tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Wrong 220 Outlet
Old 12-27-2017, 09:39 AM   #1
Stone Guy
Rock Headed's Avatar
Trade: masonry
Wrong 220 Outlet
So I have a newer oven, with a 4 pronged power cord. House has an older 3 pronged outlet.
So, cut off power at the breaker and replace the old outlet, no biggie.
The new over however is missing it's fourth, rounded, prong.
Option B....might sound stupid, but can I just take the power cord from the old oven and put in on the new oven?
OR, if I replace the outlet, does the missing fourth prong matter all that much?--it's just shock proof and wasn't required a couple decades ago.
Rock Headed is offline
Old 12-27-2017, 09:59 AM   #2
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 373
Re: Wrong 220 Outlet
Do the right thing, call an electrician. Your home insurer will thank you.
rescraft is offline
The Following User Says Thank You to rescraft For This Useful Post:
Rock Headed (12-27-2017)
Old 12-27-2017, 10:56 AM   #3
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,302
The solution should be in the oven manual.
Golden view is offline
The Following 2 Users Say Thank You to Golden view For This Useful Post:
FrankSmith (12-27-2017), Rock Headed (12-27-2017)
Old 12-27-2017, 02:15 PM   #4
TimberlineMD's Avatar
Rewards Points: 738
Four prong requires a neutral wire, which you would not have with a three.
Need a electrican.
It's easy to have a business that is busy.. it's harder to have a business that makes a profit
TimberlineMD is offline
The Following User Says Thank You to TimberlineMD For This Useful Post:
Old 12-27-2017, 02:48 PM   #5
Stone Guy
Trade: masonry
Yea, one's on the way.
Old 12-27-2017, 03:30 PM   #6
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,500
No comment.
Why is there not a Flat Mars Society?.
480sparky is online now
Old 12-27-2017, 04:06 PM   #7
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 9,926
Sounds like a good idea. On the back of every new range I've run across is a drawing showing how to place/remove the bonding jumper when going to 3-wire or 4-wire hookup.
SmallTownGuy is online now
Old 12-27-2017, 04:08 PM   #8
John the Builder
https://www.google.com/search?q=GE+r...28Tedh3aOo9iM:
Old 12-27-2017, 04:37 PM   #9
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,977
I just had a 4 prong cord (dryer) replaced with a 3 prong cord to fit an existing receptacle. I made note of the fact that there's definitely a right and wrong (unsafe) way to do it. Don't wing it.
MarkJames is offline
Old 12-27-2017, 05:12 PM   #10
Stone Guy
Trade: masonry
Oven works now. I removed the power cord from the old one, handed it to the electrician and he put it in.
Yeah, I probably wouldn't have done anything catastrophic on my own...but 75$ and it's finished.
Old 12-27-2017, 06:34 PM   #11
480sparky's Avatar
Don't blame us then.
Old 12-27-2017, 07:29 PM   #12
Stone Guy
Trade: masonry
Non sequitur much?
You have not offered any comment. Thus you have no ground to say "you didn't follow my advice, so don't blame me".
I did however follow the advice of others here and did hire a pro.
The Following 2 Users Say Thank You to Rock Headed For This Useful Post:
rescraft (12-27-2017), SmallTownGuy (12-27-2017)
Old 12-27-2017, 10:13 PM   #13
back doors to hell put in
Irishslave's Avatar
Rewards Points: 352
the neutral is for the controls, timer, lights, etc which are 110v. There is no neutral in a 220v circuit.
"An argument against democracy,” an astute observer once said, “is to spend five minutes with the average voter.”
Irishslave is offline
Old 12-27-2017, 10:21 PM   #14
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,063
Umm...
Tinstaafl is offline
Old 12-27-2017, 10:24 PM   #15
ComRemodel's Avatar
Trade: electrical
Rewards Points: 140
Yeah, he better stick to carpentry.
-Hal
ComRemodel is offline
Old 12-28-2017, 10:53 AM   #16
Irishslave's Avatar
Rewards Points: 352
BS Neutral and ground are bonded in the Service panel by means of a green screw unless it's a sub panel. Does your condensing unit have a neutral? No. Two hots and a ground. Water heater....same thing....two hots and a ground. Unless there is a 110 circuit internally in the appliance there is no need for a neutral..
Old 12-28-2017, 11:34 AM   #17
Anti-wingnut's Avatar
Rewards Points: 3,310
Originally Posted by Tinstaafl View Post
Umm...
No, our Irish friend is correct. No neutral on a 220 circuit, but there is one on 220/110 volt circuits, of which the range probably is.
Anti-wingnut is offline
The Following User Says Thank You to Anti-wingnut For This Useful Post:
Irishslave (12-28-2017)
Old 12-28-2017, 11:39 AM   #18
Irishslave's Avatar
Rewards Points: 352
They love to bust my balls around here. Something about the Irish stereotype.
Old 12-28-2017, 11:50 AM   #19
John the Builder
neutral. mfrs cal it that. Code says on new builds 4 wire is required. Calls the middle leg neutral, and 4th is chassis ground.
I don't make the rules...
wrong 220 outlet-8434d1235327410-3-prong-vs-4-prong-oven-outlet-range-4-wire-stubbie.jpg
Old 12-28-2017, 11:56 AM   #20
Irishslave's Avatar
Rewards Points: 352
Now in Europe everything is 220v. It's also a different CPS. 50 instead of 60 I think. if you bring appliances from the USA, you'll need an adapter. What does that adapter do internally? I'll bet it adds a neutral. On that I could be wrong, but in theory that would make sense. What it does with the cycles I don't know
Trailer air outlet project BCConstruction Tools & Equipment 24 02-28-2013 08:48 PM
I need to add a ceiling light to a switch that activates an outlet supafly917 Electrical 23 12-10-2012 04:03 PM
USB outlet in the kitchen maverick1980 Electrical 6 11-05-2012 06:59 PM
