Your Help Is Needed! Inventory Work Track Checklist? - Electrical - Contractor Talk
Old 10-21-2017, 11:49 AM   #1
ElectricianC-10's Avatar
Trade: Electrical
Rewards Points: 76
Hi everyone!
Good morning, we need your help.
We are trying to be more organize.
We want to build an inventory checklist for electrician work track.
Does anyone here has something like this ?
What materials needs to be in our check list in your opinion? What tools?
We do mainly residential projects.
Let me know what do you think!
Thank you
ElectricianC-10 is offline
Old 10-21-2017, 01:59 PM   #2
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,632
Re: Your Help Is Needed! Inventory Work Track Checklist?
Did you mean work TRUCK?
Home Designer Series Software
B.Johnson is offline
Old 10-21-2017, 02:58 PM   #3
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,774
Qty Manufacturer Description
1 MagneTek 2-F32T8 120V Low Watt Elec IS Blst
1 MagneTek 3-F32T8 120V Low Watt Elec IS Blst
1 MagneTek 2-F96T12 120V CBM Series SLH Blst
1 MagneTek 2-F40T12 120V CBM Low Heat RS Blst
250 Copper Wire #12/2 Solid Aluminum MC Cable
250 Copper Wire #12/3 Solid Aluminum MC Cable
500 Copper Wire #12 THHN Solid Copper BLK
500 Copper Wire #12 THHN Solid Copper BLU
500 Copper Wire #12 THHN Solid Copper GRN
500 Copper Wire #12 THHN Solid Copper RED
500 Copper Wire #12 THHN Solid Copper WHT
50 Conduit 1/2" EMT
50 Conduit 3/4" EMT
10 Conduit 1" EMT
Conduit 1-1/4" EMT
Conduit Fittings 1-1/4" EMT Elbow
2 Red Dot 1/2" EMT Conduit Body-Type LB
2 Red Dot 3/4" EMT Conduit Body-Type LB
1 Red Dot 1" EMT Conduit Body-Type LB
50 Raco 1/2" EMT Cast Set Screw Conn
50 Raco 3/4" EMT Cast Set Screw Conn
10 Raco 1" EMT Cast Set Screw Conn
50 Raco 1/2" EMT Cast Set Screw Coupling
50 Raco 3/4" EMT Cast Set Screw Coupling
10 Raco 1" EMT Cast Set Screw Coupling
2 Raco 1-1/4" EMT Cast Set Screw Coupling
20 Raco 1/2" EMT Cast Compression Conn
20 Raco 3/4" EMT Cast Compression Conn
10 Raco 1" EMT Cast Compression Conn
20 Raco 1/2" EMT Cast Comprsn Coupling
20 Raco 3/4" EMT Cast Comprsn Coupling
10 Raco 1" EMT Cast Comprsn Coupling
50 Raco 1/2" EMT 1 Hole Steel Strap
50 Raco 3/4" EMT 1 Hole Steel Strap
12 Raco 1" EMT 1 Hole Steel Strap
12 Neer 1/2" Straight Cast Flex Conn
6 Neer 1/2" 90Dg Cast Flex Conn
6 Appleton 1/2" Straight Liquidtite Conn
2 Appleton 3/4" Straight Liquidtite Conn
2 Appleton 1/2" 90Dg Liquidtite Conn
