Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Electrical
Old 10-09-2009, 02:04 AM   #1
TopFloor's Avatar
Trade: Floorist
Will this cord work?
The Machine is a big floor sander which runs on 220. The stove in the home is electric and connects to a 10-50 receptacle and I would like to get my power there. I replaced both plugs on the extension cord and would like to know if it appears I proceeded correctly, or perhaps my creation is unusable for one reason or another.
** I have edited the original image to show the green wire going to the flat blade, white and black at the angles. Thanks, Plumber Bill, for pointing out the original configuration may have been, uh, a little unsafe.
If it helps, the sander's stats are:
Motor type .....single-phase AC motor; Voltage .....230 V; Frequency .....50 Hz; Output .....2.2 kW; Fusing .....16 A; Insulation class .....B; Protection rating .....IP 54; Starting capacitor .....60 μF; Operating capacitor .....40 μF.
I have very little electrical knowledge. I hope someone here can take a look and give a helpful comment.
Thanks.
will-cord-work-sanderplug.jpg   will-cord-work-twistplug.jpg   will-cord-work-angleplug.jpg
~Greatness is a result of focused, deliberate practice.~
Under Construction: www.topflooronline.com
TopFloor is online now   Reply With Quote
Old 10-09-2009, 04:53 AM   #2
Not a sparky here, but you need to reverse the green (grnd) and the white (hot). Check both the male and the female ends to make certain the green wire is in the middle.
Just 2 cents from an insomniac. Since this is electrical and I am no sparky, let one of the sparkies confirm the wiring configuration and comment on the rated amperage of the sander and the stove circuit. The difference in the rated amperage of the stove circuit and the rated amperage of the sander may make a difference in the protection provided to the sander and you.
boman47k is offline   Reply With Quote
The Following User Says Thank You to boman47k For This Useful Post:
TopFloor (10-11-2009)
Old 10-09-2009, 07:55 AM   #3
The Old Master
Trade: Plumbing & Heating
Before you plug that in. Make sure your insurance is paid.
Get ready for the sound "POW"
Reference the angle plug photo (photo now revised edited) 10/10/2009
Bill Parr L.M.P. www.parrsplumbing.com
for a job that's up to "PAR"
Last edited by Plumber_Bill; 10-10-2009 at 08:11 AM. Reason: set the record straight photo edit by poster
Plumber_Bill is offline   Reply With Quote
The Following User Says Thank You to Plumber_Bill For This Useful Post:
Old 10-09-2009, 08:23 AM   #4
Trade: Preassembled, prefinished railing manufacturer
I have to question running the 50hz motor at 60 hz. All motors are not made the same, & some can run on both 50, & 60 hz, but you might want to verify the motors ability to run on 60hz. Green is pretty much always ground, & needs top be on straight lug. Black, & white are two hot leads to angle lugs.
You might want to make up a fuse box to protect your motor. Running a 16amp motor on a 50 amp breaker, & small wire, is not a good practice.
Joe
Last edited by Railman; 10-10-2009 at 11:41 PM. Reason: "verify the motors ability to run on 60hz" (orig 50hz)
Railman is offline   Reply With Quote
The Following User Says Thank You to Railman For This Useful Post:
Old 10-09-2009, 09:13 AM   #5
TopFloor's Avatar
Trade: Floorist
Boman, thanks for the useful reply. I had already been planning to get a sparky to check this all out in person, so the responses I'm getting confirm thats a great idea.
Originally Posted by boman47k View Post
...Check both the male and the female ends to make certain the green wire is in the middle...
I looked again at the instructions I followed to wire the plug. It clearly shows the white wire going to the middle, BUT! it shows black and RED to the side blades. This is why I am asking for a pro to check all of this out beforehand. A novice might deduce that when they say black-white-red, it must be the same as black-white-green. D'oh!
...let one of the sparkies confirm the wiring configuration...may make a difference in the protection provided to the sander and you.
Exactly the kind of opinion I am seeking: useful.
Old 10-09-2009, 09:15 AM   #6
TopFloor's Avatar
Trade: Floorist
Originally Posted by Plumber_Bill View Post
...Before you plug that in. Make sure your insurance is paid...
Hah! I sent my helper to plug it in an hour ago. Damn him! what is this black smear on the kitchen floor??
