4x4 Posts In Concrete Vs. Saddles
Old 08-31-2009, 10:41 PM   #21
adlyn construction
pipekicker's Avatar
Trade: home and commercial renovations and handyman ser.
Re: 4x4 Posts In Concrete Vs. Saddles
Originally Posted by DecksEtc View Post
If I did that in the area I am in, the posts would all be heaved from frost in less than 2 years.
I've removed many, many crooked fence posts/fences because the previous installer had the concrete up to ground level.
I've become quite passionate about building fences. I live in northern alberta where the frost goes down deep. I always use 6x6 posts unless the HO's budget is a bit wimpy, otherwise 4x6 minimum or I turn the job down. When I'm setting posts, I drill 54" to allow for a 6" base of washed rock or gravel. Before pouring concrete, I will install a small piece of 12" sonotube at the top of the hole if it is augered out really wide due to roots or loose soil. If you keep your "finished pyramid" within the diameter of the post hole, there is no chance of the frost heaving the post. It's when you fill that top augered out part with concrete, is when you will get frost heaving. If you create a concrete mushroom, the frost will have something to push against. As for the rot issue, I always stain the framing right down to the top of the concrete before backfilling. Another layer of protection above the treatment never hurts and I've never had any problems.
pipekicker is offline
Embedding W10 beam in concrete footing Greg Di Construction 31 02-20-2009 08:45 AM
Tampa, FL. Concrete Forklift Ramp Needed phattractor Help Wanted or Looking For Work 0 02-10-2009 02:26 PM
Kansas City Decorative Concrete - New Member ADC-Dustin Introductions 5 11-15-2008 10:24 PM
Pyramidal Concrete Steps Cache Concrete & Paving 19 10-20-2008 06:33 PM
Need to frame a wall over concrete wall. joseph Carpentry 3 10-07-2008 08:19 PM