50 Electri-Flex 1/2" Flexible Aluminum Conduit
12 Carlon 1/2" X/Flex L/T Nonmetallic Cond
12 Carlon 3/4" X/Flex L/T Nonmetallic Cond
1 Bussmann 30A Time Delay Class J Fuse-600V
1 Bussmann 50A Time Delay Class J Fuse-600V
1 Bussmann 60A Time Delay Class J Fuse-600V
1 Bussmann 100A Time Delay Class J Fuse-600V
2 Conduit Fittings 1/2" GRC Coupling
2 Conduit Fittings 3/4" GRC Coupling
2 Conduit Fittings 1" GRC Coupling
Conduit Fittings 1-1/4" GRC Coupling
Conduit Fittings 1-1/2" GRC Coupling
Conduit Fittings 2" GRC Coupling
Crouse-Hinds FS Box Blank Stl Cover-1G
Crouse-Hinds FS Box Blank Stl Cover-2G
1 Mulberry 1/2" 1G Cast Alum Box-5 Outlet
1 Mulberry 1/2" 1G Cast Alum Lug Box-3 Outlet
1 Mulberry 3/4" 1G Cast Alum Lug Box-3 Outlet
1 Mulberry 3/4" 1G Cast Alum Lug Box-5 Outlet
1 Mulberry 1/2" 2G Cast Alum Lug Box-5 Outlet
1 Mulberry 3/4" 2G Cast Alum Lug Box-5 Outlet
1 Mulberry Cast Box Switch Cover-1G Vert
1 Mulberry Cast Box Duplex Recpt Cover-1G Vert
1 Mulberry Cast Box GFI Cover-1G Vert
1 Mulberry Blank 4" Round Cast Box Cover
1 Mulberry 3 Hole 4" Round Cast Box Cover
1 Conduit Fittings 2"x6" GRC Nipple
2 T & B 1/2" Plastic Bushing
2 T & B 3/4" Plastic Bushing
2 T & B 1" Plastic Bushing
2 T & B 1-1/4" Plastic Bushing
2 T & B 1-1/2" Plastic Bushing
2 T & B 2" Plastic Bushing
T & B 2-1/2" Plastic Bushing
T & B 1" Insulated Grounding Bushing
T & B 1-1/4" Insulated Grounding Bushing
1 T & B 2" Insulated Grounding Bushing
12 Appleton 1/2" Locknut
12 Appleton 3/4" Locknut
4 Appleton 1" Locknut
4 Appleton 1-1/4" Locknut
2 Appleton 1-1/2" Locknut
2 Appleton 1/2" Sealing Locknut
2 Appleton 3/4" Sealing Locknut
1 Appleton 2" Sealing Locknut
6 Raco 1/2" Cast Chase Nipple
6 Raco 3/4" Cast Chase Nipple
2 Raco 1" Cast Chase Nipple
2 O-Z/Gedney 1/2" Rigid Conduit Hub
2 O-Z/Gedney 3/4" Rigid Conduit Hub
6 Killark 3/4" - 1/2" Reducing Bushing
2 Killark 1" - 1/2" Reducing Bushing
Killark 1-1/4" - 1" Reducing Bushing
12 O-Z/Gedney 3/4" - 1/2" Reducing Washer
6 O-Z/Gedney 1" - 1/2" Reducing Washer
6 O-Z/Gedney 1" - 3/4" Reducing Washer
2 O-Z/Gedney 1-1/4" - 1/2" Reducing Washer
2 O-Z/Gedney 1-1/4" - 3/4" Reducing Washer
2 O-Z/Gedney 1-1/4" - 1" Reducing Washer
2 O-Z/Gedney 2" - 1/2" Reducing Washer
2 O-Z/Gedney 2" - 3/4" Reducing Washer
12 Sepco 1/2" Knockout Seal
12 Sepco 3/4" Knockout Seal
12 Sepco 1" Knockout Seal
1 Sepco 1-1/4" Knockout Seal
1 Sepco 1-1/2" Knockout Seal
