Alternative Concrete Mixes
Old 03-04-2007, 12:20 AM   #1
orionkf's Avatar
Trade: Hardscape
Pros/cons and opinions on the following:
1. Pre-mixed, bagged concrete (just add water) compared to 3:2:1 agg/sand/porltland mix. Which one do you use and why? Anyone add extra portland or other additives to pre-mix (calcium, etc.)?
2. Using the 3:2:1 concept, what about going with a 5:1 ratio of recycled concrete aggregate to portland. Any reason not to do this?
3. Similar to #2, what about using 5:1 ratio of 3/4 minus limestone to portland. Again, any reason not to do this?
This is mainly for setting fence posts, but also for deck post supports.
orionkf is offline
Old 03-04-2007, 02:09 AM   #2
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
Re: Alternative Concrete Mixes
The premix in the bag could use some extra portland cement. For dock footings I will use portland, mesh and stone. For walkway pavers I use portland and fiberglass mesh which is hard to find now. Years ago I use to make a mix for between the logs in log homes, white portland, lime and I think sand, the stuff would burn when you cut your hands.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company.
dougchips is offline
Fiber Optics in concrete countertops 6stringmason Concrete & Paving 17 03-16-2011 05:49 PM
Staining concrete ryan.s Masonry 12 03-05-2009 03:54 PM
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Concrete home denick Concrete & Paving 5 03-06-2007 04:32 PM
Hollow steel lally or concrete filled? kusa24 Construction 4 04-23-2006 08:49 AM
