2 storey deck on top of flat roof
ive been asked to replace a rooftop deck which has 2 levels to it, currently the old deck has the posts set down into the roof and is poorly flashed which is obviously leaking, luckily its only a porch roof
with replacing this deck what would be my best method of resetting the posts so that i dont have to worry about any penetration points to flash and seal
my current thought is to set a 2x8 beam on directly on top of the flat roof over the beam which supports the rafter ends, then post up from there to support the 2nd level of deck but if i go about this method how do deflect the rain, snow and ice that will collect. where the beam is fully bearing would notching it every 16" create centered between joists create any issue.
rough dimensions are 7' x 26', then the 2nd storey is 7' x 14'