1 Sepco 2" Knockout Seal
12 Appleton 1/2" 2 Hole Steel Strap
12 Appleton 3/4" 2 Hole Steel Strap
6 Appleton 1" 2 Hole Steel Strap
6 Appleton 2" 2 Hole Steel Strap
6 Appleton 2-1/2" 2 Hole Steel Strap
1 _Andy's Favorites ARC-15, GE Style
1 _Andy's Favorites ARC-20, GE Style
1 Cutler Hammer CH115
1 Cutler Hammer CH120
1 Cutler Hammer GFI Breaker, CH
1 Cutler Hammer CH230
Cutler Hammer CH240
2 Cutler Hammer CH250
Cutler Hammer CH260
10 Square D 15A-1P Homeline Cct Brkr
10 Square D 20A-1P Homeline Cct Brkr
1 Square D 20A-2P Homeline Cct Brkr
4 Square D 30A-2P Homeline Cct Brkr
Square D 35A-2P Homeline Cct Brkr
Square D 45A-2P Homeline Cct Brkr
2 Square D 50A-2P Homeline Cct Brkr
Square D 60A-2P Homeline Cct Brkr
Square D 70A-2P Homeline Cct Brkr
Square D 80A-2P Homeline Cct Brkr
Square D 100A-2P Homeline Cct Brkr
1 Square D 15A-1P Homeline GFI Cct Brkr
1 Square D 20A-1P Homeline GFI Cct Brkr
1 Square D 30A-2P Homeline GFI Cct Brkr
1 Square D 50A-2P Homeline GFI Cct Brkr
1 Square D 15A/15A Homeline Tandem Cct Brkr
1 Square D 15A/20A Homeline Tandem Cct Brkr
1 Square D 20A/20A Homeline Tandem Cct Brkr
Square D 30A/20A Homeline Tandem Cct Brkr
1 Challenger 15A-1P 240V 10K Plug-on Brkr
2 GE Distrib. Equip. 15A-1P 240V 10K Plug-on Brkr
2 ITE 15A-1P 240V 10K Plug-on Brkr
1 Square D 15A-1P 240V 10K Plug-on Brkr
1 Challenger 20A-1P 240V 10K Plug-on Brkr
2 GE Distrib. Equip. 20A-1P 240V 10K Plug-on Brkr
2 ITE 20A-1P 240V 10K Plug-on Brkr
2 Square D 20A-1P 240V 10K Plug-on Brkr
Square D 25A-1P 240V 10K Plug-on Brkr
Square D 15A-2P 240V 10K Plug-on Brkr
1 Challenger 20A-2P 240V 10K Plug-on Brkr
1 GE Distrib. Equip. 20A-2P 240V 10K Plug-on Brkr
2 Square D 20A-2P 240V 10K Plug-on Brkr
GE Distrib. Equip. 25A-2P 240V 10K Plug-on Brkr
Square D 25A-2P 240V 10K Plug-on Brkr
1 Challenger 30A-2P 240V 10K Plug-on Brkr
1 GE Distrib. Equip. 30A-2P 240V 10K Plug-on Brkr
1 ITE 30A-2P 240V 10K Plug-on Brkr
1 Square D 30A-2P 240V 10K Plug-on Brkr
GE Distrib. Equip. 35A-2P 240V 10K Plug-on Brkr
Square D 35A-2P 240V 10K Plug-on Brkr
1 GE Distrib. Equip. 40A-2P 240V 10K Plug-on Brkr
1 Square D 40A-2P 240V 10K Plug-on Brkr
Square D 45A-2P 240V 10K Plug-on Brkr
1 Challenger 50A-2P 240V 10K Plug-on Brkr
1 GE Distrib. Equip. 50A-2P 240V 10K Plug-on Brkr
1 Square D 50A-2P 240V 10K Plug-on Brkr
GE Distrib. Equip. 60A-2P 240V 10K Plug-on Brkr
1 Square D 60A-2P 240V 10K Plug-on Brkr
