66inch Cantilever - Decks & Fencing - Contractor Talk
66inch Cantilever
Old 06-23-2009, 09:13 PM   #1
Quinn's Avatar
Trade: Deck builder /contractor
Rewards Points: 150
66inch Cantilever
What do you guys think? The existing deck beams are 50 yrs old,not treated and rotting out. 2x12s with a 5 ft cantilever. Im considering going in and replacing the beams exactly as is with treated wood. I don't like that much of a cantilever but but what has been there still seems very strong except for the fact that its rotting away. As u can see someone has done some patch work.
Quinn is offline
Old 06-23-2009, 09:16 PM   #2
Quinn's Avatar
Rewards Points: 150
Re: 66inch Cantilever
Before someone asks. Yes I am trying to sell deck and railing redo also. Definitely needs it!!
Quinn is offline
Old 06-23-2009, 09:19 PM   #3
ClemS's Avatar
Trade: Framing
shouldn't be a problem. looks like a sound design to me. if you're able to get 3x12 I'd much rather see that doubled up for the girders, but triple 2x12 will do just fine. crown down on the girders
ClemS is offline
Old 06-23-2009, 09:26 PM   #4
Quinn's Avatar
Rewards Points: 150
Thanks Clem That's a good thought on the girders
Quinn is offline
Old 06-23-2009, 09:31 PM   #5
KemoSabe
loneframer's Avatar
Rewards Points: 12,214
Yup, go with 3x12s, we've built many homes on top of pilings with them. Laminating 2x12s will harbor moisture between the laminations as well as collecting debris. Single piece is better.
loneframer is offline
Old 06-23-2009, 09:34 PM   #6
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 2,433
I would ask your local inspector what he thinks. Might have to rithink it after he answers you.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 06-23-2009, 10:06 PM   #7
Quinn's Avatar
Rewards Points: 150
The girders will need to be 24 ft. long so I would like to stick with 2x's.(for handling purposes) The section of beam exposed to weather will be covered with some kind of deck wrap.
Quinn is offline
Old 06-24-2009, 04:39 AM   #8
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,609
Make sure you thoroughly check out the connection of the joists at the house. After 50 years I can almost guarantee that there is water and/or insect damage at this point. Last year I removed one that was 30 years old and it practically snapped off at the house due to water and carpenter ant damage.
Warren is online now
Old 06-24-2009, 06:54 AM   #9
deckman22's Avatar
Trade: Deck Builder
Rewards Points: 6,394
I'm not a big fan of cantilevered decks. That existing deck looks out of level to me, seems cantilevered decks always end up that way.
Those sure are some big brick columns, they take up way too room on the patio under the deck imo. Put some new footings/post in out in the garden area, knock out those columns & you have some useable space under that deck. That's just my opinion, your customer may have a totally different one.
Deckman
www.alscustomdecks.com
deckman22 is offline
Old 06-24-2009, 07:02 AM   #10
Tom M's Avatar
Rewards Points: 7,070
You may be better served getting a treated Paralam.
Tom M is online now
Old 06-24-2009, 04:58 PM   #11
Quinn's Avatar
Rewards Points: 150
Maybe over-kill, but Im probably going to go 5 wide with my 2x12s
Quinn is offline
Can I cantilever an extension to an existing deck? lot249 Carpentry 9 05-23-2009 12:27 PM
Attaching through a cantilever Greg Di Decks & Fencing 28 02-24-2009 07:46 AM
Chimney leaks, permeates water beavhut General Discussion 10 09-02-2008 04:40 PM
Cantilever peripindicular from floor joists. georgia dawg Framing 4 04-18-2007 07:33 PM
Alum Soffit for cantilever first floor question. GiantScale Windows, Siding and Doors 6 04-25-2006 11:05 PM
