, it can be done, but dissuade your customer by explaining to them the added cost of materials and labor involved to fulfill their request.
http://i40.tinypic.com/14y3mzm.jpg
BKFranks is offline
Old 04-07-2009, 06:21 PM   #12
Chris G's Avatar
She loves the look of her interior stairs, so that's where the request came from. It was pretty strong request, lol. The balusters she wants are 2 x 3 painted.
I guess I could go through the treads, there's not that many of them, 4 to be exact. The treads will be ipe, so all that end grain being created by cutting holes in them shouldn't be a problem. But I would want to fasten them to the inside of the stringers to hide them. Hmmm......leave on half of the tread off to get access to bottom of baluster. Hmmmm.........
Hmmmmmmmmmm..........
Chris G is offline
Old 04-07-2009, 07:13 PM   #13
Dan_Watson's Avatar
If they are being painted you could use pocket screws and plugs.
Dan_Watson is offline
new stair treads over old cutback ruggermike Flooring 2 04-02-2009 08:36 PM
pressure treated vs. raw lumber for new painted ext. stair treads, what to use? jordanski Painting & Finish Work 7 03-17-2009 10:23 AM
Hickory Stair Treads dokuhaku Flooring 66 11-20-2008 12:20 AM
varathane stair treads more traction? surferal Flooring 0 09-28-2008 08:58 PM
attaching felt 72chevy4x4 Roofing 20 09-13-2008 06:36 PM