GE Distrib. Equip. 70A-2P 240V 10K Plug-on Brkr
Square D 70A-2P 240V 10K Plug-on Brkr
Square D 80A-2P 240V 10K Plug-on Brkr
Square D 90A-2P 240V 10K Plug-on Brkr
Square D 100A-2P 240V 10K Plug-on Brkr
Square D 125A-2P 240V 10K Plug-on Brkr
Square D 15A-3P 240V 10K Plug-on Brkr
1 ITE 20A-3P 240V 10K Plug-on Brkr
1 Square D 20A-3P 240V 10K Plug-on Brkr
ITE 30A-3P 240V 10K Plug-on Brkr
Square D 30A-3P 240V 10K Plug-on Brkr
Square D 40A-3P 240V 10K Plug-on Brkr
ITE 50A-3P 240V 10K Plug-on Brkr
Square D 50A-3P 240V 10K Plug-on Brkr
Square D 60A-3P 240V 10K Plug-on Brkr
Square D 70A-3P 240V 10K Plug-on Brkr
Square D 80A-3P 240V 10K Plug-on Brkr
Square D 100A-3P 240V 10K Plug-on Brkr
1 Square D 15A-1P 240V 10K Plug-on GFI Brkr
1 Square D 20A-1P 240V 10K Plug-on GFI Brkr
1 Square D 30A-2P 240V 10K Plug-on GFI Brkr
1 Square D 50A-2P 240V 10K Plug-on GFI Brkr
Square D 15A-1P 240V 10K Bolt-on Brkr
2 Square D 20A-1P 240V 10K Bolt-on Brkr
Square D 15A-2P 240V 10K Bolt-on Brkr
Square D 20A-2P 240V 10K Bolt-on Brkr
Square D 30A-2P 240V 10K Bolt-on Brkr
Square D 35A-2P 240V 10K Bolt-on Brkr
Square D 40A-2P 240V 10K Bolt-on Brkr
Square D 50A-2P 240V 10K Bolt-on Brkr
Square D 60A-2P 240V 10K Bolt-on Brkr
Cutler Hammer 100A-2P 240V 10K Plug-on Meter Brkr
GE Controls 100A-2P 240V 10K Plug-on Meter Brkr
ITE 100A-2P 240V 10K Plug-on Meter Brkr
Square D 100A-2P 240V 10K Plug-on Meter Brkr
Wesco Loadcenters 100A-2P 240V 10K Plug-on Meter Brkr
1 _Andy's Favorites Tapcon 1/4 x 1-1/4 (75ct)
1 _Andy's Favorites Drywall Anchor (50ct) Buildex E-Z
1 PANDUIT Number Book (1-45)
1 Misc Job Items Roof Pitchpocket
4 Fire Proofing 4" Fire Proofing
50 3M #18-#12 Yellow Wire Nut
500 3M #16-#10 Red Wire Nut
15 3M #12-#8 Blue Wire Nut
50 T & B 4" Ty-Rap
50 T & B #12-#10 Ring Terminal
50 Raco Box Grounding Screw
50 Raco Box Grounding Clip
1 3M 3/4"x66Ft 7Mil Electrical Tape
1 3M 66Ft Blue Electrical Tape
1 3M 66Ft Brown Electrical Tape
1 3M 66Ft Gray Electrical Tape
1 3M 66Ft Green Electrical Tape
1 3M 20Ft Orange Electrical Tape
1 3M 66Ft Red Electrical Tape
1 3M 66Ft White Electrical Tape
1 3M 66Ft Yellow Electrical Tape
1 3M 3/4" Splicing Tape
1 Ideal 1 Gallon Wire Pulling Compound
2 T & B #8-#2 1" Pipe Ground Clamp
2 Ilsco #4 Split Bolt w/o Spacer
2 Ilsco #2/0 Split Bolt w/o Spacer
12 Ilsco #6 Single Barrel Lug
12 Ilsco #2 Single Barrel Lug
Why is there not a Flat Mars Society?.
