#21 |
Trade: Floorist
Re: Will This Cord Work?
Greatness is a result of focused, deliberate practice |
#22 |
Trade: Floorist
If it helps, the sander's stats are:
Motor type .....single-phase AC motor; Voltage .....230 V; Frequency .....50 Hz; Output .....2.2 kW; Fusing .....16 A; Insulation class .....B; Protection rating .....IP 54; Starting capacitor .....60 μF; Operating capacitor .....40 μF. Here is a link to the OWNERS MANUAL. Pages 31-33 have circuit diagrams. Thanks, Boman.
Greatness is a result of focused, deliberate practice Last edited by TopFloor; 10-11-2009 at 01:07 AM. |
#23 | ||
Trade: Floorist
Re: Will This Cord Work?Quote:
Greatness is a result of focused, deliberate practice Last edited by TopFloor; 10-11-2009 at 01:06 AM. |
#24 | |
Trade: Floorist
Please explain.
#25 |
Trade: Painting & Flooring
I always wondered if this critter was worth it?
http://www.americansanders.com/produ...erbooster.aspx
"Yeah... It's worthy of a sig quote." |
#26 |
Trade: Floorist
For what its worth:
Title: Power Up- Hook Up Power Safely Author: Kim M. Wahlgren "If you need to correct the voltage, a power booster can be placed in line, but keep in mind that most power boosters only increase or decrease the voltage by 10 percent. Power boosters have other advantages besides correcting voltage: they protect the sanding equipment against power spikes, they have a built-in volt meter, and some give you dedicated 110-volt outlets for your buffers and edgers so you dont trip the breakers in the house. You can buy standard boosters or have power boosters custom-built for your specific needs." -from Hardwood Floors Magazine (June/July 2008); pg. 62
#27 | |
Trade: Electrical
You are correct in calling the plug and receptacle devices connectors. There should also be a fitting (connector) attached to the disconnect box to secure the cable to the box. The breaker is indeed a two pole so you're good to go on that! Good to see someone going through so much effort to get it right. |
#28 | |
And I do electrical, too!
Also, there was a green screw that came with the box. Install that so the box itself is grounded properly.
My next question is: What size is the cord itself? I'm guessing 12, which would be too small.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
#29 | |
I was wondering the same thing. Don't about volts, b ut 12 is rated for 20 amps, right? That is also the reason I was wondering what kind of amps the sander pulls at startup. I suspect it is more than the 16 amps posted. |
| The Following User Says Thank You to boman47k For This Useful Post: | TopFloor (10-11-2009) |
#30 | ||
Trade: Floorist
Thank,s 480Sparky. Your knowledge is a huge help.
#31 | ||
Trade: Floorist
Greatness is a result of focused, deliberate practice Last edited by TopFloor; 10-11-2009 at 11:38 AM. |
#32 | |
Service & Repairs
Trade: Electrician
I dare to even say it but the OP might be best off using 2 insulated roach clips to attach to both main lugs and another 1 for bonding the circuit breaker enclosure. Kind of like my temporary service for doing upgrades. picture |
#33 | |
No. There should have been a bonding screw so the ground wire is bonded to the can itself. Without it, a short circuit to the can will not trip a breaker or fuse, but simply energize the can and create a potential shock hazard. Unless that can is not listed for use as service equipment, which in that small of one it may very well not be. But you need to properly bond the can to the ground to prevent a potential shock hazard. Ask your sparky for a #10 ground pigtail.
#34 | |
Trade: Floorist
![]() I checked out your photo link. Thats a nice temporary set-up. Hopefully I will get a skilled electrician to build something 'universal' and teach me how to use it, depending on each situation I may encounter. Thanks for your time in commenting.
#35 |
Trade: Floorist
Got it. I am taking notes, 480, and plan to hit him up with all of these suggestions. When I get his answer I will post it. All your ideas are appreciated.
#36 | |
Service & Repairs
Trade: Electrician
Good luck! |
| The Following User Says Thank You to Magnettica For This Useful Post: | TopFloor (10-11-2009) |
#37 | |
480, are you talking about running this pigtail off the green grnd wire to the can? |
#38 |
Trade: Electrical Contractor
Nice work. You gotta do something to make your work for efficient. I agree with all posters. I would check on the single pole breaker issue (isn't your machine 240V?) Also, the suggestion for more plugs can be done. You have the basic set-up with the over current protection and the right plug for your machine. Now you can make different adapters for the front of your unit. If you run into a 4 wire dryer you would plug your adapter into the plug and your setup into the adapter. Same with over plugs.
Electrician in Alpharetta, Roswell, Atlanta |
| The Following User Says Thank You to Ohmy For This Useful Post: | TopFloor (10-12-2009) |
#39 | |
Yes. I can't tell from the pix, but it's possible the can isn't grounded.
| Tags |
220 10-50 sander ![]() |
| taking a crack at my own concrete work | J-Peffer | Masonry | 9 | 10-25-2010 06:16 PM |
| 4 Day Work Week | TrenchDweller | General Discussion | 26 | 03-27-2009 11:35 AM |
| plumber refuses to finish work | Chris Simms | General Discussion | 7 | 03-25-2009 07:02 PM |
| Homemade Work Tables | KMac | Finish Carpentry | 25 | 11-01-2008 10:01 AM |
| Hiring office work/paper work people? | J-Peffer | Roofing | 3 | 06-22-2008 11:22 AM |
