Why Does Code Note Require Gfci Breakers On Electric Water Heaters?
Old 09-29-2009, 08:41 PM   #101
ARealplumber's Avatar
Trade: plumbing
Re: Why Does Code Note Require Gfci Breakers On Electric Water Heaters?
Originally Posted by ampman View Post
solar power
Originally Posted by 480sparky View Post
It wasn't on a breaker.
I think Petey was slamming you for not properly testing for power after you 'thought' it was off.
No solar. It was on a breaker. The breaker was off and so were all the other breakers in the outside main panel. I dont think petey has a freakin clue so he decided to make a wise crack. I have a tester and the wire was tested. Now if petey will listen he might just learn a thing or two.
ARealplumber is offline
Old 09-29-2009, 08:42 PM   #102
And I do electrical, too!
480sparky's Avatar
Whatcha gonna learn him? How to test for power when you think the power is off?
Or are you wanting us to guess there was another panel somewhere INSIDE?
Site : the area or exact plot of ground on which anything is, has been, or is to be located.
Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision.
Cite : To mention in support, proof, or confirmation; refer to as an example.
480sparky is online now
Old 09-29-2009, 08:42 PM   #103
Trade: plumbing
Originally Posted by Celtic View Post
I know the reason too....someone was stoopid.
Now, who knows who that someone was
Your in 1st place so far. Sit back and learn somthing
Old 09-29-2009, 08:50 PM   #104
Trade: plumbing
The power company lost its ground at the power pole. It was feeding intermittant voltage back to the house. Have a nice day electricians.
Old 09-29-2009, 08:52 PM   #105
Fentoozler
Celtic's Avatar
Grab the popcorn!!!
The plumba is gonna school the 'lectricians!
I have a prediction:
You are gonna love....absolutely LOVE ...how this ends
It doesn't go well for you.
Celtic is offline
Old 09-29-2009, 08:57 PM   #106
480sparky's Avatar
I would have a nice day if you could explain how a lost ground at the pole can magically bypass the panel.
Old 09-29-2009, 08:58 PM   #107
Trade: plumbing
Grab the popcorn!!!
I love this movie.
Old 09-29-2009, 09:00 PM   #108
480sparky's Avatar
I love this movie.
Yea, it's got fiction, comedy and lots of zany characters.
How about you make it a documentary now?
The Following User Says Thank You to 480sparky For This Useful Post:
Celtic (09-29-2009)
Old 09-29-2009, 09:03 PM   #109
Trade: plumbing
It was feeding through the neutral at the panel from the pole. Who knows what else was wrong with the house...maybe it didn't have a ground rod at the service panel i have no clue. I'm no electrician nor claim to be. I just know the power company came out and corrected the problem at the POLE. I never said i could explain it. I was hoping one of you could explain it.
Old 09-29-2009, 09:04 PM   #110
Fentoozler
Celtic's Avatar
Riddle me this:
How was voltage present with the CB off.
Yes, we know there was no power feeding the panel, but electricity likes to travel back AND forth....not one way.
So what was it's return path?
The water pipes/heaters shell was bonded.
The grounds and neutrals bonded at panel.
So where did it go?
See in order to have a voltage, you must have a circuit, you must have a difference of potential.
You don't have any differences.
If you crap in a tube and the tube is sealed at one end, can the crap ever exit from that end?
Celtic is offline
Old 09-29-2009, 09:05 PM   #111
Trade: plumbing
I will find the answer out for you and the sake of your customers. You can count on it. I'll call the poweer co tomm. Unless sombody else here can explain the "why and how".
Old 09-29-2009, 09:08 PM   #112
480sparky's Avatar
Uh, how does the neutral affect an appliance that does not connect to it?
Old 09-29-2009, 09:10 PM   #113
Trade: plumbing
UH aren't the neutrals and the grounds bonded together in the main outside panel. The voltage was coming into the house to the water heater through the ground wire with the BREAKERS OFF
Old 09-29-2009, 09:10 PM   #114
Fentoozler
Celtic's Avatar
Clearly, you're an idiot:
I sat back...
waiting....
hoping.....
lingering on your every post....
to hopefully learn the answer .....
to this mind boggling mystery.
I gotta say....quite frankly, I'm disappointed.
The trophy is yours....hands down
Celtic is offline
The Following User Says Thank You to Celtic For This Useful Post:
480sparky (09-30-2009)
Old 09-29-2009, 09:16 PM   #115
480sparky's Avatar
Then maybe you can explain this one:
I was working in a house... doing a rewire. The house had sat empty for two years, and all services had been turned off. No electric, gas, water, phone, cable, anything.
Now, the water had been shut off at the street. But every time we flushed the toilet, water would come shooting out of the vent up on the roof. It did this every time we flushed the toilet. And this was a two-story house.
I'll be the first to call BS on your story. Either it's totally fabricated, or there's far more to it that you're letting us in on. You mistakenly believe that just because there's a wire between two points it is energized just because it's a wire.
Stick to plumbing..... shît runs downhill, and payday is Friday.
Old 09-29-2009, 09:20 PM   #116
Trade: plumbing
Tell me what would happen if the power company lost its ground at transformer?
Old 09-29-2009, 10:06 PM   #117
macmikeman's Avatar
Trade: Master Electrican, Electrical Contractor
Originally Posted by protechplumbing View Post
I don't see that happening. The amount of pipe surface area exposed
to the moist earth would dissipate any voltage before it made it all the way back up the neighbors water service and into his house. The water services would essentially be acting as grounding electrodes.
Protech stick to plumbing. You are so far off with that statement it is actually quite humorous. Thank you for that. I think I am going to have to raid the plumbers forum with insane stuff like that one.
macmikeman is offline
Old 09-29-2009, 10:11 PM   #118
Fentoozler
Celtic's Avatar
Originally Posted by macmikeman View Post
I think I am going to have to raid the plumbers forum ......
Last guy almost didn't make it back...
http://www.plumbingzone.com/f4/creating-service-division-4817/
Celtic is offline
Old 09-29-2009, 10:12 PM   #119
macmikeman's Avatar
I will. Pretty much nothing unless there is a SWER system in use at that location.
Old 09-29-2009, 10:15 PM   #120
Fentoozler
Celtic's Avatar
I will.
aww...Mac.....I was hoping he would call
Celtic is offline
Power vent vs. electric water heater. osborn Plumbing 8 03-02-2007 11:04 AM
Tankless water heaters? Tenspound Plumbing 20 06-21-2006 11:37 PM
chase for water heaters? deox719 HVAC 3 02-23-2006 07:23 PM
Electric Baseboard Heaters available LNG24 Contractor Swap 0 02-05-2006 01:44 AM