480sparky is online now
Old 10-21-2017, 03:00 PM   #4
480sparky's Avatar
2 Blackburn 1/2" Ground Rod Clamp
2 Blackburn 5/8" Ground Rod Clamp
50 Powers Fasteners 1/4"x4" Toggle Bolt
50 Powers Fasteners 10-12 x 1" Fluted Screw Anchor
50 Powers Fasteners 8-18 x 1" Hex Head Self-Drill
50 Bridgeport 3/8" Die Cast NMC Connector
50 Bridgeport 1/2" Die Cast NMC Connector
12 Bridgeport 3/4" Die Cast NMC Connector
6 Bridgeport 1" Die Cast NMC Connector
2 Bridgeport 1-1/4" Die Cast NMC Connector
1 Bridgeport 1-1/2" Die Cast NMC Connector
1 Bridgeport 2" Die Cast NMC Connector
100 Viking #12/2 NMC Staple
250 Copper Wire #14/2 NM Copper Cable w/Ground
250 Copper Wire #12/2 NM Copper Cable w/Ground
250 Copper Wire #14/3 NM Copper Cable w/Ground
250 Copper Wire #12/3 NM Copper Cable w/Ground
2 Raco 4"x1-1/2" Oct Clng Pan Fan Box
2 Raco 1/2"&3/4"KO 4"x1-1/8" Oct Box
2 Raco 1/2"&3/4"KO 4"x1-1/2" Oct Ext Ring
1 Raco Flat Blank 4" Oct Box Cover
6 Raco Flat Blank 4" Sq Box Cover
4 Raco 5/8" Rise 4" Sq 1G Device Ring
2 Raco 5/8" Rise 4" Sq 2G Device Ring
2 Raco 4" Sq 1-Switch Box Cover
1 Raco 4" Sq 2-Switch Box Cover
4 Appleton 4" Sq 1-Duplex Box Cover
2 Appleton 4" Sq 2-Duplex Box Cover
1 Raco 4" Sq 30A Twistlock Box Cover
1 Raco 4" Sq 30A-60A Recpt Box Cover
2 Raco 4" Sq GFI Receptacle Box Cover
1 Raco 4" Sq 2-GFI Recpt Box Cover
2 Raco 1/2"KO 2-1/8"D Handy Box
2 Raco 3/4"KO 2-1/8"D Handy Box
1 Raco Handy Box Blank Cover
1 Raco Handy Box Switch Cover
1 Raco Handy Box Duplex Recpt Cover
4 Raco Ears, 1/2" KO 2-3/4"D Gang Sw Box
2 Raco Ears, 3/4" KO 2-3/4"D Gang Sw Box
2 Raco Ears, 1/2" KO 3-1/2"D Gang Sw Box
2 Raco Ears, 3/4" KO 3-1/2"D Gang Sw Box
2 Raco 4"x1/2" Ceiling Pan
0 Raco 4" Ceiling Fan Ceiling Pan
12 Raco Switch Box Supports
25 Raco 6" #12 Pigtail
4 Raco Nails/Grnd 3.5"x Rnd Noryl Clng Box
4 Raco Old Work 3.5"x Rnd Noryl Clng Box
4 Raco Old Work 2-13/16" PVC Switch Box
6 Raco Nails/KOs 2-13/16" PVC Switch Box
0 Raco Side Mount 2-13/16" PVC Switch Box
2 Raco Old Work 2-13/16" 2G PVC Box
2 Raco Nails 3" 2G PVC Box
20 Carlon 1/2" PVC Schedule 40
20 Carlon 3/4" PVC Schedule 40
10 Carlon 1" PVC Schedule 40
6 Carlon 1/2" PVC Coupling
6 Carlon 3/4" PVC Coupling
6 Carlon 1" PVC Coupling
2 Carlon 1-1/4" PVC Coupling
2 Carlon 2" PVC Coupling
4 Carlon 1/2" PVC Sch 40 90Dg-Standard
4 Carlon 3/4" PVC Sch 40 90Dg-Standard
2 Carlon 1" PVC Sch 40 90Dg-Standard
12 Carlon 1/2" PVC Terminal Adapter
12 Carlon 3/4" PVC Terminal Adapter
6 Carlon 1" PVC Terminal Adapter
2 Carlon 1-1/4" PVC Terminal Adapter
2 Carlon 2" PVC Terminal Adapter
12 Carlon 1/2" PVC Conduit Strap
