Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Electrical
Closed Thread
Old 09-30-2009, 01:30 PM   #181
Trade: plumbing
Originally Posted by ARealplumber View Post
I was disconnecting an electric water heater at a home. I turned the power off to the water heater. Opened the cover at the top for the wire connections to the unit,pulled the wired out and they sparked. I turned every breaker in the outside panel off and it still would spark. I know the reason why this happened but was curious as to what others think it was.
HERE IS MY ORIGINAL POST. I STAND BY THE STATEMENT I KNOW THE REASON. THE REASON WAS GIVEN TO ME THAT THE POWER CO HAD A PROBLEM AT THE POWERPOLE. Dont try to take a word out of context to make up for your lack of knowledge. read the LONG AZZ post with the answer you friend posted a few minutes ago. Go ahead and learn somthing.
ARealplumber is offline
Old 09-30-2009, 01:35 PM   #182
Licensed Contractor
Magnettica's Avatar
Trade: Electrician
He already knows what's written in that article. I posted that info for you so your face will turn red when you realize the article says what they said in post #155 and #162.
Magnettica is online now
Old 09-30-2009, 01:39 PM   #183
Trade: plumbing
I guess you dont read well either. Compare the lenght of the magazine article you posted to those posts. OK NOW TELL MR SPARKY THAT THE BREAKERS BEING OFF WILL NOT STOP IT FROM HAPPENING. THINK YOU CAN DO THOSE TWO THINGS?
post number 162 was posted this morning around 6 am. what happened lastnight?
Old 09-30-2009, 01:45 PM   #184
Licensed Contractor
Magnettica's Avatar
Trade: Electrician
Originally Posted by 480sparky View Post
IF (and there's several ifs here!):
1. The service lost it's neutral connection completely between the pole and the house...... and IF
2. some or all of the breakers were still turned on...... and IF
3. some of those breakers that were left on supplied multi-wire branch circuits.... and IF
4. said mwbc's had enough load imbalance on them to create a potential current to ground on it's neutral......... and IF
5. the water heater ground itself was the only path left for said unbalanced current to follow............. Then
I could see it happening. But that's a lot of if's.
However, if ALL the breakers were actually off, I'll say there's no way the ground could spark.
Another possibility (and a long shot, I'm sure you'll agree): Static or devinely-timed lightning.
I agree with everything other than "if ALL the breakers were actually off, I'll say there's no way the ground could spark" because if the neighbors service is powered from the same transformer there is still a load there, but not if all their breakers are off too which is what he probably meant.
Just admit that this technical talk is way over your head Mr Plumberman.
Old 09-30-2009, 01:53 PM   #185
Electron Flow Manipulator
480sparky's Avatar
Trade: Electrons for cash
OK, I am going put this as simple and sincerely as possible:
It is painfully obvious you have no clue what you are talking about. You are a poser. And a troll. And a liar. You should stick to plumbing because shît runs downhill and payday is Friday.
You claim this..... You claim that. But you cannot provide any sort of evidence, proof, information, documentation, anything other than you say 'Well, it happened!".
Fine. Believe what you will. I'm sure the union just loves to have self-dilusional helpers on the jobsites.
I wish you well in your endeavors in life. May your illusions of grandeur provide you with many lovely surprises in the future.
You are not worthy of any more of my attention. I will punch out now.
By the time you can make ends meet, they move the ends.
Last edited by ChrWright; 09-30-2009 at 02:22 PM. Reason: Offensive quote removed.
480sparky is online now
Old 09-30-2009, 01:59 PM   #186
Trade: plumbing
I totally admit it. Ive been saying it from the start. I never said i could explain it all. I was attacked from the start. I see mr sparky doesn;t want to talk about it anymore......i guess he doesn;t agree that the breakers has nothing to do with it. Atleast he admits now it CAN happen.
Old 09-30-2009, 02:06 PM   #187
Licensed Contractor
Magnettica's Avatar
Trade: Electrician
I agree!
Old 09-30-2009, 02:26 PM   #188
ChrWright's Avatar
Trade: Builder/Remodeler
I think the OP got the info he needed.
This thread is closed.
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI
www.WrightWorks.net - Facebook - Twitter
Indianapolis Remodeling Contractor - Remodeling Photos: Kitchens, Baths, Room Additions, Basements
"The first responsibility of a leader is to define reality. The last is to say thank you." -Max DePree
ChrWright is offline
Closed Thread
Power vent vs. electric water heater. osborn Plumbing 8 03-02-2007 11:04 AM
Tankless water heaters? Tenspound Plumbing 20 06-21-2006 10:37 PM
chase for water heaters? deox719 HVAC 3 02-23-2006 07:23 PM
Electric Baseboard Heaters available LNG24 Contractor Swap 0 02-05-2006 01:44 AM
