Trade: Electrical & Carpentry
Wire Nut Spinner
I put this in the recessed lite post, where the guy had bad connections on his wire nuts. In case anybody has'nt benn back there I thought this would be interesting to everyone. I purchased one last year & I wouldn't be without it. It can be purchased at www.licensedelectrician.com
Re: Wire Nut Spinner
Does
it work like my beloved "wobbler"?
Cal You hired WHO
We always used the tan ideal wirenuts. If I ever had several joints to make, I would put a 5/16 nutdriver on a battery drill and I could make quick work of panel changes. The nut driver fit pretty good over the wirenut and spun them like a champ.
Cal You hired WHO
Trade: Contractor
I use one of these sometimes.
Trade: Squirrel Handler
Try one of these:
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
Fentoozler
These have been doing fine for me:
And I do electrical, too!
A nutdriver that's not magnetic works a whole lot better!
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
Service & Repairs
Trade: Electrician
I don't feel the need to have a tool that tightens wirenuts. I don't know, maybe it's because I'm 38 and still have the energy the way I've always done it. How could I be convinced that I need one?
For A lousy $12, buy one & try it-I think you will be convinced-you cannot tighten one as tight as this tool does. To me it is one of the best tools to come along in a long time. I try to keep an open mind and not be stubborn to new things! Some are junk, some are good, as this tool is! It was develpoed & patented by an actual electrician in the field & not by Klein (as the handle does look like Klein)
Trade: Electrician
One of the guys I used to work with had one of those and we did a job and the boss got solid MC Cable he ran a wire through the end of half his connections. I just spin them by hand and if I need a little help I grab a 5/16 nut driver.
Trade: Commercial Electrical Inspector
No offense meant but just shows - create a tool and someone will buy it.
Me personally-I always looked for ways to have LESS tools to lug around. When this topic pops up I always wonder just how much abuse does your splices come across? Why the need to drive that wire nut on so tight that you need to use pliers to remove them? Another issue is guys use these things and end up twisting the crap out of the actual conductors instead of just the ends under the nut. I always used pliers to make the splice and to install the wire nuts. Never had a problem myself. But to each his own |
Master Electrician
Trade: Electrical
Yeah, I'm on lucky's side. The less tools the better. I've been using linesman when I really need to tighten more or I'm tired. If you pre-twist you really don't need to tighten too much anyhow. I think to much and you'll break a conductor off up in there and not even know it. Remember, to pull when your done to see if something got broke. I'm not opposed to new stuff though. I just think that one is not needed.
later |
I twist my wires together with Kleins before I ever put a wire nut on. The splice is mechanically sound and electrically continuous without the nut. The nut is just insulation. My thumb and forefinger can put it on without any problem.
I've seen the ends of conductors run right through and out the end of a wire nut because someone liked to apply a gozillion foot-pounds of torque to them. I'd like to say thanks to the people who do that, because years down the road it can create a short in a metal box, which means a service call for me!
I'm actually developing a power wire nut tightener that will revolutionize the electrical industry. It runs off a marine battery, a high toque DC servo motor and a flexible shaft with a patented adjustable head to tighten (and loosen) wire nuts. I've already reduced the weight down to 63 lbs., might even be able to knock another pound or two off. You might want to place your orders with me early before they hit the market and they're all bought up, we don't have a final price yet, somewhere around $300 bucks, but we expect it to rise with the high demand.
#15 | |
Trade: Contractor
Re: Wire Nut SpinnerQuote:
Just don't mention this to Magnettica. Let's keep that between us, ok?
If anyone (with PowerPoint) wants to see how I make up a box, click here.
#17 | |
Service & Repairs
Trade: Electrician
I used to carry around every friggin tool I owned in a pouch and now all I carry around with me are linesman pliers, beefy flathead (10-in-1 on trim outs), torpedo level, wooden rule, utility knife, sharpie, and a utility pouch filled with wirenuts, ground screws, 6/32/, 8/32, staples and a cellphone. I don't need a wirenut tightener. And wiggy voltage testers. |
#18 | |
Trade: Contractor
#19 | |
Service & Repairs
Trade: Electrician
Liquid nails! |
#20 | |
| Can I split thermostat wire??? | Jambruins | HVAC | 5 | 01-13-2009 06:29 PM |
| Outdoor 18 ga wire vs. 18 ga Lamp Cord? | Greg Di | Electrical | 8 | 10-21-2008 11:42 PM |
| 3-way switch with 14/2 wire | wadswob | Electrical | 2 | 09-23-2008 08:33 AM |
