Wiring/grounding For Diesel Tank?
Old 10-18-2007, 06:19 PM   #1
jimb317's Avatar
Trade: electrician
I have a Diesel tank at my fire dept. that has to have power run to the pump. I plan on running Rigid with a sealing eye for explosion proof. If I install a LB between the "eye" and the pump does it have to be explosion proof? What are the grounding requirements for the steel frame of the tank? It is a 1000 Gal. above ground. Anything else I should know that is not obvious? Has anyone ever run electric to one of these tanks?
jimb317 is offline
Old 10-19-2007, 01:41 PM   #2
Kgmz's Avatar
Re: Wiring/grounding For Diesel Tank?
All electrical devices used with or located within twenty (20) feet of the tank should conform to NFPA 70 Hazardous Locations. All electric conduits and wiring connected to the tank should be explosion proof and in strict accordance with NEC Class-1, Division 1 or other local standards whichever is stricter.
Depending on your jurisdiction they may require that all wiring within 30 feet meet the above.
Is this a steel tank or a concrete encased steel tank?
Do you have secondary containment?
Do you have overfill protection and a overfill reservoir?
Don't forget the emergency shutoff switch with sign.
And yes the tank has to be grounded for lightning protection.
Certified:
UST Installation/Retrofitting
AST Installation/Retrofitting
UST Decommissioning
UST System Operator
Vapor Recovery and Systems Installation and Repair
Tank Tightness Testing
Cathodic Protection
Washington State Site Assessment
Oregon Soil Matrix Cleanup Supervisor
UST is Underground Storage Tank
AST is Above Ground Storage Tank
Kgmz is online now
Old 10-19-2007, 09:10 PM   #3
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
great response KGMT
Sparky Joe is offline
Old 10-20-2007, 05:58 PM   #4
jimb317's Avatar
Trade: electrician
I will check with local jurisdiction. The tank is steel, and has a secondary containment.
Thanks for the info. I was going to run explosion proof within 20 feet, but didn't think of the emegency shut off.
jimb317 is offline
septic tank replacement loogout1 Excavation & Site Work 14 10-05-2007 08:23 AM
hot water tank laybrick Electrical 8 04-25-2007 10:18 PM
Propane tank relocation... ruskent HVAC 4 03-19-2007 01:05 AM
Oil Tank KGB HVAC 1 03-18-2007 08:54 PM
oil tank location question Vermonster HVAC 3 10-19-2005 09:14 AM
