#121 |
And I do electrical, too!
Re: Why Does Code Note Require Gfci Breakers On Electric Water Heaters?
Nothing.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
#122 |
Trade: plumbing
There are 3 wires that went into that service panel. The neutral wire had votage coming from the pole and it was feeding through the ground at the water heater. Simple as that. i cant tell you the exact cause but the power company corrected a problem at the powerpole. Its up to you guys to determine why. if you cant come up with a reason then i will call the power co. and ask them how it can happen.
#123 | |
Re: Why Does Code Note Require Gfci Breakers On Electric Water Heaters?Quote:
#124 | |
Trade: plumbing
#125 | ||
OK, let's run with that. So now there's going to be some voltage differences between the each of the two hots and ground. Maybe 110v/130v, maybe 100v/140v, maybe 90v/250v. What it is depends on the loads impressed on each side of the service. But turning the breakers off will still turn off the power, whether it's 120v, 130,v, 10v, 50v, whatever. And if the transformer lost it's neutral, turning every breaker off will then completely disconnect all the wires from the utility. Yes, let's try not to disrespect people. I'm still waiting for class to start.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. Last edited by 480sparky; 09-29-2009 at 11:35 PM. |
#126 |
the pipe master
Trade: plumbing, solar
Perhaps you could break it down for me then.
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber |
#127 |
the pipe master
So let me get this straight. There is sufficient contact with the earth on a few ground rods to ground the system, but not a few hundred feet of larger diameter pipe?
#128 | |
Trade: Master Electrican, Electrical Contractor
#129 | |
#130 | |
Trade: plumbing
add>: You guys are far from professionals or you woulda picked right up on what had happened. This electrical forum needs major help in the tech department. I will still get the ruling for you guys as to what this can do. Since none of you seem to know. Last edited by ARealplumber; 09-29-2009 at 11:47 PM. Reason: add |
#131 | ||
#132 |
the pipe master
And BTW, I was just able to get 67volts by holding one lead and sticking the other one in a 120v receptical. That is enough voltage to shock someone. I was also touching a painted block wall. So if voltage was being back fed into the ground wire of the house arealplumber was in, from another houses inbalanced panel, and the neutral tap on the transformer was not connected, he could have been shocked.
Probable, no. Possible, yes.
#133 | |
Trade: plumbing
YOUR SUPOSE TO BE THE ELECTRICIAN AND HAVE THE ANSWER NOT ME.
#134 | ||
Now you're saying the transformer lost it's neutral. How does power travel through a conductor that is no longer compete and cannot be part of the circuit? What part of your own story don't you understand? Quote:
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. Last edited by 480sparky; 09-29-2009 at 11:54 PM. |
#135 | |
the pipe master
I don't need plumbing terms. Electricity always tries to return to ground. Since it would have to travel through the pipe that is extremely well grounded, it would not travel all the way back up into the adjacent house just to, then threw an individuals body to then get to ground.
Are you going to make me draw you a parallel resistance circuit diagram? Quote:
#136 |
Service & Repairs
Trade: Electrician
you had objectionable current flow because the grounded connection to the utility was lost.
why do plumbers use red for hot and blue for cold, why not green for cold or orange for hot? |
#137 | |
Uh, no it doesn't. Electricity is not 'manufactured' in the ground, and therefore electrons will want to 'return home like salmon'. It will seek any path available back to it's source. If that's through the ground, then so be it. But threre is no lunch counter in the ground that starving electrons are somehow drawn to.
#138 | |
#139 | |
------------- I hope ARP either fesses up or comes clean with an explanation. It's waaaay past my bedtime.
#140 | |||||
Trade: plumbing
Botom line is all you guys were intrested in was telling a plumber he didn't have a test meter or he's stupid. You guys are sad excuses for professionals. ADD>: So somebody lay out why the ground wire was sparking at my water heater. Tell me how that happened. ????? Ground or neutral being lost at the pole or whatever......can it happen? Last edited by ARealplumber; 09-30-2009 at 12:07 AM. |
| Power vent vs. electric water heater. | osborn | Plumbing | 8 | 03-02-2007 11:04 AM |
| Tankless water heaters? | Tenspound | Plumbing | 20 | 06-21-2006 11:37 PM |
| chase for water heaters? | deox719 | HVAC | 3 | 02-23-2006 07:23 PM |
| Electric Baseboard Heaters available | LNG24 | Contractor Swap | 0 | 02-05-2006 01:44 AM |
