Trade: Contractor, Trim Dude, and Custom Cabinet Maker
Rewards Points: 250
Wiring A Barn:
Okay guys, question. I am a contractor(really a carpenter with a license) and need to wire a barn that I built for my grandparents. This barn is used for storage and workshop, not horses etc. What would you guys suggest I use as far as type of wire and also how high would you set your receptacles and how far apart would you space them? The barn size is 24x36 with 3 stall doors across the back, double doors centered on the front, and one 12' sliding door on either end. I plan on putting one gooseneck fixture above each stall door, for a total of 3. Also plan to put 3 recessed lights in the overhang on the front of the barn, as well as workshop lights and one exhaust fan on the interior.....along with receptacles.
Thanks in advance!! |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Box Builder
Rewards Points: 8,788
Re: Wiring A Barn:
If it were me, I would get my electrician to stop in and go over everything with me. Get all the necessary info about where to put things that code requires and how to run wires. etc. At the very least I would think the wiring should be in galv. surface mounted conduit and plugs should be gfi's if a horse could get near them.
Advertisement |
#1 stunner
Re: Wiring A Barn:
Are you paying consulting fees? if so I can send my paypal address.
Service & Repairs
Trade: Electrician
Rewards Points: 2,002
Re: Wiring A Barn:
You may want to consult an electrician and the building department for this job because wiring an agriculture building even though it isn't used for horses etc, has special wiring methods that need to be followed. For instance, romex is NOT one of the wiring methods you can use. There are several but type MC Cable and UF are probably what you're gonna use.
NEC Article 547 |
#5 | |
Rewards Points: 1,524
Re: Wiring A Barn:Quote:
Sparky
Trade: Licensed Electrical Contractor
Re: Wiring A Barn:
I have been doing agricultural electrical work for YEARS. Are you doing a barn or a shop? Is there any animal feed nearby where mice like to hangout? This has a bearing on types of wire you can use. Most BARNS are done in PVC conduit with T90, or RW90 .
#7 | |
Head Grunt
Rewards Points: 2,196
ampman
Trade: providing pathways for electrons and protons
Rewards Points: 516
Re: Wiring A Barn:
do yourself and your family a favor and call an electrician
an army of sheep lead by a lion will defeat an army of lions lead by a sheep |
#9 | |
Project Manager HFH..
Rewards Points: 2,004
![]() Call a sparky....
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber |
Re: Wiring A Barn:
A person who has the talent to erect a building typically has the talent to run some wires in a little shop. It's not like he's going into it blind, he merely asked for a few pointers.
Where's my coffee?
Trade: General Contracting - A/V Integration
Rewards Points: 75
Re: Wiring A Barn:
I would go EMT if it is going to be exposed.
Don't use cowboys... if any animals are ever to be inside they will get hurt on these little devils. Keep it tight to the framing using two hole clamps. Use this as an excuse to buy a bender! ![]() Please, if you can, have an electrican buddy check everything as you go. Then hire him do the panel and finals. You will need his approval for passing. Dave
I never ![]() |
#12 | |
Service & Repairs
Trade: Electrician
And if this electrician's any good he'll tell you that using EMT is NOT one of the wiring methods listed in article 547. Hey James I run a few lines here and there does that qualify me to build an entire building? You guys crack me up, as if wiring is some sort of hobby. |
Trade: scab
Re: Wiring A Barn:
Did someone forget rigid conduit?
Re: Wiring A Barn:
Quote: "You guys crack me up, as if wiring is some sort of hobby. "
Some of you guys crack me up, as if running some wires for a couple receptacles and lights was rocket science. FYI check out the DIY site, there's tons of posts about homeowners doing a lot more than what this CONTRACTOR wants to do. |
#15 | |
Sparky
P.S. I am one of the happiest men on the planet. Thanks framers |
Trade: remodeling and restorations
Rewards Points: 250
Re: Wiring A Barn: |
#18 | |
Service & Repairs
Trade: Electrician
That doesn't mean that half of them aren't idiots you know. I could build 4k square foot house on the weekends including the roof, plumbing, HVAC, sheetrock... all a piece a cake. I have a hammer, a plunger, and some tin snips. What else could I possibly need? Besides that, so what if he's a CONTRACTOR. I'm a contractor, an ELECTRICAL CONTRACTOR. And what is a contractor? Someone who sells contracts!
Electrician service in Rahway, Cranford, Clark, Westfield, Mountainside, Scotch Plains, Fanwood, Roselle, Roselle Park, and New Jersey | Same day electrical service and repairs | Licensed and Insured Electrician in Rahway Last edited by Magnettica; 08-05-2009 at 07:24 PM. |
#19 |
Rewards Points: 250
Re: Wiring A Barn:
Okay smart asses.......
![]() Btw, my county doesn't call for anything other than romex, no conduit at all. The reason I asked was bc I wanted to do it the BEST way, not just the easiest way. As for the smartass that said something about framers, etc wiring and him making money off of it.........well it doesn't take a genious to pull wire.....and that is the hardest part of the job when wiring something as simple as a barn ain't it? ![]() I understand you guys not wanting to help the DIY guys.......but come on....lighten up on a fellow blue collar construction dude......... ![]() |
#20 | |
Trade: scab
![]() ![]() Advertisement |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Ansul system wiring | rad04 | Electrical | 16 | 07-27-2017 10:18 PM |
convert pole barn into house | kalefarmer | Construction | 5 | 07-06-2009 08:07 PM |
Bathroom wiring help please !!! | RICK430 | Electrical | 18 | 06-06-2009 06:26 PM |
'Quick Wiring' question | nadonailer | Electrical | 85 | 05-31-2009 08:57 AM |
Disconnecting Wiring Question | AlSmith | Electrical | 6 | 05-20-2009 09:06 AM |
Go to Page... |