12 Carlon 3/4" PVC Conduit Strap
6 Carlon 1" PVC Conduit Strap
4 Carlon 1-1/4" PVC Conduit Strap
2 Carlon 1-1/2" PVC Conduit Strap
2 Carlon 2" PVC Conduit Strap
1 Carlon 1/2" PVC Conduit Body-LB
1 Carlon 3/4" PVC Conduit Body-LB
1 Carlon 1" PVC Conduit Body-LB
1 Carlon 1/2" PVC 1G FSE Box
1 Carlon 3/4" PVC IG FSE Box
1 Carlon 1" PVC IG FSE Box
1 Carlon 1/2 Pint PVC Clear Cement
1 _Andy's Favorites Pull-Out Disconnect
6 Wiremold 1Ft Section Adhesive 2300 Wiremold
2 Wiremold 2300 Wiremold Cover Clip
1 Wiremold 2300 Wiremold Entrance End
2 Wiremold 2300 Wiremold Flat Elbow
2 Wiremold 2300 Wiremold Internal Elbow
2 Wiremold 2300 Wiremold External Elbow
1 Wiremold 2300 Wiremold Blank Box Cover
1 Wiremold 2300 Wiremold Fixture Box
1 Wiremold 1G Deep 2300 Wiremold Box
1 Wiremold 2G Deep 2300 Wiremold Box
2 Caddy 24" Span T-Bar Box Clip
2 Caddy Box Mounting T-Bar Box Clip
1 Tork SPST 120V Time Clock
1 Tork 2Kw 120V Conduit Wired Photo Cell
10 Steel City St Stl 12Ga 1-1/2" Channel w/Holes
10 B-Line Galv 14GA 1-5/8" Slotted Channel
6 Unistrut 1/2" EMT Channel Clamp
6 Unistrut 3/4" EMT Channel Clamp
6 Unistrut 1" EMT Channel Clamp
10 Arrow Hart SP Wht 15A Stnd Switch w/Ground
4 Arrow Hart 3W Ivy 15A Stnd Switch w/Ground
4 Arrow Hart 3W Wht 15A Stnd Switch w/Ground
2 Arrow Hart 4W Ivy 15A Stnd Switch w/Ground
2 Arrow Hart 4W Wht 15A Stnd Switch w/Ground
10 Arrow Hart Duplex Ivy 15A 125V Stnd Recpt
10 Arrow Hart Duplex Wht 15A 125V Stnd Recpt
1 Arrow Hart Duplex Ivy 15A 250V Stnd Recpt
4 Arrow Hart Duplex Ivy 20A 125V Stnd Recpt
4 Arrow Hart Duplex Wht 20A 125V Stnd Recpt
1 Arrow Hart Single Ivy 20A 125V Spec Recpt
1 Arrow Hart Single Wht 20A 250V Stnd Recpt
1 Arrow Hart Duplex Org 20A 125V Spec I.G. Recpt
1 Arrow Hart Ivy 15A GFI Recpt no Indicator
1 Arrow Hart Wht 15A GFI Recpt no Indicator
1 Arrow Hart 15A 125V Black & White Plug
1 Arrow Hart 15A 125V Gray Valise Connector
1 Arrow Hart 20A 125V Black & White Plug
1 Arrow Hart 20A 125V Black & White Connector
2 Arrow Hart St Steel 20A 4w Recpt Plate
1 Arrow Hart Flush 30A 125/250V 3p4w Recpt
1 Arrow Hart Surface 30A 125/250V 3p4w Recpt
1 Arrow Hart St Steel 30A-4w Recpt Plate
1 Arrow Hart Flush 50A 125/250V 3p4w Recpt
1 Arrow Hart Surface 50A 125/250V 3p4w Recpt
1 Arrow Hart St Steel 50A-3w Recpt Plate
2 Leviton SP Ivory 15A Stnd Decora Switch
2 Leviton DP White 15A Stnd Decora Switch
2 Leviton 3W Ivory 15A Stnd Decora Switch
2 Leviton 3W White 15A Stnd Decora Switch
1 Leviton SP Ivory 20A Spec Decora Switch
1 Leviton SP White 20A Spec Decora Switch
2 Leviton Dup Ivy 15A Resdntl Decora Recpt
2 Leviton Dup Wht 15A Resdntl Decora Recpt