Old 10-09-2009, 09:20 AM   #7
TopFloor's Avatar
Trade: Floorist
Originally Posted by Railman View Post
I have to question running the 50hz motor at 60 hz. All motors are not made the same, & some can run on both 50, & 60 hz, but you might want to verify the motors ability to run on 50hz....You might want to make up a fuse box to protect your motor. Running a 16amp motor on a 50 amp breaker, & small wire, is not a good practice.
Joe
Point taken. As I said, I know little about electricity, so such a consideration is duly noted. Thanks for the thoughtful response.
Old 10-09-2009, 10:20 AM   #8
TopFloor's Avatar
Trade: Floorist
Et tu Brute
Everyones a comedian.
My wife suggested I should bring along the following tool:
Old 10-10-2009, 04:46 AM   #9
TopFloor's Avatar
Trade: Floorist
...You might want to make up a fuse box to protect your motor....
...The difference in the rated amperage of the stove circuit and the rated amperage of the sander may make a difference in the protection provided to the sander and you...
Thanks for the feedback. Have a look at the final solution. I used it today and it worked like a charm.
Old 10-10-2009, 06:45 AM   #10
Trade: Electrical
I am sure it "works" but it appears you are only protecting one conductor. Isn't that a single pole breaker?
TxElectrician is offline   Reply With Quote
The Following User Says Thank You to TxElectrician For This Useful Post:
Old 10-10-2009, 06:50 AM   #11
rselectric1's Avatar
Good eye TX-I sometimes don't notice the obvious things
rselectric1 is offline   Reply With Quote
Old 10-10-2009, 08:22 AM   #12
Speaking of wire colors, is that extention rated for 220/240? When I think of black, white and green, I think 110, hot, nuetral, and ground.
Old 10-10-2009, 08:26 AM   #13
Lack Of All Trades
Darwin's Avatar
Trade: Professional handyman services
Only thing that will happen is the electrical current will flow up that grabber a zing you!
who dat is?
Darwin is offline   Reply With Quote
The Following User Says Thank You to Darwin For This Useful Post:
Old 10-10-2009, 01:17 PM   #14
TopFloor's Avatar
Trade: Floorist
Thanks for your observation TxElectrician. I will contact the Electrician who set me up with this item and pose this question to him. I started this thread because I desire safety, so a response like yours is much appreciated. I will post the electrician's reply.
Old 10-10-2009, 01:31 PM   #15
Electron Flow Manipulator
480sparky's Avatar
Trade: Electrons for cash
I see the same thing.
Electricity is many things, including color-blind. It doesn't care what color the insulation is. That's why you can use the white as a hot as long as it's re-identified.
Age is just a number but mine is unlisted.
480sparky is offline   Reply With Quote
Old 10-10-2009, 03:50 PM   #16
Trade: Electrical
As long as you're going for safety, go ahead and install a connector on the cable as well.
Old 10-10-2009, 04:25 PM   #17
I think several of us would like to see a picture of the inside of that box.
Can you post one?
Old 10-10-2009, 09:04 PM   #18
God Bless America
Magnettica's Avatar
Trade: Electrician
What will you do when you come to a house that has a 4-wire dryer line receptacle?
You might want to have 2 such set ups, one for the 3-wire, and one for the 4-wire.
Classic Electric LLC
Repairs, Renovations, Rehabilitation
Magnettica is online now   Reply With Quote
The Following User Says Thank You to Magnettica For This Useful Post:
Old 10-10-2009, 11:01 PM   #19
480sparky's Avatar
Or when the dryer is gas, mebbe you should have a 3rd and 4th one for the two range receptacle possibilities.
Oh, wait.... that might be gas, too.
Old 10-10-2009, 11:07 PM   #20
Agreed. Same reason the first configuration would work as long as the the configuration was the same on both ends if all three wires were the proper size. Black tape or paint on the white and good to go? Cord looks big enough since it will only be pulling 16 amps, right? How many amps would that sander pull at startup?
Tags
220 10-50 sander
4 Day Work Week TrenchDweller General Discussion 26 03-27-2009 10:35 AM
plumber refuses to finish work Chris Simms General Discussion 7 03-25-2009 06:02 PM
Homemade Work Tables KMac Finish Carpentry 25 11-01-2008 09:01 AM
taking a crack at my own concrete work J-Peffer Masonry 1 07-24-2008 02:42 PM
Hiring office work/paper work people? J-Peffer Roofing 3 06-22-2008 10:22 AM
