#141 | |
Trade: Master Electrican, Electrical Contractor
Re: Why Does Code Note Require Gfci Breakers On Electric Water Heaters?Quote:
#142 | |
And I do electrical, too!
In order to answer your (now obvious) question (which you at first claimed you already knew the answer to, then stated you would find out, then admitted you didn't actually know....) we have to know what truly happened. Not "I think....", Not "I'll call the power company....." Not conjecture or guesses. Was it a lost neutral, or a lost ground? If it was a lost ground, NOTHING WOULD HAPPEN. If it was a lost neutral, TURNING OFF THE BREAKERS WOULD STILL HAVE DISCONNECTED THE POWER. Does that answer your question? Any more surprises for us? Like it was 120V only service? Nah, I'll stick it out for a while. I'll meander over the the plumbing forum and start up some trouble whilst ARP composes a response.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. Last edited by 480sparky; 09-30-2009 at 12:13 AM. |
#143 | |
Trade: plumbing
#144 |
Good, the wife just hollared something about dinner time, and then I got to go teeech the kids spelllllin..........
#145 |
the pipe master
Trade: plumbing, solar
I have to go to bed as well. I will draw a diagram with the ohms law showing why you will not have voltage at the other end of the energized water service pipe. I'll get to it tomorrow evening.
I'll close for the night with this statement: The water pipe is one giant ground rod. If you apply 120 volts ac to one end of a series of ground rods you will not have 120 volts at the end of the string of rods. A long underground metallic pipe is no different( that's why you attach a ground clamp to the pipes for secondary grounding in the first place remember)
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber |
#146 | |||
Hmmmmmmmmmmm: Quote:
I never said it just cannot happen. It's just I can't pin down what you're saying happened. First, it was the hots that sparked after the breakers were turned off. Then it was the ground that was lost. Then the neutral. Now it's the ground that sparked. Ya know.... it's real hard to hit a target that's moving. The utility may have fixed something at the pole, but there's more to this story than we know. You or me both. Something is missing.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. Last edited by 480sparky; 09-30-2009 at 12:22 AM. |
#147 |
the pipe master
See pic for my response
#148 | |
Trade: plumbing
what problem could the utility company have if I can get a sparking ground wire at a water heater when its disconnected and all the breakers are off everywhere. Now whats your answer? So I got the neutral and the ground confused but only after you guys had no clue and started asking me how it could happen. YOUR THE ELECTRICIAN. Last edited by ARealplumber; 09-30-2009 at 12:27 AM. |
#149 | |
the pipe master
Uh, yes, it does. Do I need to put a meter on a 120v leg and a driven ground rod? How about I install an incanecent bulb in series with a hot leg and a grounded rod. You gonna tell be it wont light? pulease
![]() Quote:
#150 | |
Part of the story we need is: 1. Was the plumbing all metal (copper or galvanized), plastic (pvc/cpvc/pex) or a mix of the two? 2. Was the electrical service properly bonded at the main panel? 3. Is the incoming water line metal or plastic? 4. Was the electrical service bonded to the plumbing (assuming metal piping)? 5. Were there any 'made electrodes' (ground rods, rebar in the footings, plates, rings,..... etc) bonded to the system? 6. Is all the bonding and grounding of a low enough impedence path to properly function as a ground? None of what you've given us tonight would cause it. Maybe combined with another problem, it's possible. Maybe two other problems occured that had nothing to do with what the utility did at the pole caused it. I seriously doubt you'll ever find an answer.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
#151 | |
Waste water in a drain line do not 'seek' the sewer line out in the street, does it? Of course not! You provide a path to it with your drain line. If you did not install a sanitary sewer line between a house and the city's sewer, do you think all the wastewater is going to flow towards the street anyway like lemings to the sea? PuhLeeze!
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. Last edited by 480sparky; 09-30-2009 at 12:40 AM. |
#152 | |
the pipe master
The point I have been trying to make here is that voltage CAN'T travel from one house to another via the water service because the water service is well grounded. Electricity will not go into the ground and then jump back out. It don't work dat way
![]() Quote:
#153 | |
Trade: plumbing
#154 | |
Tell you what. I can make the whole thing easier for you. Get a 12 volt light bulb out of your car. Get the battery from it also. Drive a ground rod. Hook a wire to one terminal only on the car battery. It really doesn't matter which one, you could try either if you want to experiment some, just make sure its only one terminal. Install your bulb in series with that wire and the ground rod. Watch in rapt awe as nothing happens. This result you will get is because you have not learned plumbing well enough yet to explain it properly to us. By your learn ed plumbing knowledge, that setup I just told you ought to send the spare electricity surging out of the battery thru the light and down, down, down, deep into the very center of the earth where all the wild things are. Do a you tube video of that for us.... |
#155 | |
IF (and there's several ifs here!): 1. The service lost it's neutral connection completely between the pole and the house...... and IF 2. some or all of the breakers were still turned on...... and IF 3. some of those breakers that were left on supplied multi-wire branch circuits.... and IF 4. said mwbc's had enough load imbalance on them to create a potential current to ground on it's neutral......... and IF 5. the water heater ground itself was the only path left for said unbalanced current to follow............. Then I could see it happening. But that's a lot of if's. However, if ALL the breakers were actually off, I'll say there's no way the ground could spark. Another possibility (and a long shot, I'm sure you'll agree): Static or devinely-timed lightning.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. Last edited by 480sparky; 09-30-2009 at 01:00 AM. |
#156 | |
Trade: plumbing
![]() ![]() Well I found out today it costs the electrician 15,000 in damage because he was too stupid to know how a simple float switch and pump is plugged in.
#157 | |
Trade: plumbing
#158 | |
Seems I recall someone (I won't say who.......) said "Let's not disrespect people". Now, since both the float switch and pump are plugged in seperately, wouldn't the pump run continuously since there's no float switch to turn it off? And how would that flood the basement?
#159 | |
Trade: plumbing
The pumps thermal overload shut the pump off. The pump would cycle on and off by the thermal overload and finally it burnt the motor up. I guess he just plugged it all in and left,never waiting for it to cut off. He even admitted to plugging it in seperate. He thought thats how it plugged up. |
#160 | |
Trade: Electrical
You must be a real joy on the job site. You know, being smarter than everyone else and making sure you let them know it all the time. ![]() WTF is it with some plumbers. There are a few I know that are the best guys, to the point where we are good friends and pretty much everyone likes them. THEN.....there are several who are complete pricks and don't get along with many folks. I turned in early last night. I am glad the others here showed you what's what.
| Power vent vs. electric water heater. | osborn | Plumbing | 8 | 03-02-2007 11:04 AM |
| Tankless water heaters? | Tenspound | Plumbing | 20 | 06-21-2006 11:37 PM |
| chase for water heaters? | deox719 | HVAC | 3 | 02-23-2006 07:23 PM |
| Electric Baseboard Heaters available | LNG24 | Contractor Swap | 0 | 02-05-2006 01:44 AM |
