ATTach Deck To House Built With TGI's
Old 02-07-2007, 07:27 PM   #1
egoff's Avatar
Trade: Builder
Were building house with TGI's, would like advice on proper way to attach the deck is 2 stories tall
egoff is offline
Old 02-07-2007, 07:40 PM   #2
RobertCDF's Avatar
Trade: Custom deck builder
Re: ATTach Deck To House Built With TGI's
Are you attaching to TGI joists? Or the rimboard you are supposed to use for rims? If you are using the rimboard you are allowed to lag to it in most cases. If you had planed to attach to the joists that would be a no no. I would replace it with rim OR LVL.
This advice is based upon assuming that the deck is NOT attached to a cantilever. In these cases the rim would be engineered most cases just inverted hangers.
RobertCDF is offline
Old 02-07-2007, 07:51 PM   #3
egoff's Avatar
Trade: Builder
I just wasn't sure if you can lag into the rim since it is the osb RIM FROM BOISE
egoff is offline
Old 02-07-2007, 09:03 PM   #4
RobertCDF's Avatar
As long as it is the 1 1/4" thick rim and it is not on a cant you should be able to lag to it. Your local inspector MAY feel differantly so I would check with him to be sure.
If you are framing it and have the option I would use an LVL there if you can. And make sure that the rim is nailed to every joist and the sheathing is nailed well to the rim. Also make sure the nails from the wall also go into the rim as this will help hold it even more.
Did you see Flip this house - Cat House? SuperiorBuilt Off Topic (Non Trade) 18 01-24-2011 05:17 PM
`Flip This House' star accused of fraud AmeliaP General Discussion 28 06-03-2007 10:21 PM
deck staining bigdawg Painting & Finish Work 9 03-06-2007 01:25 AM
Deck Ideas GunnCon Decks & Fencing 54 03-01-2006 12:37 AM
Attaching deck ledger to new construction Woodcrafter74 Decks & Fencing 12 01-07-2006 09:41 PM