2 Leviton Dup Ivy 20A 125V Stnd Decora Recpt
2 Leviton Dup Wht 20A 125V Stnd Decora Recpt
10 Arrow Hart 1G Switch Smooth Pls Ivy Plate
2 Arrow Hart 2G Switch Smooth Pls Ivy Plate
1 Arrow Hart 3G Switch Smooth Pls Ivy Plate
1 Arrow Hart 4G Switch Smooth Pls Ivy Plate
10 Arrow Hart 1G Dup Recp Smooth Pls Ivy Plate
2 Arrow Hart 2G Dup Recp Smooth Pls Ivy Plate
4 Arrow Hart 1G Blank Smooth Pls Ivy Plate
2 Arrow Hart 2G Blank Smooth Pls Ivy Plate
10 Arrow Hart 1G Switch Smooth Pls Wht Plate
2 Arrow Hart 2G Switch Smooth Pls Wht Plate
1 Arrow Hart 3G Switch Smooth Pls Wht Plate
1 Arrow Hart 4G Switch Smooth Pls Wht Plate
10 Arrow Hart 1G Dup Recp Smooth Pls Wht Plate
1 Arrow Hart 2G Dup Recp Smooth Pls Wht Plate
1 Arrow Hart 1G Sgl Recp Smooth Pls Wht Plate
4 Arrow Hart 1G Blank Smooth Pls Wht Plate
2 Arrow Hart 2G Blank Smooth Pls Wht Plate
2 Arrow Hart 1G Switch 302 St Steel Plate
1 Arrow Hart 2G Switch 302 St Steel Plate
2 Arrow Hart 1G Dup Recp 302 St Steel Plate
1 Arrow Hart 1G Sgl Recp 302 St Steel Plate
1 Arrow Hart 1G Blank 302 St Steel Plate
1 Arrow Hart 1G Dup Recp Orange IG Nylon Plate
10 Hubbell 1G Ivory DECORA Plate
4 Hubbell 2G Ivory DECORA Plate
10 Hubbell 1G White DECORA Plate
4 Hubbell 2G White DECORA Plate
1 Pass & Seymour 1G Gray In-Use Deep Recpt Cover
1 Pass & Seymour 2G Clear In-Use Recpt Cover
Old 10-21-2017, 09:18 PM   #5
back doors to hell put in
Irishslave's Avatar
Rewards Points: 2,484
No green ground or bonding screws of any kind?
Television is fake...The internet is real
Irishslave is offline
Old 10-21-2017, 09:23 PM   #6
Irishslave's Avatar
just buy what you need at home depot
Old 10-21-2017, 09:41 PM   #7
480sparky's Avatar
They don't need to be green.
Old 10-21-2017, 09:51 PM   #8
Irishslave's Avatar
Hey while I got you what's the minimum size conduit body you can comfortably bend or run 4/0 through? 2 and 1/2 looks good but what about 3"? And are those rack-a-tiers benders any good or should I get the handle type?
Old 10-21-2017, 10:16 PM   #9
480sparky's Avatar
Too ambiguous. How many 4/0's? Insulation type? Copper or aluminum?
Old 10-21-2017, 10:28 PM   #10
Irishslave's Avatar
Aluminum 3 cables for 200 amp service
LB conduit body if that makes a difference I think so an LL would be a tighter radius bend
Old 10-21-2017, 10:35 PM   #11
480sparky's Avatar
Assuming some sort of thermoplastic insulation, I'd go 2".
Old 10-21-2017, 10:52 PM   #12
Irishslave's Avatar
Now about the bender....is the rack-a-tiers any good?
This was for my dad out at the farm...he had a 2" what a disaster I knew it was too small.
