Trade: Decking, Fencing and Remodeling
3 1/2" Wide Level
Does anyone know where I can get a 3.5 inch wide level? I need to put up 600ft of 1x4 picket fence, and would like to just run it without using a spacer and a level.
Thanks in advance. |
Re: 3 1/2" Wide Level
Why not level your first one, then pull you layout and then spot check as you go!
Trade: Builder/Framing Co.
level first one, use a 2x4 block to space between each picket.
Charitable animal
Trade: decks
why not put your top and bottom rail together and scribe your layout like plates when framing a wall
#5 | |
Re: 3 1/2" Wide LevelQuote:
The problem is if I level the first, the 3,4,5th etc will start to get out of plumb. No problem really, but with this much fence, I don't want to carry a level all over this property as well as a 2x4 block. I do it normally, I just don't want to. The customer changed it to a 2.25 space (the width of my level) this am, so now it is mute. About scribing the framing: the framing will be following grade up and down hills so the marks would have to be plumb as well. Too much work. Thanks everyone! |
Charitable animal
Trade: decks
just out of shear curiosity, how do you do deck railing balusters?
Trade: Porch and Deck Builder
I know it's moot now, (and mute as well I guess), but could you have attached something to one side of the level to thicken it? You would still have one good edge to work with to check plumb. Buy a cheap level and pimp it up, ya know.
Bone saws method is the best though. |
#8 | |
Charitable animal
Trade: decks
#9 | |
Anyway, HO solved the poblem...imagine that! |
Deck Designer/Builder
Re: 3 1/2" Wide Level |
| Framing Roof Joists for Addition when top Plate is not Level | personalt | Framing | 3 | 07-20-2007 06:52 AM |
| level decks on the top floors | adman1900 | Carpentry | 1 | 11-11-2006 11:20 AM |
| Stabila Plate Level? | dayspring | Tools & Equipment | 7 | 09-14-2006 12:44 AM |
| Getting the first floor perfectly level... | OntarioFramer | Framing | 8 | 05-06-2006 08:14 PM |
