Charitable animal
Trade: decks
Another Curved Deck/stair Project
http://www.putfile.com/cdac/images/142355
have 6 days into it so far |
Mod / ArchiBuilder
Re: Another Curved Deck/stair Project
Nice work!
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
Trade: Custom deck builder
Looking good... What kind of decking and railing are you doing?
Trade: Porch and Deck Builder
Hey Bonesaw,
Do you ever kerf cut the back of your rim joists before you bend them? Did you steam that board or was it wet enough to bend as is? |
Charitable animal
Trade: decks
hej Rob, its getting TT tropical teak (conceal loc) on the surface frame stained to match, and TT redwood and deckorator bronze colonial for the railing.
chris I do kerf the back sides on dry pieces or radius tighter than 10' this radius was 12'9" and I saved the wetest/heaviest pieces for it, it bent around like butter, the other side will have an 8'9" radius and will get kerfed. the winches straps and comealongs make east work of it. |
20 years Carpenter
Nice work Bone Saw..
SWEET! How are you holding the radius at the butt joints? I notice one in the open in the curve. In boatbuilding we end at a rib and fair. With decks I do the of the same but have thought of a floating backer block.
Charitable animal
Trade: decks
I strategically put butt joints where railpost layout will fall (attached outside of rim) so the post laps both pieces. I use comealongs cargo straps and ratchet straps to hold everything in place while I put tieplates at every joist/rim connection. As far as the actuall joint itself (scarfed at 20deg), no matter how perfect you fit/align it in, it always needs to be chased out with a saw. while holding both pieces under tension at the joint, I can tweak it in or out so the cuts are parrellell, then generously apply epoxy and shims to fill the gap, plane and beltsand the ***** out of it to make it look good. once tension is let out, it doesnt move. As an aside, are any of you guys who put railpost outside the rim pissed about not having solid posts available anymore, I have to make caps to cover the bottom beveled cut. At least the manufacturers could make a cap that would work with their respective sleeves at a given bevel???
I don't know what you are using but I use hydrophilic epoxy, it's great for wet wood.
Charitable animal
Trade: decks
west system 105/205, I use it with microballoons to make nail head filler. if you go to that putfile link steve, there are a couple of close ups of the joint
Hey Chris how are you likeing that timbertech? Just had someone ask me about that exact color.... Looks nice in your pics. But the last TT deck I did it seemed to scratch easy but that was 3 years ago. How is the conceal loc?
Trade: builder of stuff, real nice stuff
a true craftsman. you are selling you not the deck
Charitable animal
Trade: decks
thanx gents, much appreciated. Rob, the earthwoods line as far as I'm concerned is the best looking stuff out there, It truely looks like a million bucks when you lay it down. I couldn't agree more, in fact if you read some of my older posts, how I think the florizon, twin finnish boards are the absolutel WORST with color fade, staining, scratching, and mold (never could understand why everyone was so hellbent on hating trex, when it was these brushed finished boards giving composites a bad name) So far I'd have to say it is pretty good on the scratching as it pertains to storage handeling transit and installation, much better than trex. The conceal lock is hands down the best godddamn clip on the planet. once you use it, It really makes all those other clips and systems (other than mabey deckmaster) look like chincey crap. I really like those new correct deck colors, they are going to steam roll right over procell, procell brings nothing to the table far as I'm concerned
quite a project!!!!
I just have one question... It looks like you attached the ledger right over the vinyl siding? just saying! |
Charitable animal
Trade: decks
Re: Another Curved Deck/stair Project |
Trade: Construction
Another sweet looking project, Bone!
Gotta love seam boards, they make the surface so much nicer visually than random butt joints. You get kudos for bending the TT boards, those are some heavy, stiff suckers! Did you use additional fastening for the seam boards - glue or screws up through the joists from below? Conceal-Loc is a good system - I didn't go too much slower using them than I would top screwing TT. I predrill all screw holes in that stuff so being able to bypass that step... hell, it was probably faster going with the Conceal-Loc! Although those little #1 square heads strip out easy if you hit dense wood. The attention to detail makes your projects really stand out - it's good to see that kind of craftsmanship still around. Enjoy your weekend, man! Mac |
#17 | |
Charitable animal
Trade: decks
Re: Another Curved Deck/stair ProjectQuote:
#18 |
Workin' Hard & Havin' Fun
Trade: Deck Designer/Builder
Very cool Chris!
Keep us posted. ~Matt |
#19 |
Charitable animal
Trade: decks
http://www.putfile.com/pic.php?img=6660719
http://www.putfile.com/pic.php?img=6660718 http://www.putfile.com/pic.php?img=6660717 http://www.putfile.com/pic.php?img=6660716 http://www.putfile.com/pic.php?img=6660715 http://www.putfile.com/pic.php?img=6660714 http://www.putfile.com/pic.php?img=6660713 http://www.putfile.com/pic.php?img=6660712 http://www.putfile.com/pic.php?img=6660711 http://www.putfile.com/pic.php?img=6660710 http://www.putfile.com/pic.php?img=6660709 http://www.putfile.com/pic.php?img=6660708 outer stringer cheek cut layout outer stringer seat cut layout getting started http://www.putfile.com/pic.php?img=6660704 |
#20 |
You do some nice work. Does working with wet stringer help persuay the curve? Have you ever had an issue with strength of the stringer? I would think the wieght would want to push out and bow the curve mid-point.
| To all The Newbies Starting Up Their Own Business | dirt diggler | General Discussion | 53 | 04-27-2011 07:21 PM |
| Price Your Project Here! Honest Prices Given! | Peladu | General Discussion | 61 | 04-01-2008 07:13 PM |
| Bending Schluter stainless Rondec for curved wall | Rambo1224 | Flooring | 1 | 06-17-2007 08:53 PM |
| Project Manager/Project Engineer | ComConRecruiter | Help Wanted or Looking For Work | 0 | 03-28-2007 03:42 PM |
| Project Manuals/Specs, etc | sparkie5 | General Discussion | 5 | 10-15-2006 06:16 PM |
