Wire Disintegrated
Old 11-03-2008, 07:58 PM   #1
General Contracting
LNG24's Avatar
Trade: Real Estate Broker, Property Manager
Wire Disintegrated
I was putting up a simple light fixture today. Easy enough, right.
Pull the old fixture, install the new. As soon as I turned the wire nut to release the wires, the wire disintegrated on me! Literally, the plastic coating just fell off leaving the bare wire exposed all the way back to the clamp.
I am going to get up into the ceiling tomorrow and see if I can splice it down the line, but never saw anything like this before. There is only one small light. Line was not overloaded. House built in 1954
Sorry pic is so small, didn't have my camera phone res. set high enough
LNG24 is offline
Old 11-03-2008, 08:25 PM   #2
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Wire Disintegrated
I hung a light from a box like that earlier this evening. A trip to the HD for a new fixture and 10 minutes later I was done. The trick is to do as little as possible, meaning: pull the old fixture down gently, use side cutters to cut the supply wires, test for a real switch leg or a switched neutral, delicately removing insulation, install fixture bar, attach wirenuts, write up a bill.
Magnettica is offline
Old 11-03-2008, 09:36 PM   #3
Fentoozler
Celtic's Avatar
...or so one might think...
Where in the house was this one lonely small light?
Celtic is offline
Old 11-03-2008, 09:49 PM   #4
TxElectrician's Avatar
Trade: Electrical
Bet someone had removed that pesky insulation from the light canopy so it wouldn't be so difficult to install. Then put in a 100w lamp to brighten things up.
TxElectrician is offline
Old 11-03-2008, 09:51 PM   #5
Fentoozler
Celtic's Avatar
You gave away the punchline!
Celtic is offline
Old 11-03-2008, 10:00 PM   #6
Handle It!
MALCO.New.York's Avatar
Yep!!! Or grossly "over-watted" it!!!! ^^^^^^^^^^^^^ Like he said!!!^^^^^^^^^^^
Ultimate Wisdom---------
MALCO.New.York is online now
Old 11-04-2008, 10:25 AM   #7
General Contracting
LNG24's Avatar
There was no room to be any more careful than I was. As soon as I twisted the wire not, it sheded its skin.
This is a very old fixture. One of those with a square glass cover. True, they might have had 2 100w bulbs in the fixture, but its the line in that disintegrated. Thats 14ga. solid wire?
Fixture is located in the kitchen. Just thought it was interesting. Well time to pull the electrician back onto the job and clean it up.
LNG24 is offline
Old 11-04-2008, 10:37 AM   #8
wireless's Avatar
Trade: Electrician
Ever try unscrewing a 100w lamp while it is on? they get very hot. The light didn't overload the wires, they just got burnt from the heat of the lamps.
wireless is offline
Old 11-04-2008, 10:42 AM   #9
Fentoozler
Celtic's Avatar
Sometimes that happens, because....
...the fixture is over lamped.
Using lamps [generally] larger than 60w WILL have a negative impact on the house wiring.
The fixtures have the 60w rating - this rating is stamped/printed/on a sticker right on the fixture. 60w generates significant heat - ever try and remove a lamp that has been "ON" for a few hours? 100w generates even MORE heat. In this dual holder, 200w is an enormous amount of heat.
This quantity of heat is enough to deteriorate the insulation on the house wiring....#14, #12, #10 ~ doesn't matter. The thickness of the insulation is roughly the same size [the wire size is larger]
The heat generated by the lamps goes UP [as all heat acts]...and essentially bakes the insulation on the house wiring.
You usually don't find this same issue with a receptacle that has had a table lamp that has been over lamped plugging into it [you just find other issues/causes ]
Yup.
I hate doing that job of repairing crispy wiring due to over lamping
Celtic is offline
Old 11-04-2008, 11:21 AM   #10
Tiger's Avatar
Trade: Electrical Contractor
A little hard to tell from the picture, but it's probably varnished cambric (cloth) insulation. It gets brittle in ceiling fixtures from the heat. I usually cut all the wires back into a couple junction boxes in the attic & add a short whip for the new light.
Tiger is offline
Old 11-04-2008, 11:29 AM   #11
Handle It!
If is not a Dimmer.......................USE CFL 150's if they will fit in the "Globe". They use 42 Watts and Generate 1/10th the heat! (GE or Sylvania or Philips any other is CRAP)
Old 11-04-2008, 11:44 AM   #12
listen twice talk once!
Bkessler's Avatar
Trade: electrician
If possible that is the best way to go, It's safer, it's smarter and it should put more money in your pocket too.
Bkessler is offline
Old 11-04-2008, 11:47 AM   #13
Fentoozler
Celtic's Avatar
IF there is an attic....this is in a kitchen ~ options may be limited and the thinking hat comes out.
Celtic is offline
Old 11-04-2008, 01:25 PM   #14
General Contracting
LNG24's Avatar
There is an attic and it is in a kitchen. Going to cut it back later today and see if there is some better wire and then like posted, put a whip to the ceiling box.
FYI: It was wrapped in cloth, but what fell apart was under that cloth wrapping.
LNG24 is offline
Old 11-04-2008, 01:40 PM   #15
Fentoozler
Celtic's Avatar
Oh come on!
Sell them the recessed lighting package w/optional CF box ....don't forget the dimmers are extra
Celtic is offline
Old 11-04-2008, 08:29 PM   #16
220/221's Avatar
Trade: electrician Phoenix AZ
VERY common issue. Light bulbs are freking HOT, especially a couple 100 watters. I've seen drywall disintigrated above the fixtures.
The wire will be good outside the box. Sometimes you can loosen the clamps and slide enough fresh wire for a repair. In a pinch, with no attic access, I have re insulated the wires by slipping new insulation (one size larger) over the bare. This takes madd skills though
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
Old 11-06-2008, 11:14 AM   #17
General Contracting
LNG24's Avatar
Thanks Celtic! If you could only see how many Down Grades we had to do in order to get the entire project in line with their budget.
LNG24 is offline
Old 11-06-2008, 12:20 PM   #18
K2's Avatar
I agree. The wire is generally cooked inside the box only. Wagos can come in handy for these occasions.
K2 is offline
Old 11-06-2008, 12:58 PM   #19
Fentoozler
Celtic's Avatar
I'm sure you explained to them that it will cost a small fortune - maybe even a gov't bail out program - to have someone come back at a later date and do the upgrades they "need"
Celtic is offline
Old 11-07-2008, 01:32 PM   #20
General Contracting
LNG24's Avatar
Its a rental house, Tenants will destroy most if whats been done anyway. They will be lucky to get 10 years out of the kitchen and bathroom. 1-2 years on the floor and walls. Windows, Roof and Siding should last a while though.
Well I was glad I called out my buddy. He spotted some other problems that we took care of. Had to cut it back 5' and put in a whip.
So whats a WAGO?
LNG24 is offline
Outdoor 18 ga wire vs. 18 ga Lamp Cord? Greg Di Electrical 8 10-21-2008 11:42 PM
3-way switch with 14/2 wire wadswob Electrical 2 09-23-2008 08:33 AM
safe hot wire driver Electrical 13 05-12-2006 11:18 PM
