tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Wrong 220 Outlet
Old 12-28-2017, 12:01 PM   #21
back doors to hell put in
Irishslave's Avatar
Rewards Points: 2,256
Re: Wrong 220 Outlet
Originally Posted by SmallTownGuy View Post
neutral. mfrs cal it that. Code says on new builds 4 wire is required. Calls the middle leg neutral, and 4th is chassis ground.
I don't make the rules...
it's because new appliances have loads of solid state circuitry too. It's all 110v
"An argument against democracy,” an astute observer once said, “is to spend five minutes with the average voter.”
Irishslave is offline
Old 12-28-2017, 10:10 PM   #22
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,198
Funny thing is most electronics now have a switching type power supply. 100-240V, 50/60 HZ. Doesn't matter to it.
Golden view is offline
Old 12-29-2017, 11:22 AM   #23
ComRemodel's Avatar
Trade: electrical
Rewards Points: 140
Now in Europe everything is 220v. It's also a different CPS. 50 instead of 60 I think. if you bring appliances from the USA, you'll need an adapter. What does that adapter do internally? I'll bet it adds a neutral. On that I could be wrong, but in theory that would make sense. What it does with the cycles I don't know
In Europe one side of the 220 is the grounded conductor (neutral) like our 110 is here. Use a European appliance here and the adapter just allows you to plug the European plug into our 220v receptacle. It does nothing electrical.
If you use an American appliance in Europe that needs the 110v to neutral the only way is to use a transformer- 220v primary, 110-0-110v secondary. So yes, it creates a neutral.
Depending on the equipment or appliance, the 50 Hz verses our 60 may not make any difference.
-Hal
ComRemodel is offline
Old 12-29-2017, 11:58 AM   #24
Lettusbee's Avatar
Rewards Points: 2,308
Step 1: go to home center and buy correct cord.
Step 2: Take cord home, remove from package
Step 3: try to insert new cord into socket to ensure it is correct fit for existing outlet.
Step 4: Listen for big bang and look for light show at end of new cord
Warning, for chrissakes people do not actually follow these instructions!!!
I'm a dead crispy carpenter, not a successful electrician!
Lettusbee is offline
The Following User Says Thank You to Lettusbee For This Useful Post:
SmallTownGuy (12-29-2017)
Old 12-29-2017, 01:33 PM   #25
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,788
lol...and that'll p iss someone off. but sure as hell funny.
kirkdc is offline
Trailer air outlet project BCConstruction Tools & Equipment 24 02-28-2013 08:48 PM
I need to add a ceiling light to a switch that activates an outlet supafly917 Electrical 23 12-10-2012 04:03 PM
USB outlet in the kitchen maverick1980 Electrical 6 11-05-2012 06:59 PM