I need to get back out there and fix this. I had all kinda of problems going unprepared. There was a 200 amp panel with the old overhead line feeding it (Copper) and when I went to pull it out the lugs were frozen...and I ended up busting the the main breaker. I know you can buy these for Square D but we were out in the sticks and I had to get the well pump back on....so we got another panel...now I need to pull those 4/0 feeders and re feed through a proper sized LB....I hope I don't run into frozen lugs again....I put inhibitor on the cables but not the lug threads (the nozzle on the bottle was clogged)
Old 10-21-2017, 11:02 PM   #13
480sparky's Avatar
Now about the bender....is the rack-a-tiers any good? ...........
Dunno. Never used one.
Old 10-21-2017, 11:06 PM   #14
Irishslave's Avatar
Strong hands huh?
Old 10-21-2017, 11:20 PM   #15
480sparky's Avatar
Strong hands huh?
BFH.
Old 10-23-2017, 05:47 PM   #16
Trade: Electrical
Rewards Points: 76
Appreciate it very much.
I am trying to make the best list for my Chevy express work Van.
I have to find the best system that will help us have the most important day to day needs In our van, and in the same time be easy to update our office about the usage.
We try to do mostly residential projects and service calls.
This year we stopped working with General contractors ... (at list we are trying) Up till 2017 we only did big projects as a subs, that is why we need the new system.
Let us know what works for you?
Old 10-23-2017, 06:05 PM   #17
480sparky's Avatar
What works for most is to make their own list. Having Challenger breakers on your truck is a waste if there are no Challenger panels in your trade area.
Old 10-24-2017, 04:18 AM   #18
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,667
How many similar service trucks? 1,-10? an important thing long term is to track what U didn't have on board, and needed, and track and replace items that are used(should be an integral part of invoicing and maybe commissions? , and yank items that drop off the at least once a year(whatever) list.
What type of shelving is needed to keep this many items within a 2-3 minute snipe hunt? Do the cubby holes match the product box sizes, or do you needed unpack most items.
Does the low V. guy or the master trouble shooter get a tall boy van or a bread truck? or vice versa, the newbie drives the rolling warehouse?
Maybe photos of the perfect stocked Van? See the beer/ pop men have pics of the freezer stock plan.....
Run the loaded vans/what ever over scale and check the tires for safety/ Sue fests. Is the crash divider up the task asked of it?
No Masonry boxes? GFIs? It is all about ME.
PPE? any need for a arc flash clothes storage? Spare HV gloves etc...
Candles and flashlight batteries for my less skilled sparky friends....
Free money maker for most trades....provision to charge portable tool batteries off shift, removable charger(s) mounted on board inside van. Mos fet protected plug in strip with plug outside van body.
Maybe an 120 VAC inverter wired to vehicle? large enough to run a small hand tool or run a laptop all day....
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
ElectricianC-10 (10-25-2017)
Old 10-24-2017, 07:46 AM   #19
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
Your work track looks like a rolling billboard. Does it have loudspeakers?
RangoWA is offline
The Following User Says Thank You to RangoWA For This Useful Post:
SmallTownGuy (10-24-2017)
Old 10-26-2017, 04:07 AM   #20
Trade: Masonry
Do you buy everything through a single re-seller? Or do you allow the techs to buy at wholesale/retailers near the job site to save drive time/$s?
Would a delivery boy / helper pay that made midday deliveries to larger jobs by effective? extra set of hands eyes as needed, and performs warehousing in and out....?
Do you buy some items in bulk and then subdivide them between the operators?
A dedicated or smart phone bar code reader..... with integrated invoicing......
A labeling machine/printer with spare blank rolls.....
Video on loading dock?
Work Needed! sam202014 General Discussion 0 04-15-2014 10:43 AM
Non union jobsite (quaker church)vandalized in philadelphia $500,000 Damage mastersplinter Carpentry 41 04-19-2013 01:06 AM
Get any and all Columbia Forest Products at Home Depot if needed TBFGhost Carpentry 15 01-02-2013 08:31 PM
Insulation & Drywall Work Needed in B.C & Alberta ctwoc Help Wanted or Looking For Work 0 12-02-2011 02:17 PM
